USB Typewriter Conversion Kit
171,278
406
35
Introduction: USB Typewriter Conversion Kit
There is something very magical about typing on those old-school manual typewriters. From the satisfying snap of the spring-loaded keys, to the gleam of the polished chrome accents, to the crisp marks on the printed page, typewriters make for a sublime writing experience. Now, the USB Typewriter Conversion Kit lets you enjoy the magic of writing on a manual typewriter, without forfeiting the ability to use word-processing, email, web-browsing, or other modern desktop conveniences. Instead of fixating on a computer monitor, you can experience the simple joy of typing with ink on paper, and only look up at your monitor when you need to. Or, you can work on your typewriter alone, while discreetly saving your work to disk! (Your USB Typewriter will also make a nifty keyboard-stand for your iPad)
In these instructions, I'll help you breathe digital life into your old typewriter by converting it into a keyboard for your PC, Mac, or tablet computer. The USB Typewriter Conversion Kit will work on a wide variety of manual typewriters, from many different manufacturers and eras.
The hack is intended as a full keyboard replacement, so you can get rid of that piece of disposable plastic you call a keyboard and use the desk space for a classic, functional work of art -- A USB Typewriter!
Read on, and you'll see how easy the conversion process is -- anyone can do it, regardless of skill, and there is absolutely no soldering involved. If you are interested in performing this conversion on your own typewriter, you can purchase the USB Typewriter Conversion Kit at www.usbtypewriter.com/kits
The kit is designed to work on most manual typewriters, dating anywhere from the 1910s through 1960s. If you want to make sure your typewriter will work with the kit, simply look for your make and model in my Compatibility Guide, or email me at jack@usbtypewriter.com.
Step 1: How It Works
The USB Typewriter Conversion Kit consists of three simple components, which come pre-assembled and ready to attach to the typewriter as shown.
  • The Sensor Strip - The Sensor Strip is a row of 44 gold-plated contacts, attached to a long circuit board which will be mounted underneath the keys, spanning the width of the typewriter. Each time a key is pressed, it touches one of these gold-plated contacts, and this contact is detected by the circuitry.
  • The Magnetic Sensors - Since the Space Bar, Shift Key, and Backspace Key do not touch the sensor strip, they are instead detected magnetically. Magnets are attached to these keys, and magnetically-activated switches are glued nearby. These switches can detect the change in the magnetic field whenever these keys are pressed.
  • The Control Panel - This circuit board reads information from the magnetic sensors and the sensor strip, then determines which key has been pressed, sending that information to the computer over USB. The control panel also has several important buttons mounted directly on it: they are CTRL, ALT, and CMD. The Control Panel is mounted to the side of the typewriter, so that these buttons can be accessed easily.
Step 2: Tools and Materials
This kit was designed to require very few tools to install. Here is what you will need:
  • A fine tool for scraping/sanding, such as a metal file, 80 or 100 grit sandpaper, a nail file, or a Dremel tool with a wire brush attachment.
  • A small flat-head screwdriver
  • A pair of pliers
  • A hot glue gun
  • Wire Strippers (optional but highly recommended)
You will also need the Easy Install Conversion Kit from www.usbtypewriter.com, which includes:
  • 1 control panel that fits on the side of the typewriter
  • 1 sensor panel which fits underneath the typewriter
  • 4 magnetic switches for detecting Shift, Space, Backspace, and Enter
  • An assortment of magnets
  • A mounting bracket for your iPad or mobile device.
The project is open-source, so if you want to take a look at the design files that go into making these components, download them HERE.
Step 3: Mount the Sensor Circuitry (Video)
The first step is to mount the sensor circuitry under the keys of the typewriter. The flexible contact strip will be clipped to a piece of metal underneath your typewriter, so that each gold-plated contact on the flexible strip will be held underneath one of the keys. Each time a key is pressed, it will come in contact with one of the gold strips, activating the circuit.
Once the sensor circuitry is positioned correctly, hot glue will be used to hold the white circuit board in place.
It is hard to explain this part of the installation with pictures, so I have prepared a short video explaining how to install this circuitry on each of the most popular typewriter models out there. You should follow along with the video relating to your typewriter before reading on:
IMPORTANT NOTE: Some of the kits shipped in April of 2015 may have been shipped in an incomplete state! On these kits, the sensor circuitry was missing a strip of black gaffer's tape on one side. Before proceeding with the installation, please make sure there is a strip of black tape stuck to your sensor circuit! This circuit should be white one one side, and black (covered with tape) on the other! If you received a board that was missing this tape, email me at jack [at] usbtypewriter.com and I'll send you a replacement right away. (Royal portable customers can ignore this message, since that kit does not need the tape.
Click on the brand name of your typewriter for instructions:
Portable Typewriters:
Corona
Olympia
Olivetti
Optima
Remington
Royal
Smith Corona
Underwood Portable
Torpedo -- Video Coming Soon (email for instructions)
Triumph/Adler
Desktop Typewriters:
Royal No. 10
Royal KMM, and KHM
Underwood No. 5 and Similar Models
Remington Quiet-Riter, Letter-Riter, and Travel-Riter Models
Step 4: Attach Control Panel
Before you attach the main control panel to the typewriter, take the four rubber bumpers that came with the kit and stick them onto the four white dots on the back of the control panel. These bumpers prevent the back of the circuit board from directly touching the metal typewriter frame.
The control panel should be affixed to the left side of the typewriter towards the back. I recommend you use a moderate amount of hot-glue to attach the sensor board, but you may instead use double-sided foam tape if you want a less-permanent bond.
Some control panels come equipped with Bluetooth radio modules, which is soldered to the back of the control panel. If your control panel has such a module, do not place the rubber feet directly on the module, and do your best to avoid getting hot glue directly on the module. It is OK if the metal part of the module touches the metal frame of the typewriter (they are both grounded).
Step 5: Connect Ribbon Cable
The grey connector on your ribbon cable plugs into to the connector on the bottom right corner of the control panel, as shown. If there is too much slack, introduce folds and bends into the cable to make it more manageable (see picture above).
Step 6: Connect Chassis Lug Wire
In this step, we need to create a solid electrical connection between the control panel and the metal chassis of the typewriter.
First, find a screw or bolt on the typewriter that is easily accessible. Next, remove this screw and strip away the paint underneath it with sandpaper, exacto blade, metal file, or Dremel. Finally, use the screw to securely fasten the chassis lug to the exposed metal of the chassis -- the picture above sums it up nicely.
Now, strip the other end of this wire and insert it into the hole on the Control Panel marked "C" for Chassis. Turn the tiny screw clockwise to clamp the wire securely in place. (see second picture above)
Step 7: Mount the Magnetic Switches
In this step, we will attach the three magnetic sensors, which will detect Shift, Space, and Backspace.
To connect your first magnetic switch, strip the two wires attached to it and insert them into any of the four remaining pairs of holes on the control panel (marked "1", "2", "3", and "4"). NOTE: Before inserting the wires, you may have to twist the tiny screws counterclockwise first to open the hole up wider -- after inserting the wires you should tighten these screws again to clamp the wire in place.
ENTERING TEST MODE:
Next, while holding down the CMD key (the third button down on the control panel), plug the control panel into your computer with a USB cable. The control panel is now in TEST mode, and so the LED on the control panel will light up. Now, here is the magic part: take a magnet and move it close to the switch -- whenever it gets close enough, the LED changes color! Try it and see!
HOW IT WORKS:
The magnetic switch has the amazing ability to sense whether a magnet is nearby or not, and we are going to use this ability to detect the space bar, backspace key, and shift key. The idea is simple -- we will attach a magnet to the key we wish to sense, then glue a magnetic switch nearby. Whenever the key is pressed, the magnet will move towards the switch, triggering it.
WHAT TO DO:
Your goal is to select an appropriately sized magnet (the greater the distance, the bigger the magnet), place it somewhere on the key you wish to sense, then find the best possible place on the typewriter's frame to attach the magnetic switch. You will know you have found the right place when pressing the key causes the LED to change color, and releasing it causes the LED change back.
Once you have found the right place for your magnetic switch, glue it down with a very modest amount of super-glue or super-glue gel. Repeat this process for all the reed switches you plan to use. At the bare minimum, you should use a magnetic switch on the Shift key and Spacebar, and, optionally, Backspace as well.
NOTE:
The magnetic sensors currently included with the kit have neat mounting holes on one side. In certain situations, you can use these holes to screw the sensors onto your typewriter, instead of gluing them. However, in most cases, you won't need them, so it is OK to cut them off with scissors or wire clippers (see before/after picture).
CONNECTING ADDITIONAL KEYS:
Using the one remaining set of connections on the Control Panel, you can add an additional magnetic switch to the Return Carriage lever so it acts as an "Enter" key -- however, this is much more difficult to do. Therefore I recommend that you instead assign "Enter" to an unused key on the main keyboard (like the otherwise useless "½ / ¼" key) -- this re-assignment is done in the next step.
Step 8: Calibrate
When you first plug in the USB Typewriter, it has no idea which contacts on the Sensor Panel correspond to which typewriter keys. Luckily, the USB Typewriter has a "Calibration Mode", which sorts this out for you automatically.
To access Calibration Mode:
1) With the USB cable unplugged, open up Notepad (on Windows) or TextEdit (on Mac).
2) Next, hold down the CTRL button (One of three white buttons located on the Control Panel) while plugging the USB cable in.
A message should appear on your computer screen (See photo above).
You will then be prompted to type each letter of the alphabet, all the numerals, punctuation marks, and a few other keys. Just type the corresponding key on the USB Typewriter. A number identifying which key you pressed will be displayed on the screen.
You can also hold down the ALT button on the control panel while typing a key to assign a secondary function to a key. Example: you may want to assign ALT+Backspace to be Escape, or ALT+Space to be Tab.
ADDITIONAL CALIBRATION MODES:
In addition to the Calibration Mode described above, there are two additional calibration modes you can access:
"Manual" Calibration Mode: Hold down CTRL+ALT when plugging in to access Manual Calibration Mode. In this mode, you can scroll through an extended list of characters and pick the exact character you want to add to your keyboard layout. This way, you can fine-tune your keyboard, adding assignments for less common characters and/or characters from foreign languages.
Sensitivity Adjustment Mode: Hold down ALT when plugging in to access Sensitivity Adjustment Mode. In this mode, you can control how long a key must be held down before it registers. You can also control how long a key must be released before it is recognized as released. You can also reduce the typewriter's sensitivity to "double-taps": that is, keys being pressed twice in succession.
TROUBLESHOOTING:
The most common issue seen when calibrating is when the same number appears next to each letter, like this:
A: 23
B: 23
C: 23
D: 23
and so on....
This problem occurs because one of your gold-plated contacts is touching a key, or some other piece of metal inside the typewriter. Therefore, the typewriter's circuitry assumes you are holding that key down. Check each gold contact and make sure it is only touching its corresponding key when that key is being pressed.
Step 9: Enjoy!
Your typewriter is now completely converted and ready for a test drive! I recommend you read the operating instructions first, though -- I have the full instruction manual posted here. This manual will show you how to switch between USB, Bluetooth, and SD card mode, and how to protect your platen from damage if you don't plan on using the typewriter with ink ribbon or paper.
Optionally, if you plan on using an iPad or other tablet with your kit, you can fashion a support to hold your iPad on top of the carriage by following these simple instructions. If you don't have the Bluetooth version of the kit, you may also need the correct cable for your iPad, which you can find here.
Enjoy your awesome new (and old) USB Typewriter!
Check out my website to get more information about this mod, watch some nifty videos of it in action, or pick up a kit for your own typewriter hacking pleasure.
Hack It! Contest
First Prize in the
Hack It! Contest
1 Person Made This Project!
  • Make It Bridge
    Make It Bridge
  • Big and Small Contest
  • Game Design: Student Design Challenge
35 Comments
jolshefsky
jolshefsky
10 years ago on Introduction
I was thinking, "okay, this is kind of neat, but I like my old typewriter to be a typewriter." I like to use it especially if I have writer's block because (although I installed a ribbon with correction tape instead of red) it's hard to go back, making it impossible to edit-while-writing. It also has no mytimewastebook or any such nonsense.
But then I realized that one use — for me at least — is that if I write something on the typewriter, I usually have to transcribe it manually since OCR has a tough time with the cloth-ribbon letters. With this, I can make an instant backup, at least getting all the text entered.
A Bluetooth version would be cool, but perhaps even better (more generic) is something to make a USB keyboard Bluetooth (a box with a rechargeable that acts as a Bluetooth keyboard but requires a USB keyboard to get its input.)
spedersen4
spedersen4
I would love a guide to make a bluetooth keyboard that could be linked up with the Galaxy S3 :-D please please please provide... ;-)
best regards
Elkongen (=the electrical king)
Byungjo An
Byungjo An
Question 1 year ago
Dear Jack I purchased the Smith Corona Classic 12 USB Typewriter D.I.Y Conversion Kit, and today the typewriter was ready and ready to assemble, and it was confirmed that the 4 pin connector cable connecting the sensor board was missing and shipped.
While connecting 4 pins directly, the keypress detector board was damaged by impact.
You will need the 4 pin cable and the keypress detector board that were missing from the delivery.
Should I make a claim?
worsnop.p
worsnop.p
Question 2 years ago
Hi, I have a Remington streamliner with square keys. We have the remington streamline model 5 conversion kit. It looks like the sensor strip aligns OK with the keys but we're not sure where exactly to mount,as this model doesn't seem to have the same crossbar referred to in the videos. Should we try to mount it to the silver metal piece or somehow bridge the sensor in between the space bar strip and the silver metal piece?
ShoichiO
ShoichiO
Question 5 years ago on Introduction
I could finish to save text edit. How can I refrect Mac and I pad as I can write down on any apprication?
AmyK111
AmyK111
5 years ago
Hi Jack,
I bought the bluetooth version, but I don't know how to connect. I clicked on the instructional manual but got a Not Found (404).
Also. while calibrating I got the multiple numbers for each key. I think i have multiple keys hitting the sensors. Do you have any tips on how to fix that.
Great device you created.
HannahC25
HannahC25
7 years ago
i love typewriters! this is such a cool idea to me and im gonna have to do this ASAP!
KristinaT
KristinaT
7 years ago on Step 4
I got to the Calibrate part. The magnets and switches worked, but the sensor board did not. Not a single key. It looks like I scraped the paint well enough off the bottom, but I'll try some more. They A key does look a bit off, will that cause the rest of the board to not work? How should I proceed?
KristinaT
KristinaT
. (Note that the Shift key MUST go in the holes marked "SHIFT").
I don't see the holes that are marked SHIFT, what am I missing?
KristinaT
KristinaT
Reply 7 years ago on Step 4
I see SHIFT on your board, but mine says 4. Same thing?
kurt.nimmo.7
kurt.nimmo.7
7 years ago on Introduction
I love this idea. I am a writer who came to age in the era of typewriters. I recently bought an 1966 Olympia because I miss using a manual typewriter after I made the switch to a PC in the mid-1980s. I'd buy this, but there is a downside... I am completely and utterly un-mechanical or electrical, so I am afraid I will undoubtedly screw this up if I try to make the conversion myself. I thought about paying somebody locally to do it, but have no clue where to start. Good idea, even genius, but impractical for non-techies.
KristinaT
KristinaT
This is the best. I'm working on your conversion kit. I am afraid i will mess up. I have made it to the hot glue part... I think a good service you could offer would be for people like myself. If we try and do not do so well we could send it to you and you could fix our mistakes... I want to do it myself, but when I have trouble, no one around me is able to help.
rpotts2
rpotts2
8 years ago
beautiful. I was looking at the solder yourself kit and noticed the 74hc595s. I thought those were more for output than input. would the 74hc597 work better?
I love the look of this. Has anyone wondered about damage to the typewriter's platen from typing without paper inserted? Thanks.
DanielK8
DanielK8
8 years ago on Introduction
I know this is a bit old, so not sure if it is still checked or if Jack has an alert. Just curious if since you've been doing this if you've update to a more recent USB or would I still need the Camera Connection kit for my iPad to use it? I ordered a conversion kit today on Etsy. Despite it being October it still mentions you being on vacation in July. I hope you came back!
roddyaleixo
roddyaleixo
9 years ago on Step 7
How can I assign a magnetic switch to the return carriage? The instructables say it's much more difficult to do so, but are there any instructions to this at all? I'd rather try it than assign a dummy key to work as "Enter".
imrational
imrational
9 years ago on Introduction
Received my order from you, but I must have ordered incorrectly. I got Corona kits, and I have Smith Coronas Classic 12s. Will the Corona EZ kits work? I emailed you, but didn't see a response, so thought I'd try here.
jackzylkin
jackzylkin
Yes, the Corona kits will work just the same on Smith Coronas. Thanks for asking, and enjoy your kit.
jackzylkin
jackzylkin
gregp1962
gregp1962
What if I plug it in and there is no beep?
