Introduction: Tv Cover
I like to listen to youtube/music before bed on my tv but sometimes it gets much too bright depending on what i'm listening to. Even after turning the brightness all the way down I still can't sleep. So my idea is to make clips that you can attach a curtain to. You can put this in front of your tv so little brightness comes straight on.
Access to a 3D printer
A curtain rod
Blackout curtains
Step 1: Create a Sketch
Use the sketch tool to create a sketch
Step 2: Rectangle
In your sketch make rectangle using the 2 point rectangle tool make it 10cm by 6 cm.
Step 3: Extrude
Extrude the block to 4cm using the extrude tool
Step 4: Sketch Another Rectangle
Sketch another rectangle inside the original using the 2 point rectangle tool make it 5cm by 4 cm
Step 5: Extrude
Extrude the smaller rectangle to -4cm
Step 6: Sketch a Circle
By using the center circle tool make a circle on the same point i did, make the circle 14 cm
Step 7: Sketch a Second Circle
Make another circle inside the first one once again using the same points I did. Make the circle 11 cm
Step 8: Extrude
Extrude the bottom part of the bigger circle using the extrude tool with the join operation to 4cm
Step 9: Fillet
Fillet the inside edges to avoid scratches on your Tv to 4 mm using the filet tool
