Introduction: UP: Carl the Old Man Costume
This is the main character Carl from the kids movie UP. Its cheap and easy to make plus its a costume most people know that also stands out in a crowd.
Step 1: Materials
For materials I used a box, paper mache, faux fur (hair), paint, paint sticks (frame for glasses), electrical tape, chicken wire, wire cutters, masking tape, wiffel balls (eyes), wood glue, and went to a thrift store for the outfit.
Step 2: Foundation
To start I found a box big enough to fit over my head and rest on my shoulders. A box works well because the basic shape of Carls head is square. I covered the sides and top with chicken wire leaving a round edge for Carls big chin. Chicken wire works well because it is easy to shape and mold plus its strong. Then I covered everything in masking tape because the paper mache wont stick to the wire but works well with the tape. leave a hole for the nose, ears, and a ridge across his face for the eye brows. Be careful when cutting the chicken wire, sharp edges can form and may prick you.
Step 3: Ears
I molded the ears out of chicken wire and attached them to the sides of the head. To attach them I just spun the excess wire around the wire on the side of the head like bread ties. Cover it in masking tape.
Step 4: Nose
just like the ears, I made the nose out of chicken wire and attached it to the wire around the box where his nose should be. I spun the excess wire around the cage like bread ties again. The nose should be oval and once its attached just squash it down a little bit. Then cover it in masking tape.
Step 5: Details
I drew out where his eyes and wrinkles should be using a pen. For the wrinkles and eye brow ridge I took strips of masking tape and rolled them up into cords with the sticky side facing outside. Then I placed them on the wrinkle lines and eye brow ridge to give the details some depth.
Step 6: Eyes and Paper Mache
I cut a wiffel ball in half and used it as the eyes. I used masking tape to hold it in place and to give Carl some eyelids. I also used more tape to create more depth in the cheeks and wrinkles. The next step is paper mache. For this step I used a mixture of 25% wood glue, 25% flour, and 50% water. I also used strips of paper towel because its stronger and easier to fit in the detailed areas than newspaper is. Let this step dry for about a day and a half then you may need to apply another layer. I only used one layer because I had 3 days until Halloween. Also, be careful cutting the wiffel ball, due to the shape of it and the fact you are using a knife/scissors its dangerous.
Step 7: Paint
The paper mache was dry in about a day and a half. I also placed a window fan on Carl to speed up the dry time. Next, I painted Carls head with acrylic paint. I used a color called "Santas Flesh" for the face and "Cocoa Gold" for his hearing aids. I used blue nail polish for his eyes and a black permanent marker for his pupils and mouth.
Step 8: Hot Glue His Hair
Next, once dry, I measured his head and applied the hair (faux fur) accordingly. I applied the hair to his head using a high temp hot glue gun. The gun is extremely hot and can cause bad burns so you should use caution with this step. Next, I painted the wiffel balls and cut out a 2 inch gap between his eyes and under his eyebrows. This gap is for my vision when wearing the costume. Dont cut the hole too big yet because Carl wears glass and the hole me be blocked be the frames of the glasses.
Step 9: Glasses and Eye Brows
When buying the paint I also asked if I could take a bunch of free paint sticks which happened to be the perfect width for Carl's glasses. I broke up some to make the boxes and used whole paint sticks for the long part of the frames that attach to his ears. I then covered the frames in black electrical tape. Electrical tape works well not only because its black but its shiny. Then I used the scraps of my faux fur (hair) to make the bushy eye brows and I attached them using the hot glue gun again. Lastly you can now make the eyesight hole as big as you need to see.
Step 10: Safety
The parts you need to use caution on while making this costume are with the hot glue gun and cutting the chicken wire/ wiffel ball. When you cut the wire it leaves sharp edges so make sure you bend them in a way that they do not stick out or can poke you, especially ones that may penetrate the box and stick you while wearing it. Check carefully, you can cover these edges on the inside with duct tape.
Thanks for reading, maybe next year I can find a Russel, make Kevin (the big bird), and dog sit my friends golden retriever for the day.
