Introduction: USB Blinky
My projects typically involve many LEDs and microcontrollers. However sometimes I just love the simplest of things with LEDs.
One of the very basic LED circuits is a blinky using astable multivibrator. This is the circuit that I've made - with hand drawn and etched PCB and with incandescent lamps - when I was in high school for a PCB making contest and won. I guess it still has sentimental value for me.
Now with LEDs instead of incandescent lamps, and USB power instead of batteries, here's the USB Blinkly.
I integrated the USB plug into the PCB, so it's simpler as well as economical. You can plug USB Blinky into any USB receptacles - computers, chargers, everywhere.
Step 1: Circuit
The circuit is an ubiquitous astable multivibrator. I used NPN type transistors and used the super-bright LESs. As the values shown in the schematics, the blinking rate is about 2 times/second. You can adjust the R2,3 and C1,2 to achieve different speed. Larger the values, the slower the speed. I recommend keeping the values of R2 and R3 between 1k and 47k ohm. At larger resistance transistors do not get enough bias current to fully turn on the LEDs. At smaller resistance than 1k ohm, too much bias current flow into the transistors. Capacitors can be as small as 1uF (very fast blink, more like flicker), or as large as 1000uF (super slow).
Current draw from the USB port is slightly under 5mA.
Step 2: PCB
I made "built-in" USB plug right on the PCB. In order to fit nicely into USB ports, I used thicker (2mm) material for the PCB. This seems to work quite well, snug enough to give good electric connection, but not too tight.
However if you find your USB Blinky to be too lose in the connector, you can put some solder on the backside of the USB plug - there are two strips of pad that you can coat with solder. By putting a good amount of solder there you can adjust the fit of the USB plug.
Step 3: Parts
- 2x 5mm Super Bright LED
- 2x 470 ohm 1/8 or 1/4W (R1, R4) (yellow-purple-brown-gold)
- 2x 47k ohm 1/8 or 1/4W (R2, R3) (yellow-purple-orange-gold)
- 2x 22uF 10V or higher Electrolytic Capacitor (C1, C2)
- 2x NPN General Purpose Transistor (Q1, Q2)
- 1x Custom PCB
If you are using "standard" type LEDs (non "super bright"), you might want to give them more current to get the decent brightness. Use 220 or even 150 ohm for R1 and R4 (up to 20mA with 150 ohm).
Dig into your parts drawers or junk box. You might have all the parts you need (except maybe the PCB). Of course you can purchase the PCB or full kit from my site.
Step 4: Assembly
However if you are completely new to soldering, you might want to do a bit of practice before assembling USB Blinky.
Start soldering the low profile pars first - try soldering in this order:
- Resistors - Bend the leads, insert them into the holes on the PCB, flip the PCB over, and solder.
- Capacitors - bend the lead at the bottom of the body, watching the polarity. Longer lead is the positive (+).
- Transistors - match the shape of them with the marking on the PCB. Bend the leads to fit the holes. Solder.
- LEDs - watch the polarity again. Longer lead goes into the hole with the square pad. You can also use the shape of LEDs and the marking on the PCB to identify the orientation. (One side of LED is flat)
Step 5: Plug It In!
Pick your favorite color LEDs and make one. Happy blinking!
1 Person Made This Project!
- rumgunner made it!
25 Comments
8 years ago on Introduction
USB Blinky kits are now available at The Maker Shed.
http://www.makershed.com/USB_Blinky_Green_p/mkla2.htm
Thanks!
8 months ago
its a USB-linky
3 years ago
Very cool one, I made it on a perfboard and it works like a charm and is very nice ;)
4 years ago
Hi i am a student in the rgv and we might use this as a tester to see if a full size solar car that we are making that will go from fort worth to minnesota and this may determine if the car is getting power
4 years ago
4 years ago
4 years ago
it blinks on and off
5 years ago on Introduction
It's a coolest useless gadget I have ever seen :D Nice work!
6 years ago
I made it
6 years ago on Introduction
I made this circuit, but used 10k Ohm and 100 Ohm resistors for brighter LEDs. Great 'ible!
EPIC!!!!
I was able to make this using an LDR. its very cool. so it runs on a 9v and turns on in the dark. I put a on/off switch as well so I don't kill the battery and when I really don't want it on.
6 years ago
Could this be made with an ldr??? If so how
Well made project and instructable. Nice work!
Thanks!
Can we use a 9v battery?
7 years ago
Awsome!
congratulations, so simple and nice idea!!
Thanks!
this reminds me from my first electronic project... :D
