Introduction: UV / Fluorescent SCUBA Dive Light (Trivial)
If you SCUBA dive, you've seen the new UV/fluorescent dive lights but probably didn't want to spend 100s to 1000s of dollars on a light that doesn't serve as a primary (or backup) light.
Here is how to put one together from a cheaply available SCUBA light, and a cheaply available non-SCUBA UV flashlight for about $30 without any tools.
For a bonus we will also get the non-SCUBA donor flashlight working again, but this requires a soldering iron and basic soldering skills.
What you will need (Shown Below)
- UltraFire WF-501B UV 395~400nm LED Flashlight (Bulb Donor, about $15)
- Yellow CREE T6 SCUBA light (Cheap Chinese units available anywhere for about $15. Make sure to get the T6 version).
Step 1: Take Apart the Flashlights
Take both of the flashlights apart. Pull the large springs off of the both the lamp fixtures.
Step 2: Switch the Springs
Switch the spring from the yellow T6 and put it on the UV lamp assembly. Assemble the flashlight (with a 18650 battery or 3XAAA inside of an adapter). You are done with your UV dive light. See the next step if you want an additional flashlight (non-UV).
Step 3: Bonus Step: Getting the UltraFire WF-501B Working.
The T6 light doesn't quite reach the battery, so an unmodified WF-501B with the T6 will not work. All that is needed to make the T6 work in the WF-501B is a small battery spring. A small battery spring from another broken donor flashlight can be soldered into the center of the T6 bulb assembly. The WF-501B will now work.
2 Comments
6 years ago
nice idea
B U T
Do you know that uv light could harm fluo animals?
Thats why the business goes with the funny yellow masks...
Many posts about that in the web....
8 years ago on Introduction
This is a good idea and I did a lot of research on this several years ago (before cheap dive lights were common). I was actually planning on building my own light until funds ran out (I would rather dive than have a light that I can't use). I don't night dive often so it didn't seem like a good reason to invest at the time.
One thing that I ran across while doing research is that the wavelength that sea life tends to fluoresce the best under is actually in the visual range: 450-470 nm. The main disadvantage to using blue light is the need for yellow filters on your mask or camera.
