Introduction: Turn Cell Phone and Tablet in 3D Hologram
About: Hi there! We are Frank and Gish and we like to explore the world of lifehacking and DIY. We also run a community driven DiY francophone platform.
Have you seen this yet? I mean, have you seen the actual hologram, for real?
If not, it will take you about 20 minutes to get your own pyramid shaped hologram display.
Update: If you want to try a even easier way, check out our other Instuctable that shows how to simply print one.
Although it is not real 3D because it is 4 times a 2D images, the result is simply amazing. The original idea comes from American Hacker.
Considering that a lot of people are asking for dimensions for bigger devices such as new iPhone 6S Plus or tablets, we created templates for several popular devices. They are in attachment and printable.
(We know. You're welcome. ;)
You could also create you own holographic video, keeping in mind that all areas aound the subject need to remain black (the use of a green screen helps) and paste the image 4 times in the screen using a video editing program. Anyone willing to give tips on this matter is welcome to comment. ;)
Anyone who would like to see the step by step en français, c'est par ici! :)
Step 1: What You'll Need
  • Plastic CD case, ideally not too used or scratched
  • Cutter with a good blade
  • Ruler
  • Template for phone or tablet (see attachments) or pen and paper
  • Scotch tape
  • Krazy glue (optional)
  • Cutting mat (optional)
Step 2: Create or Print Your Template
This is what the basic template looks like. You can either recreate this or simply print one of the PDF in attachment. You can choose from several smart phones and tablets dimensions.
Step 3: Cut Your Template
Since the pyramid is 4 times the same dimensions, you only need one template.
Step 4: Cut Your First Shape
Secure your template on your CD case with scotch tape. Unlike on the picture, use a ruler. This will make things much more easier. I also recommend doing multiple light-medium cuts instead of a unique heavy one. You are less incline to crack the plastic and your cut will be more precise.
Step 5: Repeat Step 4
You need 4 identical shapes.
Step 6: Create the Pyramid
Lay your 4 faces flat, side by side, and tape the edges.
Step 7: Finalize the Pyramid
Secure the remaining edge and give the dimensions to your pyramid. It needs to stand by itself, as straight as possible, upside down.
Step 8: Glue Edges Together
This really is optional, as it can be a little bit messy. It can make your pyramid more sturdy but can also mess up the clearness of your shapes.
My personnal opinion is that if you tape precautiously, the result will be fine enough and you won't need glue.
Step 9: Try Your New Display
Here is the original video, ready for you to try your gadget. Just place your pyramid upside down (wide opening upwards) in the center of the image. Close the lights, and enjoy!!
Step 10: To Watch the Final Result
Filmed in 4k, this is a great example of what you see with the pyramid.
By the way, I created the templates based on popular 2014-15 mobile devices, if you think one is missing, feel free to let me know, I'll add it to the attachments.
