Introduction: Universal Tool Holder
About: The Center for Discovery®, Inc. is a non-profit, nationally known provider of comprehensive healthcare services for 1,200 individuals with complex conditions, medical frailties, and Autism Spectrum Disorders. …
The Universal Tool Holder (UTH) enables individuals with decreased grip strength and hand function to hold and manipulate a variety of commonly used tools like paintbrushes, utensils, and toothbrushes, in different movement planes, enabling them to perform tasks more independently.
Estimated Build Time: 6.5 hours (3D printing 6hrs ; assembly 0.5hrs)
Tools:
  1. Pliers
  2. Small wire cutter
  3. 3D printer
Materials:
  1. PLA Filament (for "UTH Solid" print file)
  2. TPU Filament (for "UTH Flex" print file)
  3. Loc-Line 1/2 inch Ball Socket Flexible Tube 6 inch
  4. Black VELCRO strap with Neoprene 1"x8"
3D Print Files (STL & G-code):
Step 1: Before You Begin...
Print the UTH solid and flex as shown in the provided guide. A scaffolding will be needed on both prints. See manual for full assembly instructions.
Step 2:
3D print ("UTH solid.stl") in PLA with at least a 2mm wall thickness.
Step 3:
3D print ("UTH flex.stl") in TPU 95 with at least a 2mm wall thickness.
Step 4:
Clean and smooth all surfaces on all the objects from both prints.
Step 5:
Insert large flexible washer onto circular groove on PLA print where indicated.
Step 6:
Insert large TPU part into the two shafts on the PLA part where indicated, making sure to face the two thin arms in.
Step 7:
Insert six sections of 1/2 inch lock line onto PLA part where indicated.
Step 8:
Insert the small flexible washer on to the end of the lock line as indicated
Step 9:
Cut and remove the black plastic buckle from the Velcro strap as indicated.
Step 10:
Insert the small flexible washer into the Velcro strap as indicated, making sure the padding on the Velcro strip faces the lock line.
Step 11:
Thread the Velcro through the large flexible washer as indicated.
Step 12: Build Complete!
Your device is ready to use. If this interests you, give us a favorite, let us know if you made it, and drop a comment or any questions. Thanks for building with us!
DISCLAIMER: The Center for Discovery, Inc. (TCFD) works with Instructables to make the following information available for informational purposes only. TCFD, its agents, successors and / or assigns make no express or implied warranty of fitness or merchantability for any particular purpose for the items depicted. The reader should understand that the construction of this item is intended for use by an individual with cognitive or physical impairments (end user). This may pose a higher risk of injury to the end user. TCFD advises there is also a risk of injury to the individual constructing the device. The reader agrees to undertake the appropriate steps to lessen or eliminate risks of injury occasioned by the construction or use of the items depicted. Any and all losses, injuries or damages incurred by or resulting from the use of the information in this publication are the sole responsibility of the reader and end user, all of whom voluntarily, expressly and completely release, forever discharge, and agree to defend, indemnify and hold harmless TCFD, its agents, successors and / or assigns, from any and all claims, demands, or causes of action, which are in any way connected with the use of the information contained in this publication.
