Turning Large Bowls on the Table Saw.
Intro: Turning Large Bowls on the Table Saw.
My wife wanted a center piece but I don't have a large lathe. After testing the idea I dove right in and coved it out! lol, "coved it out? Get it? Ahhh, wood nerds. There will be a full 30+ min how to video soon but I really liked the way the short video and the bowl turned out and wanted to share.
31 Comments
zo0oltr26 1 year ago
jonnmero 7 years ago
Up there for thinkin', down there for dancin'!
Plainclothescivilian 8 years ago
Hoang LanN 8 years ago
I bought Dewalt DW175 miter saw two months ago. I have problem with cutting board 90
degree. Do you think I use table miter saw improve cutting boar? I want to
décor crib for my daughter
MrBillG59 10 years ago
I'm not sure you needed the splines. It was unclear, but it looked like you used the same wood for both the bowl as the splines and it looked like the grain for the bowl was going in the same direction as wood for the splines.
You may not realize but a properly glued and clamped long-grain joint using yellow carpenters clue (and probably epoxy) is stronger than the wood itself. Meaning that the wood will break somewhere other than the joint before the joint breaks.
You might have saved yourself a lot of work.
NelsonStudios 9 years ago
The spalted wood is weakened by rot and I was afraid it would not hold with a lot of strength as I cut most of it away. I used the cherry splines because I figured if I can't hide them then I might as well show them off.
AARENAARON 9 years ago
DUDE, very coool and Smart project
Javin007 10 years ago
Brilliant method! Wish I'd seen this before last weekend. Wife and I made a game wheel and cut the main wheel out with a jig saw. Wheel isn't perfectly circular now, resulting in pegs that are imprecisely placed. May think about just buying another hunk of wood and rebuilding the wheel with this method.
seamster 10 years ago
Impressive. I was quite intrigued by the title, and then again by the methods you used. I would have never thought to use a table saw that way. Very nice work! Hope you win something!
Shiseiji 10 years ago
Thanks so much for sharing!! The speed up was super. I try to avoid videos because they are just so slow at conveying what I could read in 1/10 the time. Your video was perfect!
dancing_sam 10 years ago
Wow! Table saw mastery!
smirnoff04 10 years ago
Way to stretch the functionality of your tools. Great instructable.
rcharles47 10 years ago
Very smart and a great video - appreciated. So good to see a youngster involved ... my younger daughter helped working on vintage cars aged 5 and now rebuilds and maintains her own cars as well as driving them
Dominic Bender 10 years ago
Cool project, and interresting way to go about it. Thanks for sharing!
What I would love to hear more about is your finishing technique, I have not come across using epoxy as a finish before.
NelsonStudios 10 years ago
It is a side effect of working in spalted wood and that is the only place I do it. If you have never worked with it before spalted wood has started to rot and can be very spongy. It is also beautiful so when working with it you have to fill the sponge with something, either coats of finish or in this case epoxy. If you just brush on poly it will suck into the soft spots and pool on the hard giving it an ugly mottled look. Poly will do it but you have to sand between to keep the hard spots from building a real thick film. With the epoxy it soaks in, seals and hardens then after light sanding you can give it just one coat of poly and it goes on even. Most of the times... sometimes the punk is so bad it takes two coats of epoxy. When that happens you just have to paint it on again and scrape it back down to bare wood, a real pain. The detailed how to video is done and should be online by Monday afternoon, I talk and show the process there.
neutrinoau 10 years ago
Yes. I roughed it out with a wobble dado blade because it could take 3/4 of an inch latterly when I slid it sidewise but was in every other respect a horrible little blade. It also didn't have the reach. The final cuts were done with a good stacked dado blade with the very last cut being about 1/8 of an inch.
Fikjast Scott 10 years ago
Great job, I like that you had a little helper on the project or at least came to visit you while you worked.
Mattrox 10 years ago
Some awesome ingenuity shown here. Nice one! The finished bowls looks so good too!
adamwatters 10 years ago
Coolest video i've seen on instructables and a really incredible project. Great work!
