Introduction: USB 5 Volt Charger
About: I am a nerd. I enjoy building robots, programming, and 3D printing/designing. I am on a FIRST Tech Challenge team, team 4433 Smokin' Motors from Pennsylvania. We won 4 out of 7 competitions within the past …
Hello instructables surfers! this is my first instructable, so bear with me. also, i made this charger before i made the instructable.
REQUIREMENTS:
must have skills in:
soldering
hot glueing
Legoing
parts:
Legos
motorized lego robot power pack
4 RECHARGEABLE batteries
USB socket
Lets get started
Step 1: Gather Parts
you will need rechargeable batteries, the power pack, and legos
Step 2: Solder
you can solder two wires going from positive to negative in both battery slots
Step 3: Put Together Legos
1. build this
2. build both
3-4. build this, the both are the same, just flipped over
5. put step 3 & 4 under step 1
6. all parts put together
7. final lego housing
Step 4: Put Together Everything
refer to steps 2, 3, and 4 in Easy rechargable portable ipod/USB Recharger  to get the proper usb socket wiring.  also make sure the wire socket lego brick is put on the terminal correctly.
Thanks for reading this, and good luck on building it.  now, you can make a charger from anything, but I just chose this because I never play with my lego robot monkey anyway.
