Ukulele Storage Cart
Intro: Ukulele Storage Cart
My daughter's school's music class was in need of a storage solution for 30 Ukuleles, and this is the design that the music teacher and I collaborated to come up with.
STEP 1: The Sides
There was a cart we had seen online that had sides shaped like a Ukulele, and that was a must have part of the design.
I started by measuring our Ukulele and thought about the height I would need for two rows, and the width I would need for it to be stable on two wheels. Some quick googling and mathing gave me a scale factor that helped determine the exact sizes. Despite all my measuring, my wife had to help freehand some of the curvature so it looked proportional.
I created a symmetrical paper template by folding a large sheet in half vertically, and then cutting both sides at once. I could then transfer the paper template to the plywood and rough cut two pieces. One of the pieces was cut to its final dimensions, and then used it as a template to cut the opposing side with a template bit in a trim router. Rounding over all of the edges, and spending some time sanding and filling voids leaves a nice edge (even though it's plywood).
Also pictured was my initial thought for how the shelves would be positioned, and where the Ukulele would sit.
STEP 2: Fitting Rails
Since the sides of the cart are made from plywood, I wasn't sure how to join the rails (1x2" pine boards). They don't really need to hold a lot of weight, but the force of pushing the cart around and the general abuse from young children was cause for concern. I landed on butt joints with dowels. This helped with alignment, sheer strength, racking, and additional glue surface.
Pictured is a test fitting with scrap wood, and my process for sanding dowels to fit (they're never perfectly sized for the hole you need). I created a makeshift lathe by chucking one end into my drill, putting the other end in a scrap of wood with a hole in it, and using some sandpaper to decrease the diameter.
Not pictured are a couple of jigs I made out of maple (because it's harder) to help line up the holes I drilled in the ends of each rail. A trick to keeping them straight with a hand drill is making sure you're at 90 degrees, and then using a wrench or ring on your drill bit to keep you from wandering up or down.
STEP 3: Attaching Rails
I used squares and rulers to line up 1 hole per rail, and then drilled through both sheets so one dowel hole would be all the way through, and perfectly in-line. Then I could use metal dowel centers to punch a location for the blind hole. In this way, each rail is joined with 2 dowels on each end, one through and one blind.
Pictured is some of my layout process, and a test fitting.
STEP 4: Finishing Rails
Gluing it all together was a bit of an issue. The dowels made lining everything up and holding it square easy, but I didn't have clamps long enough, and fitting it all together before the glue started to set up was problematic. I ended up doing one side in stages, clamping it all together with some rails only dry fit, and then the other side all at once. Luckily I was able to use two clamps together to span the distance. After glue up was complete I flush trimmed the through dowels, and sanded things smooth.
Pictured is the clamping using longer boards to spread the pressure evenly, and the flush trimming of the through dowels.
STEP 5: Adding the Neck
I cut out the neck pieces and finished them as I had the body. I also attached them and the last rail pieces in much the same way that the rest of the rails were attached. The only difference is that I added through dowels that only showed on the inside, and only blind dowels for the top rails, since I though it was more visually appealing.
Pictured is more layout, sanding the through dowels smooth, and a picture of things finally coming together.
STEP 6: The Nubbins
I had been messing around with ideas for keeping the Ukuleles in place and providing a visual indicator for where to put them. I landed on creating these little nubbins between the spaces where the necks would go, and attaching them with the same glue and blind dowel joinery (except only a single dowel) that I used elsewhere. I cut out 36 little pieces, used a table router to round over all of the edges that wouldn't touch the rail, and then spent more time than I'd like to admit sanding them smooth on an upside-down orbital sander.
Pictured is a jig I made to help drill holes in the small pieces, my sanding station, the glue up, and a test fit.
STEP 7: Wheels & Finish
To add the wheels, I just added a small board perpendicular to the the wide boards at the base of the cart to provide a bit more meat, drill through holes, and used bolts to attach. These are the only mechanical fasteners on the structure.
For finish, after sanding smooth, I applied stain and paste wax.
