Introduction: USB Barbie
It was just another day at the beach for Barbie and friends. The sun was shining and Ken had even decided that he was feeling rather generous to let Barbie out of the house following last week's fiasco.
That was when things went horribly, horribly wrong.
Barbie was never the same again...
Okay, so this is my very first instructable, so please be gentle.
This is my rendition of a USB Barbie that I first saw on the internet several years ago. After tireless searching and vain ambition I was unable to find a decent how-to article on this particular mod. Not many drives compare to the hilarity and shock generated by this. If, like me, you enjoy the odd and oh-so macabre then this instructable is for you! Enjoy and happy making!
Step 1: Materials and Tools (Barbie)
Alright, so you wanna get inside Barbie and fill her delicious innards with the power of USBl? This is what you will need:
X-acto knife
Dremel with cutting or sanding heads
Silicone
Caulk Gun for silicone
Screwdriver (or similar for prying)
C-clamp
Rubber bands
Barbie
Barbie Clothes (optional)
Stationary USB drive (no buttons, no moving parts, ect)
Step 2: Barbie's Autopsy Adventure
Alright guys, (and gals) lets get to it. That's right it is time to live out your Barbie mutilation fantasy, and this time your little sister won't come running in just as you rend Barbie's head from her body. Like a stockpile of booze at a college party it all has to go...
There are of course many ways to disassemble a perfectly functioning Barbie doll. I prefer the macabre, old fashioned method of brute force, however, this will determine the final quality of the doll.
The Method used here was head and legs off, body cracked and/or pried open. Do what works best for you, and just keep trying to open the body without causing any damage. Try to keep the posts (see picture 3) intact if you can as it will make later steps a lot easier.
Here are a couple of pictures for you.
Step 3: USB Dismantling
Pretty self-explanatory, every drive is different, the one featured here was easily and simply pried apart. I can't possibly speak for every drive, just do your best! (Or worst)
Step 4: Barbie's Liposuction Reduction
High speed rotary tool in hand, we must now whip Barbie's body into shape. Start by cutting off small sections of her neck on both sections of the body to fit the metal portion of the drive comfortably. Once your drive fits into the body, you must figure out how deep the drive needs to go to work properly in a computer. To facilitate this, you can use my method. Plug in the drive** and place the bottom half of the body over it. Make sure that the bottom half is level with the computer and mark off where the drive ends. See pictures if you are confused here.
Legal Disclaimer:
**Exercise caution here, there are dangerous currents flowing through the computer. This method could produce a shock which could be harmful or fatal, therefore, it is not recommended. You have been warned, I take no liability or responsibility for your actions. Proceed at your own risk.**
Step 5: Barbie's Silicone Fantasy
"California Beach Barbie got free silicone from her father last week..."
So now that your drive has been fitted to Barbie's body it is time to stick it to her. Place a light layer of silicone from her neck to your line and press your drive into it. Cover the entire region in another layer of silicone and smooth out with a stick/finger/screwdriver or similar and let dry as per the directions on the tube. See the picture to get an idea of what we are going for here, it doesn't have to be much just enough to cover your drive.
Once the silicone is nice and dry, be sure to test it to make sure it will stay put. It should be firmly attached to the body. If not, pull off the silicone and try again making your layers thicker. If, as a last resort you just can't get it to stay go for the King Kong approach and use JB Weld.
Step 6: Barbie Trys to Pull Herself Together
After you are fairly certain that Barbie's new high tech appendage is secure, we must begin to pull her back together. There are many ways to do this, I choose the overkill method. Here is what worked for me:
First, I replaced the arms and leg holder as they had been originally placed. Then using the posts I managed to salvage back in step 2 and the empty body cavity I covered everything in the bottom half with silicone. Next, I made a line of silicone along the lines of the body and pinched the halves together.
To help hold the body in place long enough to dry, I placed rubber bands in areas of concern i.e. chest, belly and crotch. Fearing and in some cases noticing that this still wasn't enough I finally clamped the body to my table and put a lot of weight on it. If you broke some section of the body, now is a good time to repair it with silicone. Don't worry about bad looking edges, they will get covered up later.
Step 7: Barbie Tests the Limits
Once everything has had enough time to dry begin to remove your holds carefully. Be sure to check that the problem areas have adhered. If they haven't go back and try again, and consider the JB Weld option. Slowly remove your rubber bands and gently squeeze Barbie to test her body. More importantly, make sure that she holds together when plugged into a computer. If she holds, dress her on up! To cover your drive, just shove her head onto it.
Step 8: Barbie, USB, and the Best Stares You Will Ever Get
So that's it! I hope you enjoyed reading this instructable as much as I have writing it and that you are able to create your very own USB Barbie. If you have suggestions/questions about this project or any insights into the next round of childhood icon mutilation, shoot me a line! Feel free to upload your USB Barbie related stories/pictures to the comments section. Today, we leave you with a few pictures of Barbie, doing what she does best and some ideas on what to do with her!
Put pictures of your obese relatives on her.
Store your collection of childhood music.
Take her to a Barbie convention.
Use her as a podslurper (Found on this site)
Make her store your "questionable material." She has an open mind.
Install DBAN to make her into a hard drive murdering witch!
Threaten your siblings that all their toys will wind up like this if they don't do as you command.
Use her as a "normal" thumb drive.
88 Comments
12 years ago on Introduction
If you used Ken it might have been NSFI (not safe for Instructables).
Reply 12 years ago on Introduction
I'm thinking of creating a USB dock. With ken bent over.
Reply 2 months ago
ahahahahahahahehehehehe
use nail polish remover to remove the painted on underwear hahahahahahahhahahaha
holy crap I'm dying
Lol, stick it to the man! Awesome!
AH HAHAHAHA Best use for a Barbie ever!!
Admit it, you just wanted to rip Barbies head off and find a use for her Body... Shame you can't do that to EVERY plastic Bimbo out there ehehehe
Great work buddy... LOVE it!
LOLOLOLOLOL!
You know... Since when i was a little Girl Cindy used to try and keep up with Barbie..... I wonder if someone will post a reply to this instructable and make a Cindy complient USB flash drive...
THE DOLL WARS HAVE BEGUN
Reply 2 months ago
I have 2 Cindy dolls and a Cindy baby...
AHAHAHAHAHAHAHAHHAHA
THIS OUGHT TO BE GOOD
3 months ago
WHY ARE WE BRINGING KITTENS INTO THIS
11 years ago on Introduction
How big is the barbie? I've been thinking of doing this with a batman :D
Reply 3 months ago
the question is: does Batman deserve that much humiliation? (I THINK HE DOES)
6 years ago
This has shades of the Kip Kay Barbie-Cam hack!!
https://youtu.be/oEH5pMylo3Q
Reply 5 years ago
Yeah, that's really cool. xD
Reply 6 years ago
Outstanding hack!!!! And perfect for the Halloween Season!
6 years ago
this is so awesome. Serves barbie right for being so rudely dressed! :D
11 years ago on Step 8
I've been half tempted to do something like this for some time. Although it would be kinda weird to do it with a barbie... Any idea what else I could use?
A Sock.(Maybe)
Reply 11 years ago on Introduction
Okay wow, that picture is awesome! I could see that being awkward on a barbie, but actually pretty funny! How about a Teddy Bear or a similar cute and unsuspecting stuffed buddy? It would be kinda funny to simulate the chest burster from Alien. I look forward to seeing where you go with your idea!
Well.... I was trying to keep in the picture's theme. The trick is to keep it cool and guy approved, without sliding into creepyville. I have a 4G stick, and it shouldn't be hard to solder a old USB mouse wire to that. The trick is the vic- recipient of the upgrades.
11 years ago on Step 4
Maybe you should add a recommendation to turn off the Computer and Un-plug it from the power supply.
