Introduction: Under Barrel Grenade Launcher for the MAR
About: I make K'nex guns, specializing in semi-automatic, RBG-Slingshot hybrid systems which i use in most of my guns. Note: I am not responsible in any way for any damage, injury, or death caused by my Instructable…
This is an Instructable for an under-barrel grenade launcher for my MAR. It launches grenades which throw fragments around the area of impact upon impact.
Note: The grenade launcher has a block trigger but since this is more of a secondary, special, or back-up weapon I guess it doesn't matter as much.
More Instructables by me.
Step 1: Making the Components
Make the following:
Picture 1: Make 2 (Lets for now call these part A).
Picture 2: Make 1 (Lets call this part B).
Picture 3: Make 1 (Lets call this part C).
Picture 4: Make 1.
Picture 5: Make 1.
Step 2: Construction
Follow the images:
Picture 1-2: Add "Y" clips where shown (there should be 8 of them).
Picture 3-4: Add the earlier made parts where shown.
Picture 5: Place white rods where shown.
Picture 6: Add the earlier made ram rod and add rubber band(s).
Step 3: Ammo
These are different types of ammo which can be used. These can be hard to make. I suggest first putting the spacers on the rod and putting the "Y" clips at the ends and using you fingernails or something thin to push the rod so both "Y" clips hold on. Then add the gray or metallic blue connector.
Step 4: Placing, Loading, and Firing
Lock the white rods so they connect into the grip as shown in image 1. Place the rubber band like in the 2nd image. Pull the ram rod back as in image 3 until the trigger blocks the rod from pushing the ammo out and place the ammo in the barrel. Push the trigger to the side to fire (Its a block trigger).
Warning- This may cause harm or injury if misused. Do not point it at people. I am not responsible for damage, injury, or death caused by this instructable.
