Introduction: Ufo Light Toy...
I invented this toy when i was a child. I was trying to
make a perpetual motion machine but made this by accident...
It is fun and very simple...
I did this build at The TechShop in San Jose California...
http://techshop.ws/
Gabriel Aceves
http://techshop.ws/
Gabriel Aceves
Step 1: Materials...
Materials you are going to need are, (2) small Dc motors, (1) 1/8 split pin, (1) small 6-9volt lightbulb
with 4 inch leads, (1) AC-DC transformer that matches the voltage of of your dc
motors... I got all the materials at HSC electronic surpluss
in sunnyvale california. you also need a soldering iron and solder
Step 2: Step One... Linking the Motor Shafts...
Ok so what we are going to do in this step is connect the shafts of the two motors
as shown in the pictures... I found that a 1/8 inch split pin worked will...
When I was a kid I used the gears that were attached to the motors, So you
are going to press one shaft halfway in and the other motor the other
half from the oppisite side...
Step 3: Step Two... Soldering the Light...
Now you are going to solder the light bulb to the motor...
You cant tell in the pictures but you want the wires facing the same
direction and at a ninety degree angle from the shaft so they do
not flex alot... They should also be the same length...
Step 4: Step Four... Soldering Your Power Supply...
Now we are going to solder our power supply
to the second motor... I did not put a switch in
there but you could put on in if you want...
i am just showing the concept and base materials..
You can also use batteries as a powersource....
I think I am going to figure out how to make a prettier
and more compact model some day...
Step 5: Step Four... Testing...
So plug in the powersupply and when the motor spins hold
the second motor and see if your light bulb lights up...
If it does not check your wiring and rating or light bulb...
If you have a multimeter see if power is coming out of your
second motor which is now acting as a generator...
If you do then check your bulb... if not check your generator....
Step 6: Step Five... Having Fun...
Go and find a dark place and plug it in and
look at the pretty circles,,, If you shorten the wires the
lightbuld goes faster... You can also hook up
multible and colored bulbs... Havefun...
I did this build at The Tech Shop in San Jose California...
Gabriel Aceves
Gabriel Aceves
