Introduction: USB C Handheld Arcade
Multi-form factor arcade with USB only connection from portable device.
Using only a SINGLE USB C cable to a gaming handheld you can unlock the power of a multi-form factor arcade below. The USB C Connection will handle power and display output from the handheld as well as adding all the additional gaming inputs.
PowerA Wired Controller for Xbox Series X|S supplies
HDMI Audio Extractor Splitter 4K hdmi to hdmi 3.5mm Audio Adapter Converter supplies
EG STARTS 2 Player Arcade Contest DIY Kits USB Encoder To PC Joystick supplies
Gaming Mouse and Keyboard supplies
Sinden Red Arcade Light Gun supplies
43" SMART TV/Monitor supplies
5" Speakers supplies
PXN PC Racing Steering Wheel supplies
USB 10 Port HUB supplies
Power Strip supplies
USB C to HDMI Adapter,with 4K HDMI Output USB 3.0 Port & USB-C Fasting Charging
Step 1: Build
Build black painted shelving to contain the arcade against the wall.
Drill holes in the main board that will sit like a square on top of the main desk that contains the buttons, this will also hide the wiring that connects all the USB devices below the desk.
Using the EG Starts guide you can properly space the holes to drill.
Underneath the main desk there's a slide out panel with drawer brackets to hold the keyboard and mouse to slide out to use.
The TV is mounted to the wall and surrounded by a wooden frame with a arcade marquee box at the top. Measure the TV box frame to just larger than the TV, to enclose it nicely and make it look built in.
Step 2: Button Setup for Dual Joysticks
The button holes in a typical arcade fighter stick pattern. Using the EG Starts guide I've wired the buttons accordingly, to a matching stick fighter button arrangement.
8 button joystick wired up like so:
K4 K1 R1 L1 K3 K2 R2 L2
It is plug & play in Windows and will register as a generic gamepad.
Step 3: Finish Build
Against the wall, build shelving with red t-molding edging with black paint, power saw and router with the t-molding bit.
Step 4: Top Marquee / Sound
There's a cutout above the TV for the marquee which will hold an additional game decal and 2 stereo speakers. Use the 3D print surrounds to give the speakers a nice finished look, this avoids having to cut perfect circles.
Attach the speakers to the 3D Printed surround and attached the surround to the marquee panel to place above the TV.
Apply decals to center of marquee between the speakers.
Step 5: Wiring
Using a USB HDMI Audio Splitter you can wire sound to a small amplifier to power the speakers.
Here's the following instruction of the completed wiring for all the components for the arcade.
The keyboard, mouse, lightgun, controller, and steering wheel all are connected to USB through a hold in the desk, these wires will be hidden under the box that mounts the speakers slightly higher than the desk top.
Use coat hooks to nicely wrap the wiring to avoid tangles.
Step 6: Finished
As you can see it's able to have a complete multi-functional arcade cabinet with all the standard arcade peripherals all routed through one single USB cable to the handheld. The handheld is also receiving power to keep it charged as well.
