Introduction: Uninstall the Battery on BObsweep Pethair or Standard
Follow the video for full instructions on replacing bObsweep Pethair or Standard's Litium Ion battery.
For a text and photo version of this repair, see the rest of the steps in this guide.
Step 1: Remove BObsweep's Battery
Use a phillips head screwdriver to remove the two screws that hold the battery.
Lift the battery cover and the battery itself up.
Step 2: DIsconnect the Battery
Unplug the connector to remove the battery completely.
Using both hands, pinch the plastic connector where the battery's wiring attaches to bObsweep and pull apart to disconnect.
Step 3: Attach the New Battery
Connect the wires of the new battery. Push together tightly and it will lock in place.
Tuck the wires down inside the battery compartment on the left side.
Lower the battery down into bObsweep with the barcode facing up.
Step 4: Secure the Battery Cover on BObsweep
Lower the cover down so it lies flat and the screw holes of the cover line up with those on bObsweep.
Reinstall the two screws removed in step one to secure the cover and battery in place.
