Introduction: Ultralight Backpacking Stove Only 3/8oz. (video Demo)
This stove has been made many times by many people. I have made several of them and I use it as part of my Ultralight Kitchen so I thought I would show how I do it.
Here is a link to my kitchen kit (https://www.instructables.com/id/4-34-oz-Ultra-light-Backpacking-Kitchen-video-de/)
The best fuel I have found for this stove is HEET - Gas-line Antifreeze & Water Remover. It is about $1.50 a pint and it is 99% methanol. You can get it almost anywhere, gas stations, supermarkets, parts stores. So if you are doing a long trek and you make stops in town to re-stock, you can always fuel up with no problem. As far as energy, 1 or 2 oz can usually boil 2 cups of water.
To use the stove, pour HEET in to the center section and light. Soon the methanol in the external chamber will vaporize and start to escape from the jet holes. These streams of vaporized methanol will ignite and will continue to burn until the fuel is gone. Below is a demo of this.
Step 1: Gather Materials & Tools
To build this stove you will only need 2 aluminum cans. Usually I use a Guinness can for the bottom section and a coke can for the top and ring. I have found that the Guinness cans are a little heavier and that they stretch better. In this instruction I use 2 coke cans. If you decide to make this stove I would suggest using a Guinness can for the bottom.
The tools you will need are as follows:
To score and cut the cans:
- Utility knife
- Large "C" clamp
- Razor blade
- Various pieces of wood to be used as spacers.
- Petroleum jelly
- Small piece of plywood
- 1 push-pin
- hammer
Step 2: Scoring and Cutting the First Can
This set up is to make the score line on the the first can.
1. Clamp a razor to your workbench 1.-1/4" above the surface of the bench.
2. With the can upright, slowly rotate the can against the razor with only slight pressure.
3. Once you have made several passes around move to the next step
4. Use the clamped razor to carefully puncture the can along the score.
Be ready with a sink or bucket or be able to get outside quickly. (things get messy here)
5. Carefully work your thumb in to the puncture as shown in the picture, and slowly work your
way around the can. The can should separate along the score line if it was done properly.
Step 3: Stretch the Bottom Section
Use the remaining unopened can to pre-stretch the top and bottom sections.
1. Rub a small amount of petroleum jelly on the bottom of the full can.
2. Carefully insert the bottom of the full can in to the cut bottom from the first can.
3. Using a small piece of plywood or the like, apply firm and even pressure to force one can in to the other.
note: Do this step incrementally; Press the can in a little way and let the pressure build up push it back out. then repeat until you can force the can about half way in to the bottom section.
Step 4: Score & Cut the Second Can
This set up is to make the score line on the the second can.
1. Clamp a razor to your workbench 1-1/8" above the surface of the bench.
2. Score the second can just as you did the first.
3. Use a utility knife to make a score line on the inside ring of the bottom of the can.
4. When the score line has weekend the bottom enough you will be able to push the bottom in to the can.
5. Use the clamped razor to carefully puncture the can along the score.
6. Carefully work your thumb in to the puncture as shown in the picture, and slowly work your
Step 5: Prep the Top Section for Assembly
It is necessary to reduce the diameter of the top section slightly, even though the bottom section was stretched.
1. Cut five or six 1/2" slits in to the side wall of the top section. Space them evenly around the circumference.
2. At the top of each slit use a hole punch to make a relief for the displaced aluminum.
note: the holes are very important. Without them a sharp point will develop and this will spit the bottom section when you try to assemble the stove.
Step 6: Cut Out the Ring Strip
1. Use a pair of scissors to carefully cut the side wall from one of the leftover cans.
2. Use a strait edge to true up one side with a utility knife.
3. Cut the strip to 1.5" wide. Take care to make the second cut parallel to the first.
4. Trim the 1.5" wide strip to 7"
5. Cut notches in to one side of the strip as shown below.
6. Cut a slit half way across each end so that they may be linked together. See picture for detail.
Step 7: Assembly of the Ring
Glue the ring together:
1. Do a dry fit to see that the ring links properly and that it fits in to the groove in the bottom section
2. Mix a small amount of JB weld epoxy adhesive and apply it to the end of the ring strip.
3. Link the ring together and tape it while you move to the next step.
Step 8: Assembly of the Stove
1. Apply JB weld to the groove on both cans and to the inside of the bottom section.
2. Place the ring, with the notches down, in to the bottom section.
3. Vary carefully insert the top section in to the bottom section.
4. Slowly and carefully squeeze the sections together until the ring is seated firmly in the upper and lower rings.
Step 9: Jetting the Stove
Use a push-pin to make 16 evenly spaced jet holes in the top of the stove.
To insure that they are evenly placed, follow the pic below.
Once the jets have been added and the epoxy allowed to cure over night, the stove is finished and ready to be used. If you like you can use a piece of 200 grit sand paper to buff the paint off and leave a cool brushed finish.
I have found that 16 jets is a fairly good number, more than that and the efficiency of the stove goes down. In the video below is a comparison between a stove with 24 jets (left) and one with 16 jets (right). As you can see the stove with 16 jets is burning in with a more focused pattern and the flame is an even blue for the most part.
