Ultimate Night Vision Headlamp - 500+ Lumens With Only 8 Watts
Intro: Ultimate Night Vision Headlamp - 500+ Lumens With Only 8 Watts
Headlamp flashlight technology takes a quantum leap! You can have it all: * Intense brightness * Lightweight * Long life * Low cost * Rechargeable * Unbreakable * Small * Waterproof * Unique shocking turquoise color
Race proven! I put the light to the ultimate test by competing in the Gold Rush 24-hour Adventure endurance race in the Sierra Nevada mountains of California. Many of the other competitors had $500 HID lamps from NiteRider, Light & Motion, etc, yet throughout the race nearly everyone that saw my light commented as to its extreme brightness or asked where they could get one. It was that much brighter than anything else.
Specs:
brightness: 500+ lumens / 7 million+ mcd @ 15 degree
weight: 120 gram headlamp + 60 gram electronics + 280 gram battery pack = 460 gram total
cost: $60 including batteries
lifetime: 3, 6, 12, 24 hours (4 brightness settings)
size: headlamp portion 5cm x 5cm x 2.5cm
rechargeable: Ni-MH or Lithium-Ion batteries (your choice)
unbreakable: LED technology
Tech:
- Cyan (or Green) high power/high efficiency LED's
- high-transmittance TIR lenses
- high-efficiency DC/DC step-down converter
None of this was possible just a couple years ago, but now it can be done easily with inexpensive components you assemble yourself!
i've got several other power-LED instructables too, check those out for other notes & ideas.
This article is brought to you by MonkeyLectric and the Monkey Light bike ilght.
Specs:
Tech:
STEP 1: What's So Special Here?
Your eye! Remember back to biology class - your eye has "rods" and "cones". these are the sensing cells in your eye that detect images. the cones are your daylight & color vision, but they are less sensitive than the rods. Now the part you didn't learn in school:
(1) The rods are about 2.5 times more sensitive to light than the cones. That's why they are your night vision.
(2) The rods and the cones are not equally sensitive to all colors (wavelengths) of light. The wavelength of maximum sensitivity for your rods is 507nm, or blue-green. Why? Moonlight is more bluish than sunlight. The color of maximum sensitivity for your cones is 555nm green, about the color of plants. (more info)
To get the best possible vision at night, we'd like to build a lamp that puts out the most light at the 507nm that our rods are most sensitive to. This gets us the best vision at night for the least power used. If we had a white light instead, it would take much more power to get as much visibility.
Thanks to our friend the LED, this weird pure turquose light is possible! The latest LED technology is much more efficient than a standard light bulb to begin with, but using the special turquose color gives us even much better night vision than white, and is more efficient than even the fanciest HID lights.
STEP 2: Ok, But Really What Is So Special Here?
well, basically there are a couple of things we do to get better efficiency and output than anything else you can buy/borrow/steal:
1) use cyan or green LED's. these will give 2.5x their rated lumen output using your night vision, because they are rated based on your day vision. (see http://hyperphysics.phy-astr.gsu.edu/hbase/vision/bright.html )
2) use the latest high-power LED's. new LED's such as the Luxeon's are rated about 50 lumens/watt for cyan and green (this is the day-vision rating). this is equal to the high-end HID lamps and at least twice as efficient as a halogen lamp. The Luxeon LED's used to be pricey, but now they are about $3 each.
3) use the latest optics custom-designed for the Luxeon LED's. several companies are now making low-cost lenses for LED's based on the TIR (total internal reflection) principal. These lenses do not have a reflective mirror, and achieve 85%-90% transmission. non-LED lamps lose much more of the light because some of the light shines backwards where it can't be used, and because mirror reflectors are less efficient. typical transmission for reflector-based systems is only 65%.
4) don't over-power the LED's. looking at the LED datasheet, we notice that the LED efficiency goes down somewhat with higher power: 45 lumens at 1W power, but only 80 lumens at 3W power. so we get the best efficiencies with less power. this indicates the importance of having a brightness-switch on the unit. in practice i have found the 1/2 power setting to be nearly as bright as the full power setting.
STEP 3: What You Need
4 x Luxeon Star 1W Cyan (LXHL-ME1D or LXHL-ME1C) OR Green (LXHL-MM1C or LXHL-MM1D) - $3 each. (the circuit will work just fine with any color LED you want)
old CPU heatsink (around 5cm x 5cm x 1.5cm)
LED Dynamics Buckpuck (3021-D-I-1000 or 3021-D-E-1000) - $20
4 x L2Optics/Dialight OP-015 lens - $1 each
4 x L2Optics/Dialight OH-ES1-CL lens holder - $0.30 each
8-10 x AA NiMH rechargeables, or 3 x Lithium-ION rechargeables - $20 total for NiMH
2 small toggle switches (digikey 519PB) - $1.50 each
1 large toggle switch (digikey 514PB) - $2
flexible stranded wire (18ga to 22ga)
sheath for wire (eg: sheath of a 3/16" double-braid rope)
silicone or epoxy
thermal compound (also known as thermal grease or heatsink compound) - $5
plastic or fiberglass for heatsink mount
old headlamp headband
Where to get it:
old CPU heatsink - you will find these in any broken computer from 1995 onwards. in newer pc's the heatsink will be too large, but you can cut it with a hacksaw.
US/Canada:
the LED's, lenses, and buckpuck all come from future electronics also see here - the 2nd link is a direct search for the LED's and buckpucks. for the lenses, here is the direct search to find them.
Europe/World:
You can get the above LEDs, buckpuck & maybe lenses at farnell.com or rswww.com
- i recommend Luxeon 1W Stars, either Cyan or Green with either Lambertian or Batwing type. My testing shows that the 1W stars can be driven at 2W no problem with the heatsink, and they are much easier to work with than 3W stars because their backplate is insulated.
- Several different lenses are available for the lens mounts, so you can easily tailor the light to your needs. you can even change the lenses on the road in a minute or so. there are 5 degree, 15 degree, 25 degree and 5x25 degree lenses available, all are $1 each.
batteries are from http://www.batteriesamerica.com
switches from http://www.digikey.com (probably can find similar items from future electronics)
small quantity thermal compound. both computer and electronics stores have this. "Arctic Silver" is one of the common ones for computer use. Thermal adhesive is even better if you can find it (and it is pricey).
http://www.mouser.com (search for "thermal compound")
http://www.newegg.com (search for "thermal compound")
Digikey also has it, but only in $25 packs. CompUSA also will likely have it.
wire: 22ga is ideal here. you want something flexible that won't break after a few flexes. this can be surprisingly hard to find! radio-control hobby stores usually have something like this. at Home Depot you can get an 18/2 or 18/3 rubberized cable ("SJOOW") and split it open to get out the individual wires.
sheath: you want something to go over the wires and protect them. a good choice is a 3/16" or 1/4" double-braid rope (that means it has a core and a sheath). you pull out the core and have a sheath left. you can probably find this at Home Depot, if not try your local Marine store for yacht rope.
more information: the technical datasheets for each component:
Phillips Luxeon Star Led's: http://www.luxeon.com/pdfs/DS23.pdf
Led Dynamics Buckpuck: http://www.leddynamics.com/LuxDrive/datasheets/3021-BuckPuck.pdf
L2Optics/Dialight Lenses: http://www.l2optics.com/luxeon.aspx
silicone or epoxy
Where to get it:
US/Canada:
Europe/World:
STEP 4: Solder the LED's Together
fit to heatsink. the led's are in a series-parallel configuration (2 led's in series, 2 pairs of that in parallel)
note that if you want to make a white headlamp, or any other color, the project will work exactly the same.
STEP 5: Heatsink Goop
clean the heatsink first so that glue will stick to it later.
apply heatsink goo (heatsink compound aka thermal compound aka thermal grease) to bottom of LED's. you can also use thermal glue instead (and it is probably better if you do), but it is hard to find and a bit pricey.
stick LED's on the heatsink and wiggle slightly (but keeping the goop from getting all over since you need to have the glue stick later)
STEP 6: Glue the LED's
the glue is all we are using to hold down the LED's. it seems tough and durable to me, but if you are worried the alternative is for you to drill 2 holes in the heatsink for each of the LED's (matching the cutouts in the star), and bolt them down with 4-40 size nylon machine screws. (or 3mm size). you can get nylon machine screws from www.mcmaster.com
1) do not get any glue on the LED lens. some glues (like silicone) you can get off the lens after it dries.
2) make sure the glue can handle 80-100 degrees celcius. (don't use hot-melt glue!). make sure it is waterproof (don't use superglue / cyanoacrylate)
3) i used silicone, but if i do it again i will try epoxy instead. the silicone does not flow by itself, so it is hard to get it to fully cover the LED (in order to have a submersible lamp). with epoxy you can dispense it with a syringe and accurately get it everywhere but the lens. smearing the silicone around is messy.
4) after pouring the glue, press the lens holders into place on top of the led's
STEP 7: Attach Buttons to Buckpuck
hot-glue or silicone
the big switch is the master on-off
the small switches will control the brightness. you only need TWO small switches, three turned out to be overkill.
STEP 8: Solder Brightness Resistors
refer to the schematic below. we'll build it using "point to point" wiring.
R1 = 680 ohm (blue gray brown)
R2 = 1200 ohm (brown red red)
these values worked for my buckpuck despite a somewhat misleading note in the datasheet, so test your resistor values before soldering.
these values give you FOUR overall power settings:
1) heat resistor lead and melt a small blob of solder to it ("tinning" it)
2) heat the switch lead and melt a small blob of solder to it also
3) now hold the resistor lead against the switch lead and melt the two solder blobs together, without needing to add any new solder.
this is good soldering practice in general anytime you are soldering something that is heat sensitive (such as the battery holders)
- both switches off: full power
- one switch on: 1/2 power
- other switch on: 1/4 power
- both switches on: 1/8 power
STEP 9: Attach Headlamp
you will need an old headlamp mount (or you could make yourself one from a bungee-strap and plastic). you will have to figure the best way to attach your LED/heatsink to your headlamp since it depends on the details. for my headlamp, i cut two simple pieces of plastic (shown below)
STEP 10: Strain Relief the Wiring
one of the keys to durable electronics is STRAIN RELIEF. any wire that gets bent or pulled will rapidly break if it does not have a good strain relief. there is a certain art to making a good strain relief!
first, i covered my entire wiring with a sheath from a 3/16" rope. if you've used very durable wire to begin with this may be overkill.
next, i made a strain relief where the wiring attaches to the headlamp, so that it won't get tangled or ripped when the lamp angle is changed, or the battery is dropped.
make an overhand knot in the wire, then glue it to the base plate. the knot gives much better grip to the sheath and the glue.
STEP 11: Make the Battery Pack
the "Buckpuck" lets you use pretty much any battery pack. The buckpuck is just an efficient (90-95%) DC-to-DC step-down converter, so it will always output the correct voltage and current to the LED's no matter what the input voltage is. The LED's may need up to about 7V to run them, and you need to add 2V overhead for the Buckpuck - so any battery pack above 9V will work. 8 x NiMH cells will be 9.6V, 3 x lithium-ion cells will be 11.1V, and 10 x NiMH cells will be 12.0V. those are all good choices.
I used 8 x NiMH cells, AA size. These are 2700mAh cells, which yielded about 3 hours runtime at maximum power, and 24 hours runtime at minimum (1/8) power.
STEP 12: Finish Wiring
connect the lamp and battery to the electronics
STEP 13: Add Lenses and Test!
the lenses just press-fit into the lens holders
several different lenses are available for these mounts, so you can choose the lens angle you want.
don't stare directly into the light! it will blind you!
630 Comments
Sandy Man 4 years ago
colin.riddel 7 years ago
As a motorist I am required to have my headlights adjusted so as not to blind an oncoming driver. I have several times had close calls to accidents caused my these superbright headlights worn on a cyclists head with the beam waving all over the place including directly into my eyes. These devices should be BANNED totally
Azze01 5 years ago
Nowadays, I have a LED Light on my helmet and so I have the light exactly where I need it: in the spot that I'm looking at. Plus it gives me the chance to direct my beam away from every oncoming car by looking to the ground/curb (just try that with bar mounted lights), but many of them keep blinding me until I blind them back. All I need to do now is lift my head and stare at the driver for a second to make them switch to low beam instantly. This tells me that they exactly know what they're doing but don't give a damn.
But we shouldn't think in "They" and "We" categories. We're all prone to make mistakes and share the streets as well as the interest to avoid accidents. This should be motivation enough to take care of each other and not bash each other.
JohnD316 7 years ago
I agree with you Colin.riddel. The lights on bicycles should be mounted on the bike and not waved around to annoy other drivers. Now-a-days most bike riders disobey the rules at night anyway and don't use lights of any kind. Also when is the last time you saw an adult cyclist with a bell on the handlebars? As a motorist you do require your headlights to be properly adjusted but when some drivers put huge tires on their pickups they forget that their headlights are now a foot higher and never get them adjusted. I think the police are missing this offence in every regard. Also most garages do not have the correct equipment for headlight alignment.
Musicman41 7 years ago
As far as the bell goes, it's not as effective as you may think. I had one, but haven't replaced it since it broke. It's not loud enough to get the attention of motorists (especially if they play music), and pedestrians are slow to recognize it, and confused when they do. I think the only time this helps is when riding with other cyclists. It's much more effective to use your voice. I personally say "Passing on your _______" when biking in passing period at school to let people know I am going around them.
I am guilty of riding without a light, because I am too lazy to replace mine after it broke (same incident as with the bell). 95 percent of my ride, though, is under streetlights, and I am always aware that motorists may not see me, and thus ride much more cautiously.
TurdF1 7 years ago
Funny, as a motorist I cross paths with cyclists all the time. Can't say I've ever noticed "these superbright headlights worn on a cyclists head with the beam waving all over the place including directly into my eyes". As a cyclist I ride with 2 bar mounted lights and a head lamp, that way I can track ahead when I hit the trails. I've honestly only had one driver complain about the head lamp. He was in the oncoming lane and made a left that would have sent me to a hospital if I hadn't stopped. I looked directly at him with the headlamp. First he said the light was too bright, then he said he hadn't seen me before he turned. The thing is these lights are only blinding if you point it in someones face. Most cyclists are aware of this and keep it aimed at the road unless someone else isn't paying attention. Since you've had "several close calls" perhaps your driving and general lack of awareness are the issue?
EricR177 7 years ago
Well wait a min a car driver almost has several close incidents with cyclists, (I'll assume he means nearly running then over / killing them) yea must be the headlamps, ofcourse it couldnt be his driving.
I read you essay. You state " Most cyclists are aware of this and keep it aimed at the road", most may very well do so but not all do. You however like a lot of cyclists seem to have to blame someone other than yourselves for anything that goes wrong
JerryS42 7 years ago
I definitely understand and share your concern. And the same is true for some car LEDs.
Also, keep in mind;
1. Turn your high beams off; most bikers and pedestrians want to know you've seen them and likewise don't want to be blinded.
2. Slow down and give some space; some will use their light to get your attention if they think you have not spotted them.
3. Be considerate, keep in mind that you are not the soft target in a potential collision.
FrankM38 7 years ago
OK, I'm confused. If the light is "waving all over the place", how is it blinding when the light isn't pointing directly at your eyes?
Ever bought a car and for weeks after the sale it seems like dozens of other drivers bought the same car? That's what is going on in your case.
Have you read any studies on the this? Is there actual data? Is data being supplied by "THEY" university? I'm not trying to be difficult but simply asking. There is a tendency for us to be knee jerk reactionary and call for banning or criminalize those things without ever asking "is it me?" first.
I've had night vision problems myself. Back in the 80's the only vehicle I used was a motorcycle. Of the 3 accidents I've had in total, 2 were night vision related. My last crash happened in 1997. Long story short, a $10 yellow visor has kept me from any night vision wrecks and put a flip down filter in my cars.
My last upgrade was putting a yellow decal on the top 3rd of my helmet visor only. This was done after putting a blue headlight on the bike and noticing some of the benefits using it went away with a filter. I just tilt my head if need be.
Frank: Would you ever think of putting a light on your motorcycle helmet and not using the ones on the bike. The ones on the bike do not wave around like a helmet light would.
MimkeD234 7 years ago
That was actually my first thought. The bluer side of the spectrum has good visibility, but is also effective at blinding bystanders (or drivers, in your case). Couple that with how bright this thing is and it can become quite dangerous.
Perhaps it would better if only used out in the woods (or other secluded location) where there isn't going to be a passing motorist to blind.
On another note, I wonder how well a red headlamp would work with these specs. The color red is supposed to be very friendly on a person's night vision and is actually what pilots use in the cockpit when they have to read something at night. A white or blue flashlight could severely diminish a person's night vision capabilities for up to 30 minutes (bad combination for flying a plane).
ronjohnstone 8 years ago
"Moonlight is more bluish than sunlight." NO! Moonlight is nothing more than reflected sunlight = exactly the same color spectrum. It looks different simply because it is much dimmer and your eyes rods don't see color well.
chrwei 8 years ago
that would only be true the moon were a perfect reflector, which it isn't because you can see its surface features clearly. I don't know how accurate the blue statement is, but your statement isn't exactly accurate either.
ToolboxGuy 8 years ago
I have no idea what colors if any are lost in the reflecting, perhaps some across the spectrum, so at best a weakened version of sunlight.
towellm 6 years ago
The moon looks as it does for many reasons but primarily Rayleigh Scattering. The lamp is great because of his research into the human eye and will make this post timeless. If you look a little deeper, you'll see why most white LED's (without corrections) are a very poor source of visible light because of refractive image splitting on the retina and also the biology of the rods/cones taken together plotted against the frequensies of these devices.
ToolboxGuy 6 years ago
@towelim - If it were a red ball instead, we wouldn't be seeing much blue light reflecting from said red ball, Rayleigh Scattering or not.. I had made the reference to the moon's "color" as I had seen an actual
rock taken from the moon, and it'd be an incomplete spectrum of color,
as we don't get to see all colors "reflecting from the moon." There didn't appear to be any iron or silica in it at all. It looked more like greyish limestone or compressed grey dust than anything else. I am sure the RS effect attenuates the light as well - I will have to read up on it -- thanks!
It's too bad that we hadn't been able to run any spectroscopic analyses on the sample back then, so I'd have more information about it. (Not that we could take any of it and heat it up!)
Perhaps NASA or other groups have data on the subject nowadays?
towellm 6 years ago
You bring about an interesting point wrt to this headlamp. Low light vision is further broken down into Scotopic and Mesopic (basically: low and lower). If you look these up and esp the wavelengths associated with each, certain colors will be more pronounced than others depending on light level (LUX). I believe a three color headlamp (LED's come in 5nm steps), each dimmable, would allow adjustment to the specific environment (colors) and LUX levels you are witnessing. The ideal ranges might be 495-500nm, 500-505nm and 505-510nm.
nicholashansen36 8 years ago
moonlight is more bluish then sunlight due to the fact it indirectly comes in contact with the earth, there are greater chances for materials that obstruct its path to absorb the other colors of the spectrum, and the most resilient color of the spectrum is blue, hence why the sky is blue, and mountains and other objects in the distance appear more bluish because the other colors in the spectrum fade away before blue does
Lawvill 7 years ago
Bear in mind that this is a 10 year old post, which means that it was made back in 2006. That in mind, this therefore is very impressive.
