Introduction: USB Gamepad Slotcartimer - Ir-lotsensor
This is the second variation of my slotcar timer interface. Where the gamepad was triggered by a "deadstrip" the first time I am now using an IR-slotsensor to trigger the gamepad.
EDIT
The third and refined version can be found here:
https://www.instructables.com/id/cheap-USB-slotcar...
Step 1: Partlist
TCST 2103 ir-slotsensor
Darlington transistor BD679 NPN
5 V/DC Reed relay
10kOhm and 100Ohm resistor
z-diode 5V LED
- (optional but good for testing)
This will set you back some 4-6€, depending on where you source parts.
I am leaving cheap and going for a "perfect" solution.
Step 2:
Here is the circuit.
The LED is optional but you can test your circuit with it.
Step 3: Things to Improve...
I am not sure at this point how accurate the hardware will detect the cars.
It will probably work good with 1:32 cars but have a hard time detecting 1:43 scale cars.
When I pull a toothpick through the ir sensor they are not always detected. 1:43 slotguide pins will probably not get detected.
The reed switch closes very fast and works rather good.
Ideas how the stretch the switching would really be appreciated.
I also bought an opti coupler, this it the next part I would love to test.
Of course the slotsensors would have to be installed in the slot.
I am just learning electronics for some days now so please excuse any stupidity I may display writing about this vast topic.
