Introduction: ULTIMATE GUIDE TO BLOOKET FACTORY :D
If your just soo noob at blooket factory mode like micak, then don't worry i will help you today. Unless your micak. >:D
Step 1: Start the Game.
This is the easiest step all you need to do is make a solo game and then click factory-
Step 2: Begin Your Game
recommendation: Set time to 25 mins. When you start the game, make sure that you know what rate per second(rps) is. If you don't this means how much you will be making in a second. At first this doesn't matter much. So what you should do is make all your blook spots full. After this you will be introduced to diffrent types of blooks. Make sure you ONLY take the wonderland blooks(little castle on the bottom right). (ex. king of hearts, queen of hearts, caterpellar) These make the most money.
Step 3: Knowing Who Makes the Most Money $$$$$
So now that you know what rps(probably should be mps) is, you now can figure out who makes the most money. Ok so first of all, im just going to say that the king of hearts makes the most money. Please dont mix this up with king. the medieval box makes less money but more money than the commons. So when you first start, get as many wonderland blooks as you can and upgrade them. Doing this will make you temporary money. As you start to get more, try to switch to only king of hearts, queen of hearts, and the caterpillar. These make the most money, once you get to those try to switch to ONLY king of hearts and caterpillar. Even though the queen of hearts makes 'more' money it actually doesn't. The rps is a small amount. When you have x5.5 on it it looks like it has the same amount and you can clearly see that the queen of hearts needs 3 seconds when the catepillar only need 1. So the catepillar makes more money. When you get more cards, try this challenge. Get all blooks to be king of hearts only. King of hearts makes 8.3B with the x5.5 and takes 5 seconds to make. But if you do the math this is the most money making blook.
Step 4: Types of Blooks in Factory Mode.
Factory mode has common, medival box, wonderland box. (most money making: wonderland)
Dont mix up the king with king of hearts. this king makes little money if you considered how much money i made.
Step 5: Results!!!
These are my results i got from using these steps. Just so you know i made all the answers correct so that i could get more tokens and i got the 3x token. So i got only 100 but with the x3 i got 300. Total money was about 16T :0
I know its a lot of $$ :D
