Turn the Lights on or Off From Your Bed (can Be Done in 5 to 10 Minutes)
25,786
11
10
Introduction: Turn the Lights on or Off From Your Bed (can Be Done in 5 to 10 Minutes)
I always hated having to get up from my bed, turn off my lights, then stumble over all the stuff on my floor as I went back to bed. This simple solution takes 5 to 10 minutes, and can be done with stuff from around the house.
Parts list:
Sticky tack
String
Thumb tacks
Something Heavy
Step 1: Prepare Your String
Tie a small loop that will fit over the light switch in the string near then end, and tie the heavy thing to the string 3-4 inches from the end.
Step 2: Loop the String Over the Switch
Loop the string over the switch.
Step 3: Secure It With Sticky Tack
Secure the string to the switch with sticky tack.
Step 4: Use the Thumb Tacks As Makeshift Pulleys
Stick one thumb tack into the wall, and one into the ceiling to use as a pulley
Then attach the end of the string to the wall with another thumb tack
Video of it in action:
Be the First to Share
    • Anything Goes Contest
    10 Comments
    ElectricalE1
    ElectricalE1
    7 years ago
    This is a very easy approach that works always and everywhere...
    Create a short circuit!
    youtu.be/A4ci7fRyh1Y
    hailey.smith
    hailey.smith
    Reply 2 years ago
    what there is no way
    ncaplan
    ncaplan
    12 years ago on Introduction
    any suggestions for a push button light?
    samsalvo64
    samsalvo64
    Reply 11 years ago on Introduction
    You could tie three strings to a bolt, one next to the head, one twords the end, and hot glue the third on the bottom of it. for the two you tied, thumb tac them to the ceiling and measure so it's right in front of the switch and the hot glued string have next to your bed (if it is your bed) and when you pull the string, let go and the bolt will hit the light switch. Whala! lights OUT!!!1
    whiplash
    whiplash
    love the idea pity it wont work with my lightswitch cause they dont stick out like these
    rimar2000
    rimar2000
    13 years ago on Introduction
    Very clever. In 1962 I maked some similar to manage the radio volume-on-off.
    dooey100
    dooey100
    Reply 13 years ago on Introduction
    Thanks! There are a couple similar instructables, but they all require two strings and/or more parts that must be purchased.
    Kwitmeh3
    Kwitmeh3
    the one string, bolt thing is childish but thumb tacks are good use instead of buying pulleys
    uguy
    uguy
    My son did this very same thing when he was about 13-14 and I still caught him trying to stay up late.
