Introduction: Twitter Poem Box
Included are two versions of the same project. One version used the Seeed Studio 125Khz RFID module, while the other used the The Parallax Serial RFID Reader / Writer Module.
Twitter Lamp from SACC-PC on Vimeo.
Step 1: Parts
Seeed Version Part List
* Seeed Studio 125Khz RFID module - Wiegand (RFR102A1M) http://www.seeedstudio.com/depot/125khz-rfid-module-wiegand-p-225.html?cPath=144_153
* 3 RFID 54mm x 85mm Rectangle Tags-http://www.parallax.com/Store/Accessories/CommunicationRF/tabid/161/ProductID/689/List/0/Default.aspx?SortField=ProductName,ProductName
*1 BlinkM http://thingm.com/products/blinkm
* 1 Arduino
* 1 Arduino Ethernet Shield-http://www.adafruit.com/index.php?main_page=product_info&products_id=83&zenid=9b755efcfe260b30eee32576599c81c5
* WIZ812MJ Ethernet SPI/Bus Module (RJ45) 2.54mm Pitch http://www.saelig.com/product/ETH042.htm
* 1 Ethernet Cable
* 1 USB Cable
* 1 Unused Ethernet Port with connection to internet
* 1 Solderless Breadboard
* 1 LED
* 1 220Ω resistor
* 22 AWG solid core wire
* Soldering Iron
* Lead-Free Solder
* Wire Strippers
* Wire Cutters
* Glue Gun
* Velum
* Tape
* Hot glue
* Box
* X-acto knife
* Drill
Parallax Version
* The Parallax Serial RFID Reader / Writer Module http://www.parallax.com/Store/Accessories/CommunicationRF/tabid/161/ProductID/688/List/0/Default.aspx?SortField=ProductName,ProductName
* 1 BlinkM-http://thingm.com/products/blinkm
* 1 Arduino
* 1 Arduino Ethernet Shield-http://www.sparkfun.com/products/9026
* 1 Ethernet Cable
* 1 USB Cable
* 22awg solid core wire
* Soldering Iron
* Lead-Free Solder
* Wire Strippers
* Wire Cutters
* Glue Gun
* Velum
* Tape
* Hot glue
* Box
* X-acto knife
* Drill
* Cardboard Tube
Step 2: Seeed RFID
The RDM 125KHz card mini-module is designed for reading code from 125KHz/ 134.2KHz card compatible read-only tags and read/write card . It can be applied in office/home security, personal identification, access control, anti-forgery, interactive toy and production control systems etc.
1. To connect the RFID reader to the arduino, attach pins 1 and 2 of the RFID reader to digital pins 2 and 3. Connect the RFID reader to 5V and ground.
2. Attach the LED and the 220Ω resistor to the RFID reader. The LED will serve as a signal indicator.
3. Upload this code to your arduino:
/* Modified from
* Crazy People
* By Mike Cook April 2009
* An RFID reader outputing 26 bit Wiegand code to pins:-
* Reader attached to Pins 2 & 3
* Interrupt service routine gathers Wiegand pulses (zero or one) until 26 have been received
* Then a string is sent to Serial
volatile long reader1 = 0;
volatile int reader1Count = 0;
void reader1One(void) {
reader1Count++;
reader1 = reader1 << 1;
reader1 |= 1;
void reader1Zero(void) {
reader1Count++;
void setup()
Serial.begin(9600);
// Attach pin change interrupt service routines from the Wiegand RFID readers
attachInterrupt(0, reader1Zero, RISING);//DATA0 to pin 2
attachInterrupt(1, reader1One, RISING); //DATA1 to pin 3
delay(10);
// the interrupt in the Atmel processor misses out the first negitave pulse as the inputs are already high,
// so this gives a pulse to the reader input line to get the interrupts working properly.
// Then clear out the reader variables.
// The readers are open collector sitting normally at a one so this is OK
for(int i = 2; i<4; i++){
pinMode(i, OUTPUT);
digitalWrite(i, HIGH); // enable internal pull up causing a one
digitalWrite(i, LOW); // disable internal pull up causing zero and thus an interrupt
pinMode(i, INPUT);
delay(10);
// put the reader input variables to zero
reader1 = 0;
reader1Count = 0;
void loop() {
if(reader1Count >=26){
int serialNumber=(reader1 >> 1) & 0x3fff;
int siteCode= (reader1 >> 17) & 0x3ff;
Serial.print(" Reader 1:");
Serial.print(reader1,HEX);
Serial.print(" ");
Serial.print("Reader 1 converted to DEC:");
Serial.print(reader1& 0xfffffff);
Serial.print(" ");
Serial.print("siteCode:");
Serial.print(siteCode);
Serial.print(" ");
Serial.print("serial number:");
Serial.println(serialNumber);
reader1 = 0;
reader1Count = 0;
4.Open the Serial monitor and record the numbers that the serial monitor spits out when you wave your RFID card in front of the RFID antenna.
/* Modified from
* Crazy People
reader1Count++;
reader1 |= 1;
reader1Count++;
void setup()
Serial.begin(9600);
delay(10);
pinMode(i, OUTPUT);
pinMode(i, INPUT);
delay(10);
reader1 = 0;
reader1Count = 0;
void loop() {
Serial.print(" ");
Serial.print(" ");
Serial.print(" ");
reader1 = 0;
reader1Count = 0;
Step 3: Seeed and BlinkM
1. Connect the BlinkM d pin (the data pin) to the analog 4 of the Arduino.
2. Connect the BlinkM c pin (the clock pin) to analog 5 of the Arduino.
3. Connect the BlinkM to 5V and GND.
4. Download the BlinkM_funcs.h file-http://todbot.com/blinkm/example_code/BlinkMTester/BlinkM_funcs.h
5. Create a new sketch.
6. Create a new tab and name it BlinkM_funcs.h
7. Paste in the BlinkM_funcs.h code in the new tab
8. Paste the following code in the main sketch, compile and upload. The code allows the user to control the BlinkM with the RFID tags:
#include <Wire.h>
#include "BlinkM_funcs.h"
#define blue [your id tag # here]
#define red [your id tag # here]
#define green [your id tag # here]
long prevTime;
int card1;
int card2;
int count=0;
long dec;
int color;
byte r,g,b;
byte addr = 0x09;
reader1Count++;
reader1 |= 1;
reader1Count++;
void setup(){
BlinkM_beginWithPower();
Serial.begin(9600);
delay(10);
pinMode(i, OUTPUT);
pinMode(i, INPUT);
delay(10);
reader1 = 0;
reader1Count = 0;
void loop() {
readCard();
void readCard(){
if(count<2){
dec = (reader1& 0xfffffff);
if(count==0){
r=0;
b=0;
g=0;
Serial.print("dec=");
Serial.println(dec);
switch(dec){
case red:
r=255;
break;
case green:
g=255;
break;
case blue:
b=255;
break;
default:
color=0;
Serial.print("new tag");
displayColor();
reader1 = 0;
reader1Count = 0;
}else if(reader1Count == 0){
displayColor();
if(millis()-prevTime>2000){
count++;
prevTime=millis();
}else{
count=0;
void displayColor(){
BlinkM_fadeToRGB(addr,r,g,b);
Step 4: Seeed and Twitter
1. Cut out holes for the USB and Ethernet and maybe a hole for the power jack if you want to power the arduino that way.
2. Create a 2.5in by 2.5in by 2.5in box of velum with the 2.5in by 5in bottom open
3. Tape the vellum to the top of your box over the BlinkM and secure all the parts
4. Download the TrueRandom http://code.google.com/p/tinkerit/wiki/TrueRandom,
NewSoftSerial http://arduiniana.org/libraries/newsoftserial/,
and Twitter http://www.arduino.cc/playground/Code/TwitterLibrary libraries
5. Upload this code to your Arduino
#include <TrueRandom.h>
#include <SPI.h>
#include <avr/pgmspace.h>
#include <Wire.h>
#include <BlinkM_funcs.h>
#include <Client.h>
#include <Ethernet.h>
#include <Server.h>
#include <Udp.h>
#include <EthernetDNS.h>
#include <Twitter.h>
based on Kittty Twitty Cat Toy v1.0
by Marc de Vinck
Jan 6, 2010
KittyTwitty cat toy project found in MAKE, Volume 22
String (formerly TextString) Library by Tom Igoe
http://www.arduino.cc/en/Tutorial/TextString
// the push button
#define pushBtn 6
boolean printed=true;
int color;
#define blue 57337134
#define red 23773468
#define green 23805695
long prevTime;
int card1;
int card2;
int count=0;
long dec;
int r = 0;
int g = 0;
int b=0;
#define addr 0x09
// used to store the status of pin (6)
int var;
long randNum1;
long randNum2;
long randNum3;
long randNum4;
String dataString;
long prevtime = -30000;
// defining the network setting for the Ethernet Shield
// this can be made up
byte mac[] = {
0x1A, 0x6F, 0x99, 0xCD, 0xFF, 0xFF };
//get this from Settings, then change last byte
byte ip[] = {
10,0,1,197 };
//to get token: http://arduino-tweet.appspot.com/
Twitter twitter("[your_token_here]");
prog_char words1_0[] PROGMEM = "Red ";
prog_char words1_1[] PROGMEM = "Green ";
prog_char words1_2[] PROGMEM = "Blue ";
prog_char words1_3[] PROGMEM = "Yellow ";
prog_char words1_4[] PROGMEM = "Purple ";
prog_char words1_5[] PROGMEM = "Cyan ";
prog_char words1_6[] PROGMEM = "White ";
prog_char words2_0[] PROGMEM = "lights ";
prog_char words2_1[] PROGMEM = "arts ";
prog_char words2_2[] PROGMEM = "gases ";
prog_char words2_3[] PROGMEM = "circles ";
prog_char words2_4[] PROGMEM = "needles ";
prog_char words2_5[] PROGMEM = "doorknobs ";
prog_char words2_6[] PROGMEM = "sirens ";
prog_char words3_0[] PROGMEM = "sleep. ";
prog_char words3_1[] PROGMEM = "walk. ";
prog_char words3_2[] PROGMEM = "live. ";
prog_char words3_3[] PROGMEM = "exist. ";
prog_char words3_4[] PROGMEM = "perceive. ";
prog_char words3_5[] PROGMEM = "think. ";
prog_char words3_6[] PROGMEM = "see. ";
prog_char words4_0[] PROGMEM = "Cats are awesome.";
prog_char words4_1[] PROGMEM = "Quilts taste like gingerbread.";
prog_char words4_2[] PROGMEM = "Metal is highly interactive.";
prog_char words4_3[] PROGMEM = "Light is radiation.";
prog_char words4_4[] PROGMEM = "Sound is the wind.";
prog_char words4_5[] PROGMEM = "Clocks make a good bed.";
prog_char words4_6[] PROGMEM = "Glass is opaque.";
PROGMEM const char *words1_table[] ={
words1_0,
words1_1,
words1_2,
words1_3,
words1_4,
words1_5,
words1_6};
PROGMEM const char *words2_table[]={
words2_0,words2_1,words2_2,words2_3,words2_4,words2_5,words2_6};
PROGMEM const char *words3_table[]={
words3_0,words3_1,words3_2,words3_3,words3_4,words3_5,words3_6};
PROGMEM const char *words4_table[]={
words4_0,words4_1,words4_2,words4_3,words4_4,words4_5,words4_6};
char words1_buffer[7];
char words2_buffer[10];
char words3_buffer[10];
char words4_buffer[30];
reader1Count++;
reader1 |= 1;
reader1Count++;
void setup(){
// run this code once
//defining the btn as an input so we can read it
pinMode(pushBtn, INPUT);
// starts serial communications so you can debug easier
Serial.begin(9600);
//DATA0 to pin 2
//DATA1 to pin 3
pinMode(i, OUTPUT);
pinMode(i, INPUT);
reader1 = 0;
reader1Count = 0;
//begins the Ethernet connection from the stored information
Ethernet.begin(mac, ip);
connectToTwitter();
Serial.println("Waiting"); // print, used for debugging
void connectToTwitter(){
// print a blank line, used for debugging
Serial.println("Connecting to Twitter..."); // print, used for debugging
char testFN1[4]={int(random(4000,5000)) };
if (twitter.post(testFN1)) { // Twitter that we are up and running
int status = twitter.wait(&Serial); // wait for a response from twitter
if (status == 200) { // if Twitter responds 200
Serial.println("Tweet OK!"); // print success // print a blank line, used for debugging
}else {
Serial.print("Tweet failed : code ");
Serial.println(status); // print error code
connectToTwitter(); // print a blank line, used for debugging
}else {
Serial.println("connection failed.");
connectToTwitter();
void loop(){
// run over and over, never stop
readCard();
displayColor();
// check status of wire sensor
checkState();
void getString(){
//concatenates poem
dataString= strcpy_P(words1_buffer, (char*)pgm_read_word(&(words1_table[color])));
dataString=dataString+ strcpy_P(words2_buffer, (char*)pgm_read_word(&(words2_table[int(randNum2)])));
dataString=dataString+ strcpy_P(words3_buffer, (char*)pgm_read_word(&(words3_table[int(randNum3)])));
dataString=dataString+ strcpy_P(words4_buffer, (char*)pgm_read_word(&(words4_table[int(randNum4)])));
dataString=dataString+ " - 1000000000";
void tweet(){
// function tweet, this is called if status = 1
char filename[88];
dataString.toCharArray(filename, 88);
Serial.println(); // print a blank line, used for debugging
if (twitter.post(filename)) {
// tweet the completed datastring of words
Serial.print("Tweeting -- "); // print, used for debugging
Serial.println(dataString); // print, used for debugging
Serial.print(" -- Status: "); // print, used for debugging
int status = twitter.wait();
Serial.println("Successful!");
Serial.println();
}else {
Serial.print("Tweet failed : code "); // print error code
}else {
Serial.println("Connection to Twitter failed."); // print error code
void readCard(){
if(count<2){
if(count==0){
r=0;
b=0;
g=0;
switch(dec){
case red:
r=255;
break;
case green:
g=255;
break;
case blue:
b=255;
break;
default:
color=0;
reader1 = 0;
reader1Count = 0;
printed = false;
count++;
prevTime=millis();
}else{
count=0;
}//readCard()
void checkState(){ // check status of wire function
if(!printed){
doStuff();
printed=true;
if(r==255 && g==0 && b==0){
color=0;
} else if(r==0 && g==255 && b==0){
color=1;
} else if(r==0 && g==0 && b==255){
color=2;
}else if(r==255 && g==255 && b==0){
color=3;
} else if(r==255 && g==0 && b==255){
color=4;
} else if(r==0 && g==255 && b==255){
color=5;
} else if(r==255 && g==255 && b==255){
color=6;
void doStuff(){
randNum2 = random(7);
randNum3 = random(7);
randNum4 = random(7);
getString();
tweet();
5. Connect your Arduino to the ethernet
6. Test.
Step 5: Parallax Lamp
The Parallax Serial RFID Reader / Writer Module provides a low-cost solution to read and write passive RFID transponder tags up to 3 inches away. The RFID transponder tags provide a unique serial number and can store up to 116 bytes of user data, which can be password protected to allow only authorized access. The Parallax website suggests that the RFID Read/Write Module can be used for access control, user identification, robotics navigation, inventory tracking, payment systems, car immobilization, and manufacturing automation.
1. Wire SIN in digital pin 3.
2. Wire SOUT to digital pin 2.
3. Download the NewSoftSerial Library http://arduiniana.org/libraries/newsoftserial/
4. Upload the code to Arduino. This code will read the RFID cards:
#include <NewSoftSerial.h>
#define rxPin 2
#define txPin 3
byte r=0,g=0,b=0;
prog_char red[] PROGMEM = "2F00E69DFF";
prog_char green[] PROGMEM = "2F00E68BC6";
prog_char blue[] PROGMEM = "2F00E6C2D0";
PROGMEM const char *colorTags_table[] = {
red,green,blue};
char tags_buffer[12];
NewSoftSerial RFID = NewSoftSerial(rxPin,txPin);
void setup() {
Serial.begin(9600);
RFID.begin(9600);// RFID reader SOUT pin connected to Serial RX pin at 9600bps
void loop() {
sendRead();
readTag();
void sendRead() {
RFID.flush();
RFID.print("!RW");
RFID.print(0x0F, BYTE);
void readTag(){
byte code[12];
int bytesread = 0;
String msg;
while(bytesread<12){ // read 10 digit code
// this blocks and should ideally have a timeout
if( RFID.available()) {
code[bytesread] = RFID.read();
bytesread++;
if(bytesread == 12) {
if (code[0]==0x0A) {
Serial.print("TAG code is: ");
for(int i=1;i<11;i++){
msg = msg+code[i];
for(int i=0;i<3;i++){
strcpy_P(tags_buffer, (char*)pgm_read_word(&(colorTags_table[i])));
if(msg==tags_buffer) {
switch(i){
case 0:
Serial.println("red");
r=255;
break;
case 1:
g=255;
Serial.println("green");
break;
case 2:
b=255;
Serial.println("blue");
break;
#define rxPin 2
#define txPin 3
byte r=0,g=0,b=0;
red,green,blue};
void setup() {
Serial.begin(9600);
void loop() {
sendRead();
readTag();
void sendRead() {
RFID.flush();
RFID.print("!RW");
void readTag(){
byte code[12];
int bytesread = 0;
String msg;
bytesread++;
msg = msg+code[i];
switch(i){
case 0:
r=255;
break;
case 1:
g=255;
break;
case 2:
b=255;
break;
Step 6: Parallax and BlinkM
1. Connect the BlinkM d (data pin) to the analog 4 of the Arduino.
2. Connect the BlinkM c (clock pin) to analog 5 of the Arduino.
8. Paste the following code in the main sketch, compile and upload. The code allows the user to control the BlinkM with the RFID tags. This code controls the BlinkM while the RFID is not available. If you don't account for this period, the BlinkM will cycle through the colors rather than display the last color selected. Calling fadeToRGB when RFID is not available fixes this issue:
#include <Wire.h>
#define rxPin 2
#define txPin 3
byte r=0,g=0,b=0;
int blinkm_addr = 0x09;
int count=0;
long pt;
prog_char red[] PROGMEM = "[your RFID tag number]";
prog_char green[] PROGMEM = "[your RFID tag number]";
prog_char blue[] PROGMEM = "[your RFID tag number]";
red,green,blue};
void setup() {
Serial.begin(9600);
BlinkM_begin();
BlinkM_setRGB(blinkm_addr, 0, 0,0);
void loop() {
BlinkM_setRGB(blinkm_addr,r,g,b);
sendRead();
readTag();
void sendRead() {
RFID.flush();
RFID.print("!RW");
void readTag(){
if(count<2){
byte code[12];
int bytesread = 0;
String msg;
bytesread++;
}else{
//this fixed the problem
BlinkM_fadeToRGB(blinkm_addr, r, g, b);//call which fades to desired color
// Serial.print(code[i], HEX);
msg = msg+code[i];
Serial.println(msg);
if(count==0){
r=0;
b=0;
g=0;
switch(i){
case 0:
r=255;
break;
case 1:
g=255;
break;
case 2:
b=255;
break;
} //end for loop
}//end code[0]==0x0A
}//end bytesread == 12
displayColor();
if(millis()-pt>1500){
count++;
pt=millis();
}//end if count
else{
count=0;
BlinkM_fadeToRGB(blinkm_addr, r, g,b);
#include <Wire.h>
#define rxPin 2
#define txPin 3
byte r=0,g=0,b=0;
int count=0;
long pt;
red,green,blue};
void setup() {
Serial.begin(9600);
BlinkM_begin();
void loop() {
sendRead();
readTag();
void sendRead() {
RFID.flush();
RFID.print("!RW");
void readTag(){
if(count<2){
byte code[12];
int bytesread = 0;
String msg;
bytesread++;
}else{
msg = msg+code[i];
if(count==0){
r=0;
b=0;
g=0;
switch(i){
case 0:
r=255;
break;
case 1:
g=255;
break;
case 2:
b=255;
break;
} //end for loop
displayColor();
count++;
pt=millis();
}//end if count
else{
count=0;
Step 7: Parallax and Twitter
1. Get a token to post a message using OAuth. http://arduino-tweet.appspot.com
2. To configure the network information in the code,start by looking at your computer’s network settings. On the Mac, go to System Preferences/Network, then click the Advanced button and select the TCP/IP tab.
3.For the code’s free IP address, you can usually just take your network setting and increase the last number a little bit.If your IP address was: 192.168.1.2, you could try 192.168.2.12
4. Download the Twitter Library http://www.arduino.cc/playground/Code/TwitterLibrary
5. Create a new sketch. Paste in this code. make the necessary modifications:
#include <Wire.h>
#define rxPin 2
#define txPin 3
byte r=0,g=0,b=0;
int count=0;
long pt;
prog_char green[] PROGMEM = "your RFID tag number]";
prog_char blue[] PROGMEM = "your RFID tag number]";
red,green,blue};
boolean ctt=false;
char testFN[80];
// modify the last two bytes-it can be anything
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFF, 0xFF };
//modify the last number so the ip is unique
byte ip[] = { 10,0,1,29 };
Twitter twitter("[your token here]");
String poem;
int color=7;
int lastColor=7;
long randNum2;
long randNum3;
long randNum4;
////poem
prog_char words1_3[] PROGMEM = "Magenta ";
prog_char words1_4[] PROGMEM = "Cyan ";
prog_char words1_5[] PROGMEM = "Yellow ";
prog_char words2_0[] PROGMEM = "clouds ";
prog_char words2_1[] PROGMEM = "seals ";
prog_char words2_2[] PROGMEM = "skyscrapers ";
prog_char words3_0[] PROGMEM = "lives. ";
prog_char words3_1[] PROGMEM = "fly. ";
prog_char words3_2[] PROGMEM = "sleep. ";
prog_char words3_3[] PROGMEM = "surround. ";
prog_char words3_4[] PROGMEM = "implode. ";
prog_char words4_0[] PROGMEM = "Pigs will fly but men will not.";
prog_char words4_1[] PROGMEM = "The red rose smashes into oblivion.";
prog_char words4_2[] PROGMEM = "Legends live but heros die.";
prog_char words4_3[] PROGMEM = "Small talk is large in the language of life.";
PROGMEM const char *words1_table[] = {
words1_0,
words1_1,
words1_2,
words1_3,
words1_4,
words1_5,
words1_6 };
PROGMEM const char *words2_table[] ={
words2_0,
words2_1,
words2_2
PROGMEM const char *words3_table[] ={
words3_0,
words3_1,
words3_2,
words3_3,
words3_4
PROGMEM const char *words4_table[] = {
words4_0,
words4_1,
words4_2,
words4_3 };
char word1_buffer[8];
char word2_buffer[12];
char word3_buffer[10];
char word4_buffer[44];
void setup() {
Serial.begin(9600);
BlinkM_begin();
BlinkM_setRGB(blinkm_addr, 0, 0, 0);//call which fades to desired color
lastColor=7;
Ethernet.begin(mac, ip); //begins the Ethernet connection
delay(1000);
connectToTwitter();
if(ctt){
Serial.println("start everything");
void connectToTwitter(){ // print a blank line, used for debugging
char testFN1[4]={int(random(1000,2000)) };
ctt=true;
}else {
}else {
connectToTwitter();
void loop() {
sendRead();
readTag();
void sendRead() {
RFID.flush();
RFID.print("!RW");
void readTag(){
if(count<2){
byte code[12];
int bytesread = 0;
String msg;
bytesread++;
else{
msg = msg+code[i];
if(count==0){
r=0;
b=0;
g=0;
switch(i){
case 0:
r=255;
break;
case 1:
g=255;
break;
case 2:
b=255;
break;
} //end for loop
displayColor();
count++;
pt=millis();
}//end if count
else{
count=0;
void getString(){
//concatenates poem
poem=strcpy_P(word1_buffer, (char*)pgm_read_word(&(words1_table[color])));
poem=poem+strcpy_P(word2_buffer, (char*)pgm_read_word(&(words2_table[randNum2])));
poem=poem+strcpy_P(word3_buffer, (char*)pgm_read_word(&(words3_table[randNum3])));
poem=poem+strcpy_P(word4_buffer, (char*)pgm_read_word(&(words4_table[randNum4])));
poem=poem+"-Lukas";
void getPoem(){
randNum2 = random(3);
randNum3 = random(5);
randNum4 = random(4);
getString();
tweet(poem);
lastColor=color;
color=0;
color=1;
color=2;
color=3;
color=4;
color=5;
color=6;
else if(r==0 && g==0 && b==0){
color=7;
if(color!=lastColor){
getPoem();
void tweet(String poem){
poem.toCharArray(testFN, 80);
Serial.println(poem);
//---------------- for twitter --------------
if (twitter.post(testFN)) { // tweet the completed datastring of words
Serial.println();
else {
else {
delay(500);
tweet(poem);
//digitalWrite(statusPin, LOW); // sets the status LED off
Serial.println("ready"); // print, used for debugging
5. Plug in the power supply and Ethernet cable, and flip the switch. The power LED should come on, and in a few seconds, the network status LED, too. The code tweets an "Up and Running" message to let you know everything is OK. You can plug a USB cable into the Arduino and listen in on the serial port for some debugging.
Step 8: Making the Diffusor
1. First you need to grab a tube
2. Next you need to cut off a length from the end of the tube (I cut a 3in portion)
3. Drill some holes on the side of the tube
4. Cut out a circle of velum that will fit on top of your tube
5. Using a hole puncher make some holes in the velum you cut out
6. Attach the velum to the top of your tube (tape is good)
7. Secure the tube to the box on top over the BlinkM
