Introduction: USB LED Hotwheels Car
Pimp my Hotwheels Car
Step 1: Tools Required
1. Soldering Iron
2. Hot Glue Gun
3. Rotary Drill (Dremmel)
4. Scalpel Set
5. Pliers
6. Wire Strippers
2. Hot Glue Gun
4. Scalpel Set
5. Pliers
6. Wire Strippers
Step 2: Materials Required
1. Hotwheels Car.
2. USB Cable with male plug.
3. LED & Resistor (Use the web to match your choice).
4. Wire, 2 Colours.
4. Wire, 2 Colours.
Step 3: Strip the Wires
Use the Red (+5v) & Black (Gnd) wires, and cut off the rest.
Step 4: Prepare the LED
The long leg on the LED is +, so the Resistor should be soldered to this, the shot leg is - or Gnd.
Please ignore the white cable in this Pic it should have been the black one!
Step 5: Solder & Clean Up
As space is limited inside the car, use a scalpel or file to clean up the solder, unless not like me you are a tidy solderer.
Step 6: Dismantle the Car
Use a small HSS drill bit in the dremmel to drill out the rivets.
Step 7: Cut Out the Spacr for the LED
Every car is Different, just be careful not to cut into the interior.
Step 8: Glue in the LED
Use the hot melt glue to fix the LED in place, using just a little glue at a time, be careful not to glue lower than the Wheels.
Step 9: Ready to Plug In
Plug in and stand well back!
Step 10: All Done
Just switch out the lights!
