Introduction: Two Servo and Drawer Slide Pen Plotter
Built this primitive 2d pen plotter using two standard servos (plus one microservo for pen) and 3 drawer slides. Software is DrawingBotV3 to create gcode which is sent to Arduino Uno via Python script. Simple and draws crude prints but perfect for artwork. Uses polynomial functions for x and y to translate servo angles into linear positions.
Why build this plotter when you can buy a DIY plotter kit for $60 that prints very accurately? For two reasons: I want a printer that makes hand drawn looking prints though I am probably just rationalizing a bit. Two, it really teaches you the whole process from creation of jpeg, to Gcode, to serial communication, to Gcode interpretation, to line drawing algorithms, and a short intro to polynomials. What an education.
The still-life is a plot of a painting by Cathleen Rehfeld which I then painted with acrylics. Took just a few minutes to paint.
(2) standard size servos, I used cheap analog servos at first but finally settled on TD8130MG digital servos (also cheap)
1 micro servo
(3) drawer slides - mine slide out about 10cm but wish I had gone with longer ones. Use longer than you want the drawing area so that servos have some slack area.
Arduino Uno
Sensor shield for easily plugging in servos
6 volt regulated power supply to easily run servos
various brackets and dodads for servo linkage
a bamboo cutting board to mount the slides on
Step 1: Mount Slides on Board
I mounted two of the slides about 8cm apart on the edge of a cutting board,
Then I screwed one more slide onto a piece of 1x4 inch board about 24cm long
Then I screwed this board to the sliding rails.
Step 2: Make Pen Holder
Cut a slot in 3mm plywood board and epoxied a fishing tube section to hold the pen.
Mounted the board onto a second 3mm plywood board with a small hinge.
Mounted the board to the sliding rail.
Mounted a servo to operate the pen lift mechansim.
Note, gravity is a great force to use to keep the pen in contact with the paper. A stiffer solution will just end up tearing the paper.
Step 3: Mount Servos and Linkage
I used a servo mounting bracket to mount one servo to the cutting board. Then made a servo arm out of wood and a fishing tube. I used 3mm threaded bolt with horns and attached the servo arm to a bracket on one of the slides. The threaded arm is 16cm long, the servo arm is attached at 9.5 cm from the servo shaft.
I mounted the second servo on the 1x4 wood, made a servo arm, and connected the linkage in the same way with the same dimensions. Note: servos must be mounted in the same direction as the photo or the printer will not print in an X,Y horizontal/vertical orientation.
Counterweights: this is optional but recommended. I built a couple of pulleys so that I could hang some weights off the servo linkage to reduce the amount of servo gear lash. Watch the video for details.
Step 4: Connect Electronics
I used a sensor shield for easily connecting the servos to the Arduino. Unfortunately I only had a 6 volt power supply which is too much for an external supply for the shield so I bent the sensor shielc 5 volt pin out of the way and connected the sensor shield to the Uno. This means the 6 volt external power supply will only feed the servos and not the Uno. The uno must have its own power supply.
Connect the horizontal servo(X axis) to pin 9 and the vertical (Yaxis) to on 10.
Connect the 6 volt power supply to the sensor shield.
Connect the micro servo to pin 5.
Step 5: Software
I use DrawingBotV3 to convert a jpeg photo to Gcode.
Use Python IDLE Gui to run a script that reads the Gcode file and sends it via serial to an Arduino Uno.
Use Arduino sketch to read the Gcode from the Python script and execute a line drawing function.
Code below.
1. DrawingBotV3 download: https://github.com/SonarSonic/DrawingBotV3
2. Python download: https://www.python.org/downloads/
3. Python script to read Gcode file produced by DrawingBotV3:https://wordpress.com/post/demej00.wordpress.com/2525
ARDUINO CODE
4. VarSpeedServo library: https://github.com/netlabtoolkit/VarSpeedServo
5. Arduino Calibration routine for servos: https://wordpress.com/post/demej00.wordpress.com/2521
6. Arduino Gcode interpreter: https://wordpress.com/post/demej00.wordpress.com/2528
Step 6: Calibrate Servos
The only time consuming job that must be done before the plotter is usable is to calibrate the servos.
Run the calibrate print program that will print a
Step 7: Some Artwork
I download interesting images from the internet into DrawingBotV3.
I like to plot a print and then use a brush and water to smear the ink around in a wash. Or I can add acrylics which has a nice effect on smooth printer paper.
The last plot is my favorite so far. If you squint your eyes you can probably tell who it is.
