Introduction: Two-Toned Tie Dye Socks
About: I'm a lifetime crafter here to share my love of all things crafts and DIYs. I have a crafting blog (https://www.abcrafty.com) and YouTube channel (youtube.com/abcrafty)
Update your wardrobe with these fun red and blue tie dye socks. They're super easy to make and the two-tone look is a fun and unique tie dye pattern.
  1. Tie Dye Kit (this is the one I used, which you can get for 20% off with code ABCRAFTY)
  2. Soda Ash
  3. White Cotton Socks
  4. Rubber Bands
  5. Plastic Bin
  6. Plastic Wrap
Some of these links may be affiliate links, which means AB Crafty may earn a commission if you purchase.
Step 1: Soak
Soak the socks in water and ring them out so they're wet, but not dripping.
Step 2: Fold and Wrap
Fold the socks from the toe to heel in an accordion fold. (The photo shows the accordion fold, but in the opposite direction)
Then add rubber bands to secure it.
Make sure you do the same number of folds and place the rubber bands in the same place on both socks.
Step 3: Mix Soda Ash
If your kit comes with soda ash, mix it up by combining 1 cup soda ash with 1 gallon warm water. Stir it until it's all dissolved.
Then soak the socks for 20 minutes.
Step 4: Mix Dyes
Fill the dye bottles to the line with warm water. Shake them so the dye is completely dissolved.
This is the kit I used
Step 5: Add First Color
Place a piece of plastic wrap on the table and put the socks on top.
Add your first color to half of the socks. Be sure to flip them over to get both sides.
Step 6: Add Second Color
Add the second color on top. Be sure to get between the folds so there is enough dye.
Step 7: Wrap and Set
Wrap the socks in the plastic wrap and let them set for at least 12 hours. I like to leave them for a full 24 hours to make sure the dye sets properly.
Step 8: Rinse and Wash
Rinse off the socks and remove the rubber bands. Rinse until the water runs clear. Then run it through the washer and dryer.
Then your two-toned socks are complete!
