Introduction: Ultrasonic Sensor to Measure Water Height
How to easily build an sensor to measure water height.
Step 1: Step 1: Materials and Tools
Materials
- a Particle Photon
- a breadboard
- breadboard wires
- a micro-USB cable
- a red LED
- a green LED
- a yellow LED
- three 220 Ohm resistors
- a ultrasonic sensor (HC-SR04)
- Tupperware box
Tools
- Soldering iron
- Hot glue gun
- Wood glue
- Duct Tape
Step 2: Step 2: Soldering
Solder two breadboard wires to each led. This makes sure there is enough room to put the LEDS wherever you like.
Step 3: Step 3: Circuitry
- Connect the pin labeled “UCC”at the ultrasonic senor to pin 3V3 on the Particle Photon
- Connect the pin labeled “trigger” at the ultrasonic senor to pin D4 on the Particle Photon
- Connect the pin labeled “echo” at the ultrasonic senor to pin D5 on the Particle Photon
- Connect the pin labeled “GND” at the ultrasonic senor to pin GND on the Particle Photon
- Connect the green LED to pin to D0 with an 220 Ohm resistor in between
- Connect the yellow LED to pin to D1 with an 220 Ohm resistor in between
- Connect the red LED to pin to D2 with an 220 Ohm resistor in between
Step 4: Step 4: Code
Go to https://build.particle.io Before you put in the code you should add the library “HC_SR04 and
select it. You cannot just type “Include but have to realy include it in the created app from the library.
Use this code:
// This #include statement was automatically added by the Particle IDE.
#include
int cm = 0;
int trigPin = D4;
int echoPin = D5;
int Red = D2;
int Yellow = D1;
int Green = D0;
HC_SR04 rangeFinder = HC_SR04(trigPin, echoPin);
void setup()
pinMode(Red, OUTPUT);
pinMode(Yellow, OUTPUT);
pinMode(Green, OUTPUT);
void loop()
cm = rangeFinder.getDistanceCM();
if (cm<20 && cm>0){
digitalWrite(Red, HIGH);
digitalWrite(Yellow, LOW);
digitalWrite(Green, LOW);
Particle.publish( "distance", "HIGH water " + (String) cm);
else if (cm>40){
digitalWrite(Red, LOW);
digitalWrite(Green, HIGH);
Particle.publish( "distance", "LOW water " + (String) cm);
else if (cm==-1){
digitalWrite(Yellow, HIGH);
Particle.publish("distance", "ERROR " + (String) cm);
else {
Particle.publish("distance", "MEDIUM water " + (String) cm);
delay(3000);
