Unskinny Bot: 3-lb Horizontal Spinner Combat Bot
Intro: Unskinny Bot: 3-lb Horizontal Spinner Combat Bot
This is my fourth Beetleweight (3-pound) combat robot and, hopefully, the first with a usable weapon. Let's just say those earlier attempts at weaponized 'bots were "learning experiences"...the kind where you go home and hope you can salvage it for parts. On the other hand, my bot #3 has held up well in combat over the last year, but it's a wedge, so this is my attempt to level up and throw some non-boring into the mix.
"Unskinny Bot" is my take on the tried-and-true horizontal bar spinner, just a rectangular chunk of metal that spins really fast and (hopefully) does a lot of damage to the other bot.
It will debut at Robot Battles 47 Microbattles at Dragon*Con in September 2013.
STEP 1: Design
I spent a lot of time modeling it in Sketchup before even ordering parts. Attached is the CAD file (in Sketchup) for the 'bot. Some notes about the design:
- dead shaft for the weapon: This means the weapon shaft doesn't rotate; instead, the weapon blade and weapon pulley (which are bolted together) spin around the fixed shaft. There were a couple of reasons I chose this arrangement. First, that having the dead shaft clamped to the armor at the top and bottom might make it easier to change a weapon belt during competition. And second, it would have required some machining beyond my abilities and equipment to build a keyed weapon shaft with high-speed bearings at the ends.
- it had to fit within the milling limits: which are about 11"x5" for the machine to which I have access
- battery cover for quick battery access: very important during competition!
- power switch: the rules require this if a bot has a powered weapon. I always forget this until it's almost too late...
STEP 2: Materials and Tools
Materials
- (1x) 16T Fingertech timing pulley
- (1x) 42T Fingertech timing pulley
- (1x) 300mm Fingertech timing belt
- (1x) Fingertech power switch
- (1x) Turnigy Park300 1600kv brushless outrunner motor
- (1x) 30A brushless ESC
- (1 pack of 2) Kitbots B16 motor mounts
- (1x) 3/8" ID needle roller bearings, McMaster-Carr p/n 5905K22
- (2x) Beetle B16 gearmotors
- (1x) Futaba R2004GF radio receiver
- (2x) ServoCity.com 3/8" bore set-screw hub clamps
- (2x) Banebots bb-3-9 brushed ESC
- (1 package of 2) LiteFlite 2-1/2" wheels
- (1 package of 2) Dave's Hubs, 4mm bore
- 12"x12"x3/16" Al-6061 plate
- 2"x36"x3/8" Al-6061 bar (McMaster-Carr p/n 8975K593)
- (3 ft) 3/8"x1-1/4" UHMW polyethylene bar (McMaster-Carr p/n 8702K731)
- 3/8"OD x 12" hardened steel shaft (McMaster-Carr p/n 6061K32)
- (1 box of 50) 18-8 stainless steel plastite screws, 6-19 thread, 3/4" long (McMaster-Carr p/n: 96001A268)
- (1 box of 50) grade-8 6-32 5/8" cap screws (McMaster-Carr p/n 91251A150)
- (1x) Turnigy 1000mAh 3S 30C Lipo battery pack
- CNC milling machine
- drill press
- miter saw
- hand files
- transfer punch set
- center punch
- scratch awl
- Sharpie
- Torx screwdrivers
- tap & die set
- utility knife
- try-square
- hex keys
- soldering iron
- rotary tool
- pipe cutter
- angle grinder
STEP 3: Milling the Armor
Tools This Step
I have access to a small CNC milling machine at the university where I work. I used it to cut out the top and bottom armor plates from 3/16" 6061-Al plate. The last picture shows the top armor and the (old) battery cover after milling. All the milled pieces required some hand filing to remove burrs, soften edges, etc.
I have attached DXF files for the armor pieces to this step.
- hand files
- 3/16" aluminum plate
STEP 4: Frame Assembly
Tools This Step
I laid out the electronics and motors for fit, and used that to choose the location of and drill the holes for the motors.
The motor and motor mounts are assembled and attached as shown in the pictures.
With the wheels and hubs assembled and in place, I sized the rear bulkhead so that it sticks about a wheel's thickness beyond each wheel. This gives space to easily remove and replace wheels during competition as well as provide more buffer between the wheels and the side armor. More buffer means that opponent's spinning Blade O' Death has to push farther to take out my wheel...
- drill press
- utility knife
- cutting board
- try square or other metal straightedge
- torx screwdrivers
- miter saw
- milled armor plates
- UHMW bar
- motors
- motor mounts
- plastite screws
STEP 5: Wheel Guards
Tools This Step
First, I cut the front wheel guard supports from short scraps of UHMW bar, drilled pilot holes, and attached them to the side bulkheads with plastite screws. (If I had to do this over I would have designed it such that those guards were a single piece going across the bot, boxing in the electronics and firewalling them away from the weapon motor.)
Then I took some scraps of 1/8" thick UHMW plate and traced a wheel on it as shown in the pictures and then screwed the plate to the front and rear wheel guard supports so I could finish tracing the wheel guard profile. Then I cut it with my bandsaw. Repeat for the other wheel.
- drill
- red Sharpie
- utility knife
- bandsaw
- cutting board
- torx screwdrivers
- miter saw
- UHMW bar
- 1/8" thick UHMW plate
- plastite screws
STEP 6: Attach Weapon Shaft Collars
Tools This Step
The shaft collars are pre-tapped, but my design calls for the armor to be tapped and not the collars, so I drilled them out just enough to slide a 6-32 bolt through.
My CAD file has a too-small weapon shaft hole in the top and bottom armor plates, so I bore it out to 3/8". Tighten one of the shaft collars onto the shaft and slide the other end of the shaft into the bottom armor plate. Use a transfer punch to mark the corresponding hole positions on the armor plate; drill and tap these to accommodate a 6-32 bolt. Repeat for the top armor.
Fasten the collars to the armor with grade-8 6-32 cap screws. Also, replace the stock clamping screw in each collar with one of the grade-8 cap screws. Can't hurt to make things a little stronger...
It's really annoying to have to deal with that long piece of weapon shaft...maybe I'll get around to cutting it one of these days...
- drill press
- tap & die set (with a 6-32 tap)
- hex keys
- shaft collars
- 3/8" shaft stock
- 6-32 cap screws
- tapping fluid
STEP 7: Frame Assembly, Part 2
Tools This Step
Begin by threading the weapon shaft through both armor plates (and their shaft collars). This forces both the top and bottom armor plates to be aligned on the weapon shaft.
Now mark the bulkheads and drill pilot holes based on the corresponding top armor holes. Fasten with the plastite screws.
Finally, drill pilot holes for the battery cover and attach with plastite screws. I also added 6-32 washers.
Still need to cut that weapon shaft...
- Torx screwdrivers
- hex keys
- drill press
- plastite screws
STEP 8: Annoying Shaft: BE GONE!
Tools this step
- clamps
- angle grinder with metal-cutting blade
- 3/8" shaft
STEP 9: Weapon Blade
Tools this step
Materials this step
I used a hacksaw and file to remove the set-screw nub from the timing pulley. Then I drilled a single hole (with a bit intended for 6-32 tapping) as shown in the second picture.
Then I measured and cut a 6" piece of the Aluminum bar using the miter saw and drilled a 1/8" hole dead center. I used the drill bit as a temporary axle to mate the bar and pulley along their common axis. The third picture shows this from the back side of the blade. While these were together, I put the 6-32 drill bit in the pulley's off-center hole and rotated the pulley: this scratched a nice circle on the blade, a circle that is where all my pulley-to-blade fastening holes will be. Once done, I tapped the single pulley hole to 6-32 thread.
Next, I drilled four holes in the blade, big enough to accommodate 6-32 screws a little loosely. I used the inscribed circle to guide them (as in the third and fourth pictures). Attached the pulley to one of the holes (again, using the 1/8" drill bit to keep the center holes aligned) with a cap screw. Used a transfer punch to locate the remaining three holes on the pulley, which were then drilled and tapped for 6-32 thread.
Then I attached the pulley to the blade with all four screws. It may be necessary to make the holes in the blade a little bigger so as to adjust for alignment. Finally, I drilled the center hole of both the blade and pulley -- at the same time! -- to 9/16" so as to accommodate the roller bearing. (Since I wanted this hole to be as precise as I could get it, I enlarged it a little at a time, in increments of about 1/8" diameter each time.)
Finally, I assembled the blade as shown in the last pictures. I cut down some bronze bushings to keep the blade at the proper distance from the top and bottom armor pieces.
- drill press
- files
- try square
- miter saw
- scratch awl
- center punch
- hack saw
Materials this step
- 2" wide by 1/4" thick Al bar
- Fingertech 42T timing pulley
- 6-32 cap screws
- roller bearing
- 3/8" inside diameter bronze bushings (with flange on one end)
STEP 10: Weapon Motor Mount
Tools used this step
Basically I took a scrap of angle Aluminum and drilled the motor mount pattern on one leg and drilled holes for attaching it to the UHMW riser block on the other leg. Then I hacksawed and filed to get the bracket to fit in the space required.
The critical measurement here is the distance between the motor and the blade. My design does not have a belt tensioner, so the motor must be placed so that the belt has enough enough tension to not slip off either pulley.
(If I were to do this over I'd mount the weapon motor to one of the side bulkheads instead of in the center of the bot.)
- Miter saw
- metal files
- drill
- countersink bit
- hacksaw
- brushless motor
- UHMW bar
- angle aluminum (just a small scrap is enough, should be about 1.5" wide by 1.5" tall by 1/8" thick)
- random bolts (probably 6-32) to hold the bracket
STEP 11: Electronics
Tools this step
- soldering iron
- screwdriver
- 4-40 tap
- 30A brushless ESC (for the weapon motor)
- battery
- battery connector
- (2x) BB-3-9 ESC (for the drive motors)
- Radio receiver
- power switch
- connect the weapon ESC output wires to the weapon motor
- connect the left and right drive ESC output wires to their respective drive motors.
- connect together the positive power wires of all three ESCs and route to one leg of the power switch
- connect the other leg of the power switch to the positive of the battery connector
- connect together the ground wires of all three ESCs and route to the ground of the battery connector
- plug the servo-style cables from the ESCs into the radio receiver. For the receiver I used, the drive motors are on channels 1 and 2 and the weapon is on channel 3.
STEP 12: Battery Cover
This is pretty quick and dirty simple. Just a scrap of 1/8" thick UHMW screwed to the armor to cover the battery access hole. It works. :)
STEP 13: Finished!
STEP 14: Appendix: the Original Drive Train
I left the pictures for this step in case anyone wanted to see how the belt-driven version of the bot would (should) have looked...
42 Comments
AnhN95 5 years ago
Do you have a design more details?
Thanks
lewisb42 5 years ago
There should be enough detail in the instructable to build it from scratch (others have done so), but if you have specific questions I'd be glad to help if something's unclear.
AnhN95 5 years ago
It only has two wheels, so how to move without being rubbed to the ground?
AnhN95 5 years ago
aaronanger3000 7 years ago
im having trouble downloading the files..could someone tell me whats the final length and width of the top and bottom plates please
lewisb42 7 years ago
It's about 10-7/8 inches long by 4-1/4" wide.
If you like, email me at lewisb42 AT yahoo DOT com and I'll send the files (if I still have them...)
bharadwaj123 8 years ago
What is the best motor that to be used for a horizontal spinner
MicheleG32 8 years ago
where can I buy one of these
lewisb42 8 years ago
I don't know of any horizontal spinner kits, but there is a vertical spinner kit here:
http://www.kitbots.com/product.sc;jsessionid=B3FB80A382A1B4D005A6F578675E2F5C.m1plqscsfapp01?productId=19&categoryId=1
and a wedge kit here:
http://www.shop.rovparts.com/D2-Combat-Robot-Kits_c7.htm
bumbolbee 8 years ago
hello can i ask about combat robot cause my father is a technician what can i do to his scrap material
HI I am a NEW her can you help me ALL to make a new combat robots i am a filipino if can you suggest
WarriorBeast 8 years ago
thats a lotta wires
awsome ninja 9 years ago
lewisb42 9 years ago
The upside is that, upon switching to a direct-drive scheme, I had some weight left over for wheel-guards.
The Lightning Stalker 10 years ago
It has more mass.
It is less likely to snap and send chunks flying.
It is much cheaper.
It is harder.
Just my 2¢
