Twine Ball Lamp Shades
Intro: Twine Ball Lamp Shades
Spring has sprung! Revamp your outdoor decor with these DIY twine lamp shades. Transforms your traditional christmas lights into ambient spring and summer lights.
STEP 1: Gather Your Materials
balloons
plastic wrap
spray paint (I used Krylon Metallic Gold)
paint brush or foam brush
christmas lights
STEP 2: Wrap, Wind, Wait.
Next, you will inflate the balloons to your desired size.
Wrap each balloon in plastic wrap.
Wind the twine around each balloon and over the plastic wrap. (Don't worry about cleaning up the ends, you can trim them after drying.)
Use a paint brush or foam brush to paint the Mod Podge over the twine. Be generous! The more Mod Podge, the stiffer the shades with dry.
Now you must wait for the Mod Podge to dry. I suggest waiting overnight to achieve the best results.
STEP 3: Pop and Paint!
After your Mod Podge dries, you will pop each ballon and pull out the balloon and plastic wrap from the interior.
I suggest first pushing into the balloon at the openings to pull the plastic wrap away from the twine. The Mod Podge might dry and adhere to the plastic wrap.
Afterwards, spray the twine shades with your selected spray paint.
STEP 4: Almost Done!
Once your lamp shades are done drying, you can string them onto the christmas lights.
Find the larger gaps in the twine and stuff several light bulbs into each lamp shade. Continue this process, stringing the lamp shades along the lights.
You can choose how to use them. Lined in a row, placed in a bowl, or strung across a balcony.
15 Comments
Rosanna Mullet 10 years ago
I totally want to make these! they are so pretty!
dbeylina 10 years ago
thanks!
mommywoman 9 years ago
SweetSecrets 10 years ago
OooooOOOoooo I like these. I might just try them out. Great design, good idea!
wabbit75 10 years ago
WoW, I can't wait to make these for our Bedroom!
kosteej 10 years ago
Would there be any worry of the twine catching on fire from the lights?
I haven't had any trouble with these shades for a full year. I would recommend only using these outdoors where the air is cooler, and over-heating is less likely. Your largest safety concern is replacing any string of lights with worn or broken cords or loose bulb connections.
ekiessling 10 years ago
thanks!
sunshiine 10 years ago
I love your design. Thanks so much for sharing your hard work and do have a safe and happy spring!
sunshiine
thanks!
emilyvanleemput 10 years ago
They look so pretty! How tricky is it to remove the balloons?
Thanks! not that tricky at all. Definitely let them dry completely and you can use scissors to try to cut away any plastic wrap that my solidify from the Mod Podge.
tpatten-scheinost 10 years ago
susanjerrell 10 years ago
