Introduction: UV Resin Flower Pin
I've been meaning to have a go with UV dip resin for a while, and finally had a crack at it today. There was quite a learning curve on this one, but I did end up with a cute result. It's a pretty customisable project - I went for heart shaped petals and the gay and trans pride flags as my colours, but there are tons of other possibilities.
- UV dipping resin (clear)
- Standard UV resin
- UV coating resin (I used gloss)
- very thin wire, I used 0.3mm in silver
- petal making jig (you could absolutely make your own, or shape the wire freehand/around small household objects like pens/chopsticks etc.)
- wire cutters
- UV lamp
- alcohol ink pens and/or resin pigments
- glue (I used Bostik contact adhesive)
- two beads (I used 1x 6:0 green seed bead and 1x 6mm wooden bead)
- green fabric/ribbon (I used recycled sari silk ribbon yarn)
Step 1: Shape Wire
Wrap a length of wire round your jig to form a petal, and twist the two ends together. Cut the wire, leaving about an inch and a half to work with. Make more petals than you think you'll need!
I started off making larger petals on the biggest part of the jig, then when I got to the next stage realised I'd bitten off more than I could chew. I ended up using 6x 12mm petals and 5x 6mm petals.
Step 2: Dip!
This is where things derailed a little. I dipped my large petals into the resin, pulled them out, let the excess drip off... And the film burst. I kept at it with all the large petals I'd made, and most of them turned out looking like I'd made hot glue blobby monstrosities (blobby monstrosities pictured) because I couldn't get them both thin and intact.
So I moved down a size, and that went much better. I dipped one at a time, dripped off some of the excess, and then partially cured each petal using the UV lamp (make sure you put the lid on your pot of resin each time!). Then I set them aside and moved on to the next petal. I then did a full two minute cure on all of them.
So I'd definitely advise starting small with these - the 6mm petals turned out great and were really easy, the 12mm weren't bad. I shall be working up to larger ones when I've honed my skills a little!
Step 3: Colour
I do actually own a lot of different UV resin pigments, but to keep the specialist materials down I mostly used alcohol ink pens to colour my petals. I did a couple of practice ones on my blobby monstrosity petals, before colouring my six larger petals rainbow with a little clear at the base, and the five smaller pale pink, blue, and one clear. I used a blending pen to blur the transition from coloured to clear a little.
Step 4: Resin Resin Resin
I then did a coat of my normal UV resin over the dried ink (make sure you've got the side you coloured on!), and cured. For the trans pride petals I also added first a sparkly layer on the back (the colour was Polarisation Pearl from Padico) and then a layer of white over that. Cure cure cure.
Step 5: Sand and More Resin
I stuck a dust mask on, and gave the petals a light sanding on both sides. Then, one side at a time, I coated and cured a layer of UV coating resin. We are almost done with the resin. Mostly.
Step 6: Assembly
I took my seed bead, and threaded all my trans petals into it. I arranged them as I wanted, before cinching the bead right up to the top, and twisting the wires together.
I didn't have a matching green bead with a larger hole, so I coloured in a plain wooden bead using an alcohol marker. Then I threaded in both the trans set of petals and all the gay ones. Arranged them how I wanted, and twisted all eleven strands of wire together.
Step 7: Very Nearly Final Resin Stage
I drizzled more of the normal UV resin onto the twisted wires, to secure them. Cured that.
Step 8: Actual Final Resin Stage
I glazed the wooden bead with coating resin, and cured (you could do this step earlier before assembly, but having the flower as a stand actually works quite well for application and curing).
Step 9: Glue!
I measured my stalk against a kirby grip (you could use another style of hair clip, brooch pin or whatever you fancied), and trimmed the wire to around the same length. I then applied glue to the wire, and wrapped it in silk ribbon starting at the flower end. Without cutting the ribbon, I then applied glue to the top of the hair grip and the wire I'd just wrapped, and wrapped the ribbon back up the stem and top half of the grip. I glued the bead to the top circle, and glued the end of the ribbon in place around its base to hide that last bit of metal.
Step 10: And Done!
I tweaked the positioning of the petals one more time, and called the project complete!
The dipping resin was definitely less beginner-friendly than I'd anticipated (and very labour intensive), but it was also really good fun. I'll absolutely be doing some more projects with it to improve my skills. I think next time I'll use coloured resin instead of the alcohol pens, but the pens are absolutely a more budget-friendly/versatile option if you don't hoard craft supplies as much as me!)
