Introduction: Upcycle Your Firepit Into a Table
Step 1: Supplies
For this project I used some composite decking material and a old fire pit stand, all stuff that I got out of a dumpster. I also used wood screws and four right angle brackets.
Step 2: Table Top
First I cut the decking material to about the size that I need it, then I laid the pieces in to a square. I traced the fire pit stand circle onto the decking material. Using a band saw I cut out the shape of table top, screwed all the pieces together. I used extra pieces of decking material on the bottom of the table top for support.
Step 3: Table Base.
On the fire pit base I drilled four holes in the center/top edge of the legs and bolted on the four right angle brackets.
Step 4: Finishing
After both the stand and the top was finished I bolted on the table top to the stand using the four brackets. I then sanded down the edge of the table until it was smooth. Final touch paint the stand with a new coat of black paint.
This was a nice easy afternoon project that did not cost any money, everything I used, I found out for the trash or was leftover from another project.
