Introduction: Twisted Spoke Bicycle Wheel Lacing - Flowers!
I've never given my girl flowers.... Except for the surfboard with frangipanni's on it. When i recently built her up a light'n'sexy single speed for running about town i decided to braid into each wheel a flower complete with petals. Here's how.
Step 1: Front Wheel
36 spoke hub
hole spaceing (measured between hole centres accross the hub.) = 38.4mm
hub width: 68.4mm
314mm spokes
608mm diameter rims.
Step 2: Choose Your Spokes.
Take a look at all the online spoke calculators. Largely ignore them.
Basically just take a set of spokes way too long to build for the equipment you have.
Take a best guess at the twisty pattern. I've included 3 configurations in this how-to as a guide. I don't know of any spoke calculator for doing these patterns...
Step 3: Lace Very Loosely One Side of the Wheel.
lace all spokes loosely on one side of the wheel. I'd suggest looking at sheldon brown's wheel lacing guides as an excellent guide. http://www.sheldonbrown.com/wheelbuild.html
Step 4: Now the Tricky Part. Lace the Other Side
put in half the spokes only in alternate holes. loosely tighten them in with the nipples.
Step 5: Put in the Second Half of the Spokes.
you should be able to wrestle the spokes into place. the first half are easy, then they get increasingly hard.
try and lace them opposite each-other ie for each one on this side of the wheel, insert one on the opposing side next....
Step 6: Tighten and True Wheel
This is also a tough bit. Trueing these wheels isn't anything like trueing normal wheels. tightening a spoke somewhere has untold effects elsewhere on your wheel...
the secret is to tighten all up to firmish, then to proceed very slowly, sort of 1/4 turns on each spoke
Step 7: Ride, and Re-true.
Unlike a normal wheel, these will take a while to settle in. You'll need to ride a few times and re-true after each ride. The first ride in particular will be kinda scary as your wheels make a lot of noise. The spokes are rubbing on each-other and settling into their final configuration.
Step 8: Alternative Lacing Pattern.
36 spoke wheel.
62.4mm hole diameter.
66.8mm wide hub.
266mm long spokes.
540mm diameter rim.
Step 9: Alternative Lacing Pattern #2
36 spoke wheel.
hole spacing accross hub: 61mm
hub width: 74mm
304mm spoke length
608mm rim diameter.
39 Comments
16 years ago
And one for the testing on my a.t.b. let's just check if the city-curbstones will prove too much. This one's in 26" with 280mm spokes (14) haven't measured the hub, it's a standard shimano (ALTUS!) one. Firts ride now, adjusting already needed. But very little. Fun to make and nice to PIMP MY BIKE!!! Thanx for putting the design on the web. Greetings from Zutphen (Netherlands)!!!!
Reply 11 years ago on Introduction
Congratulations!
This post has won today's I Made It Challenge! For that they will receive a 3 month PRO membership!
Thanks for using instructables.com!
https://www.instructables.com/community/June-is-I-Made-It-Challenge-Month-Win-a-Pro-Mem/
1 year ago
So I did this lace style on a rim and took it in to get trued and the bike shop wouldn't even touch it!
10 years ago on Introduction
that is really far out. I won't to try to make a wheel like that myself. http://nabacar.com
thx...
Anyone notice these two pictures, the spokes are laced differently.
In the first picture; all the spokes from the left hand hub flange go to the spoke/nipple holes in the left hand side of the rim. And vise versa for the right hand side. As it should be.
In the second photo; some of the left hand spokes (left hub flange) go the holes on the right side of the hub. Every 4th hole! I can see why - it is more aestetically pleasing to the eye.
My question is, is this ok for show but not for the road? its obviously puting more of an angle on the spoke/nipple/rim hole. Would you ride the miss matched wheel in terms of left/right handed rim and flanges.
I hope that makes sense!
really depends on the wheel. most rims with directional eyelets wont even allow for that kind of lacing without some force, but if you use a velocity deep v for instance without eyelets at all, or say a single wall rim you may find that it works alright, but the actual truing of the wheel after the fact will be hard to accomplish. i mean, theres a reason that wheels have the four spoke pattern. probably ok to use with the right tension, but you can bet on it if you lace it properly.
Great pattern but where can I get the lacing instructions? Can you send me them? Or is there a website for exotics??? Thanks.
Awesome job. I bought my wife a mtn bike for mother;s day - she would have loved a set of wheels laced like yours...
12 years ago on Introduction
jeez, that must be a huge pain to keep them wheels true
16 years ago on Step 2
I ahve built up a set of these, a general rule of thumb is to take the length the spoke calculator gives you, and add 10mm
Reply 12 years ago on Step 2
hi, do you mean 10 mm compared to a cross-3 pattern?
Reply 12 years ago on Introduction
Yes, I think that is what the OP was referring to.
How is the integrity of these?
nice....got any patterns for BMX?
btw if u go to the web :http://www.sheldonbrown.com/wheelbuild.html
and go to the section called 'nipples'......u'll get a good laugh there :)
13 years ago on Introduction
Thank you for sharing your beautiful spoke patterns. However, I think, in structural engineering point of view, the double twisted one has too much degree of freedom in each twisted point to sustain severe external lateral loads, which can overwhelm the frictions and bending forces in the joint(twist) and finally cause the deflection of the rim. For example, when it is deflected like the Pringles, which causes specific part of the rim to be lengthened while making the other 90 degree locations shortened, the spoke pattern may just easily changes its lengths by pulling the adjacent "petals" gradually because the location of the first twists from the hub are not firmly fixed and the second twist point can also be moved by the external load. In my opinion, the double twist one can be trued for internal static equilibrium, but cannot be fully resistant to external forces. Regardless of my opinion, I feel your pattern gives us, amateur wheelbuilders all over the world, a great inspiration. Thank you.
14 years ago on Introduction
Amazing work. I'm not so familiar with bike mechanics, but I want to spiff up a bike I already have. Is there a way to remove the spokes from the wheels I have, twist them, and put it back?
I did this over 20 years ago and twisted the spoke 3 times. I built the wheels for Laguna Bicycles back in the late 70's early 80's
Very cool & clever. I want to attempt it, but I'm already challenged a bit, when lacing up a standard wheel.
15 years ago
I haven't seen the double twist, but I have built several wheels with a single twist design. I always used spokes that were about 5mm longer than whatever the spoke calculator called for on the single twist. Downsides of the wheel are that if one spoke breaks you effectively have two broken spokes, and they are VERY difficult to build round. Getting them true is easy, but keeping (or at least trying to keep) them round in the building process is a nightmare. Upsides of the wheel, once they settle they do a great job of staying true. The cross gives GREAT torsional stiffness, which makes them great for rear wheels and disc brakes. It is somewhat akin to the old style of tie and solder. I would suggest getting a few normal three cross wheels under your belt before going for the twist. For a professional look, make sure that any labels on the rim are readable from the drive side. You should also be able to read the label on the hub through the valve stem hole. And last but not least the valve stem should not be in the middle of the last cross. I edited your image to show the proper placement. (I hope you don't mind.) For those interested in building wheels, look into getting the book "The Bicycle Wheel" Great reference manual and Great information.
