Introduction: USB Kylo Ren Flash Drive
This was a project I made because I had a extra flash drive and wondered what to do with it
I was thinking though my head what I got the idea to make a lightsaber
After I started I just kept on going and it turned out to be better than I thought it would be!!!!!
Hot glue
Flash drive with status light
Aluminum foil
Black duct tape
Marker with lid
Small piece of red wire
Step 1: Remove Plug From the Base of the Marker
You may need pliers
Step 2: Pull the Marker Stick Out
Be careful not to ruin anything
Step 3: Cut the Marker Right Past the “Z” in Crazy Art
Step 4: Slide the Flash Drive in and Glue It Into Place
I used paper as filler
Step 5: Cut a Piece of Hot Glue the Length of the Marker
Step 6: Cut Two Nockes Into the Marker and Glue the Hot Glue in Place
Step 7: Glue the Aluminum Foil Around As Shown
Step 8: Add Aluminum to the Rest and Cut a Piece of Hot Glue the Length That You Want the Blade
Step 9: Glue the Main Blade on and Use Hot Glue to Make Waves on the Blade and the Quillions
Step 10: Use the Duct Tape to Make a Wrap Around It and Than the Cross Guards
Step 11: Use the Duct Tape to Make Another Wrap Around the Top
Step 12: Cut a Small Piece of Aluminum Foil and Glue It As Shown
Step 13: Take a Piece of Red Wire and Glue It From the Piece of Aluminum Foil to the Bottom
Add some small pieces of aluminum foil to keep the wire in place
Step 14: Cut a Gray or Black Marker Lid in Half and Cut Out the Inside Part
Step 15: Cut Sections Out of the Marker Almost As Long As the Part of the Flash Drive That Plugs Into the Computer
Step 16: Slide It on to the Drive, It Should Fit Tightly But Not to Tight
Step 17: Take a Piece of Tape the Size As Shown
Step 18: Wrap the Tape Around the Bottom As Shown
Step 19: Finished!!!!!!!
Thank you for looking at this some ideas for use***
*put the Star Wars movies on it
*build all lightsabers and keep them on a shelf
*solder a led so it glows brighter than just the status light
Thanks for looking!!!!!!!!
