Introduction: Two Axis Solar Tracking System Using Msp430
Hi guys. I want to show you my solar tracking system project. The system can move along two different axis. I used 4 LDR light sensor for sensing light and 2 servo motor for giving positions according to values read from sensor. 4 sensor are grouped as 2 sensor couple. The analog signals taken from LDR sensors are converted to digital signal with using MSP430G2553. Each sensor couple values are compared independently and give direction one servo motor.
Step 1:
This is my solar tracking system circuit diagram. I used Proteus circuit development program. In this program there is no MSP430G series library. Because of this , I used another MSP430 circuit diagram for showing circuit connections. But I used MSP430G2553 in my project
11 Comments
5 years ago
I am also having errors and I have no idea how to rectify it
Reply 5 years ago
Also I am using ccsv7
5 years ago
what is name of microcontroller that you use in proteus?
6 years ago
code for the same project using MSP430F5529 does anyone know please upload
8 years ago on Introduction
I try to fixed the problem about code. You can use ''dual axis servo solar tracking_v2''
This is the error that i am getting
the code, when built on CCS shows the errors:
1) Expected a declaration
2) This kind of pragma may not be used here.
Pls suggest changes to the code, Thanks
When I had design this code , I had used CCS v5. These errors may cause because of this. Now , I tried working the code in CCS v6 and I am faced with similar mistakes. After I will fix these problem , I will give feedbacks
did you try rectifying the errors ?..i a m having the same problem
very goood man very good
thank you my friend :D
