Introduction: Tutorial: How to Use Analog Ultrasonic Distance Sensor US-016 With Arduino UNO
Description:
US-016 ultrasonic starting module allows 2 cm ~ 3 m non-measurement capabilities, supply voltage 5 V, operating current 3.8mA, support analog output voltage, stable and reliable. This module may be different varies depending on the application of the scenario (maximum measurement range for each 1 m and 3 m); When the range of pin floating range is 3 meters.US-016 measuring distance can be converted to analog output voltage, the output voltage is proportional to the measured distance.
Feature:
- Working voltage: DC 5V
- Working Current: 3.8mA
- Operating temperature: 0 to + 70 degrees
- Output: Analog (0 ~ vcc)
- Induction angle: less than 15 degrees
- Detection distance: 2 cm-300 cm
- Accuracy: 0.3 cm + 1%
- Resolution: 1 mmModule
- Size: 45mm * 20mm * 1.2mm
Step 1: Material Preparation
The photo above show the material needed in this tutorial:
