Up Out of the Way Wire Dispenser
Intro: Up Out of the Way Wire Dispenser
This is an addition to my other instructable HIDE N SLIDE
https://www.instructables.com/id/Hide-N-Slide/
i needed the wire to be at the bench but had no room for it so this is what i came up with
ALWAYS USE YOUR SAFTEY EQUIPMENT
tools i used for this project is as follows:
SAFETY GOOGLES
GLOVES
screwdrivers
drill
cicular saw
jig saw
1/4 inch drill bit
measureing tape
square
materials needed :
one pack of drawer slides (you get 4 in the package )length will vary depending on your space
wood
package of 1 1/2 in L brackets
2 shower door rollers
4 #6 x 1 1/2 flathead screws
2 flat washers to fit #6 screw
wooden dowel rod to fit your spools of wire
Allot of patients :>)
Optional materials
sheet metal
SAFETY GOOGLES
GLOVES
screwdrivers
drill
cicular saw
jig saw
1/4 inch drill bit
measureing tape
square
materials needed :
wood
Optional materials
sheet metal
STEP 1: Step 1
first i measured my area and made note of it
then i took the two rollers i was going to use and removed the roller by drilling the rivit out
{ be careful of this part as the ball bearings will fall out }
STEP 2: Step 2
i measured 1 1/2 inches from the back on both sieds and marked them
i installed the roller brackets on each side { the roller brackets will start from the back on the marks you made }
make sure that the roller brackets are as flush as possible to the bottom
STEP 3: Step 3
i then measured the are between my now installed roller brackets and subtracted 1/4 inch from it
the length of the board will vary depending on your space and your plans
i cut the board to my measurements
i then measured out the area that i would need to accommodate the spools of wire that i have
i cut out the hole with a circular saw and finished off the corner cuts with a jig saw
i then installed the two back rollers three inches from the back
STEP 4: Step 4
i cut 2 1 1/2 in side runners for the rods that will hold the spools of wire
i then measured out the area and drilled out four holes for the rods
: note only going half way thru the board
i then took a dremel and sloted one side so i could easily remove the spools and replace wire when needed
STEP 5: Step 5
i drilled three holes in each side runner as to not split the wood when i installed them
i sued a countersink to make the screws flush with the board
i installed both sides makeing sure not to tighten them to tight so i wouldnt split the wood
STEP 6: Step 6
i then two rods to fit into the sides
about an 1/8 inch shorter than the distance
I then insalled the front two rollers and test fitted the board
STEP 7: Step 7 ( Optional )
i then took a piece of sheet metal and made a box to hold wire connectors
STEP 8: Final Step
i put the spools on the rods and inserted them into the board
than i put the board into place
now your done
thanks for looking
and i hope someone can use this
REMEMBER TO WORK AND PLAY SAFE :>)
BATTERIESNOINCLUDED
now your done
thanks for looking
BATTERIESNOINCLUDED
22 Comments
SicknTwisted 11 years ago
RangerJ 11 years ago
Dark Light 11 years ago
batteriesnotincluded 11 years ago
thank you
007kramerica007 11 years ago
and you are correct about the lighting
i installed candeler lights in between the joists
mugidude 11 years ago
im not that organized just enough tho
lime3D 11 years ago
this is not in the ceiling
the drawer sldies let me get the specialty tools up out of the way but also within hands reach
there is also wire connectors stores on the board above
yes your idea would work just fine if that is all you wanted in that space nut my goal is too get as much as possible off my work space
hope this helps you
Manny B 11 years ago
mattsouthgate 11 years ago
Matt
lionel1024 11 years ago
Everfalling 11 years ago
barista 11 years ago
Detailed, well thought out, instructable.
Spoiled only by the poor spelling.
Dominic Bender 11 years ago
good question Satrek
yes you could mount the coils of wire below the board , but it depends on your space you have when you swing the board down to access the tools you have on it
in my situation i have shelves below that was the reason for the cutout
chinchymork 11 years ago
now could someone call my wife and tell her that i do have good idea,s sometimes lol
