Introduction: Ultra-Low Power Precision Timer Using the ICM7555
About: Eiyu | Electronic Components Specialist Providing expert insight in sourcing, modules, and supply chain strategy at Eiyu—a top distributor of components from 1,000+ global brands.
ello everyone! Today I’m diving into a project featuring a classic reimagined: the ICM7555ISA.
While many of us grew up using the standard NE555, the ICM7555 is the CMOS version that every engineer should have in their toolkit. It solves the two biggest headaches of the original 555: high power consumption and massive supply-current spikes during transitions. This makes it perfect for battery-powered IoT sensors or precision timing circuits where "noise" is the enemy.
Introduction: Why the CMOS ICM7555?
The ICM7555ISA (SOP-8 package) is a direct drop-in replacement for the standard 555, but with massive performance upgrades:
  1. Ultra-Low Current: It draws only about $40\mu A$, compared to $3000\mu A$ for a standard NE555.
  2. Wide Voltage Range: Operates from $2V$ to $18V$.
  3. No Supply Spikes: You don't need the massive decoupling capacitors typically required to "tame" an NE555.
  4. High Input Impedance: The trigger and threshold inputs are $10^{12} \Omega$, allowing for very large timing resistors and extremely long time delays.
In this project, we will build a Long-Duration Battery Monitor that pulses an LED every 5 seconds to indicate "System OK" with minimal battery drain.
Core Components:
  1. IC:ICM7555ISA (SOP-8 Surface Mount)
  2. $R_1$: $10M\Omega$ (Timing Resistor - enabled by the CMOS high-impedance input)
  3. $R_2$: $47k\Omega$ (Sets the pulse width)
  4. $C_1$: $1\mu F$ Tantalum Capacitor (Timing Capacitor)
  5. $C_2$: $0.1\mu F$ Ceramic (Bypass Capacitor)
  6. LED: Low-current High-Efficiency LED
  7. Battery: $3V$ Coin Cell (CR2032) or $3.7V$ Li-Po
Tools:
  1. Soldering iron with a fine tip (for SOP-8)
  2. Solder wick (for cleaning bridges)
  3. Multimeter
Step 1: Circuit Design (Astable Mode)
We are configuring the IC in Astable Multivibrator mode. Because the ICM7555 has almost zero input leakage, we can use a $10M\Omega$ resistor for $R_1$, which would be impossible with a standard bipolar 555.
  1. Pin 3 (Output): Connected to the LED via a current-limiting resistor.
  2. Pins 2 & 6: Tied together to the junction of $R_2$ and $C_1$.
  3. Pin 4 (Reset): Tied to VCC to prevent accidental resets.
Step 2: Calculating the Timing
The "On" time ($T_1$) and "Off" time ($T_2$) are calculated as follows:
$$T_1 = 0.693 \times (R_1 + R_2) \times C_1$$
$$T_2 = 0.693 \times R_2 \times C_1$$
With our values ($10M\Omega$ and $1\mu F$), the LED will stay off for roughly 6.9 seconds and blink for a fraction of a second, significantly extending battery life.
Step 3: PCB Layout & Soldering
Since the ICM7555ISA is an SMD (SOP-8) part, layout is compact.
  1. Keep High-Impedance Traces Short: The trace between $R_1$ and Pin 6/2 is sensitive to noise. Keep it as short as possible.
  2. Bypass Capacitor: Place $C_2$ ($0.1\mu F$) directly across Pin 8 (VCC) and Pin 1 (GND).
Step 4: Assembly Tip: Flux Is Your Friend
When soldering the ISA package, apply a small amount of tacky flux to the pads first. "Tack" one corner pin, align the chip, then solder the opposite corner. Once aligned, you can solder the remaining pins easily. Clean the board with IPA afterward; at $10M\Omega$, even finger oils or flux residue can alter your timing!
Step 5: Testing and Measurement
  1. Connect your $3V$ source.
  2. Use a multimeter in "Current" mode to measure the standby draw. You should see it idling in the micro-amp range.
  3. Verify the blink interval. If the blink is too dim, reduce the LED series resistor (since CMOS output drive is slightly weaker than bipolar).
Conclusion
The ICM7555ISA is a "sleeper" component. It looks like an old-school 555 but performs like a modern low-power supervisor. It’s a perfect bridge for engineers who want the simplicity of analog timing with the power specs of modern electronics.
Would you like me to generate a specific Bill of Materials (BOM) with manufacturer part numbers for this build?
