Introduction: Uber High-end Fashion Earrings From Recycled Water Bottle
This Instructable will guide you through the process, of creating some simple fashionable earrings from Recycled Water Bottles.
This I'ble will show you one example that you may wish to recreate. The possibilities are endless and many neat effects may be achieved.
Step 1: What You Will Need
You will need for this project-
~ Water bottle.
~ 2 earring hooks.
~ Some small gauge wire.
~ 1200 grit Wet / Dry sand paper.
~ Assorted beads / stones.
~ Needle nose pliers.
~ Matches or a lighter.
~ Water bottle.
~ 2 earring hooks.
Step 2: Cutting the Segments, Creating Ancor Points and Sanding
Start by taking your bottle and cutting the top and bottom off it.
Take the cylinder and slice it up one side.
Lay the sheet of plastic out flat and trace around the bottle cap. We will need 6 circles for these earrings.
Cut the 6 circles out.
We now need to create the anchor points to join the segments.
There needs to be a hole at the top and bottom of 4 segments.
Then two of those we need to make another hole to anchor the offset segment.
Make this hole just to the side and up a tad from the bottom hole .
We then need another hole just at the top of the offset segment.
Take some of your wire and heat till glowing red hot. Use this to make the holes.
Once you have finished creating the holes it is time to sand. Take your sand paper and abraid the surface of the plastic to an opaque finish.
Step 3: Joining the Segments
To join the segments we will need to take some of our wire and create loops in order to connect the pre-made holes.
Create 2 pairs of fixings as pictured. The smaller are for the offset and the larger pair are to join the top and bottom segment. I have made these larger as to accomodate a glass bead.
Step 4: Attaching Segments
Take you earring hook and attach the first segment.
Next take your larger joiner and connect the top and bottom.
Once you have joined the top and bottom segments, take a smaller joiner and attach the offset.
You may then connect the finishing beads to the bottom segment.
Your wire joiner here will depend on what items you wish to use to finish.
Just make another set similar to the ones used to join the top and bottom.
Step 5: Your Finished!
That's it!
Try various combinations and designs. Experiment with different stones / beads etc.
The possibilities are endless.
