Introduction: Upcycled Polka Dot Mini Dress
I recently bought a long pattern dress from a local thrift shop and I really liked the fabric and pattern of it but not the style, I thought I could make into something I would wear and make it into an upcycled mini dress with crisscrossing straps
Materials Needed:
- Polka Dot Dress
- White Thread
- Scissors
- Measuring Tape
- Fabric Chalk
- Ballpoint pins
- Rotary Cutter
- Needle
Step 1: Step 1: Deconstructing the Dress
Step 1: Cut the seams and remove the lace
- Cut the lace from the dress
- Cut the stitching from the side of the dress
- Lay the dress flat
- Cut the straps
Step 2: Step 2: Measurements
- Measure your waist, bust, and hips
- Measure the desired length of the dress
Step 3: Step 3: Outline the Dress
- Lay both sides of the dress inside out on top of each other
- On the front side of the dress, mark how deep the sweetheart neckline should go
- Use the fabric chalk to mark the measurements
- Use those markers as a guide to draw the general shape of the dress
- Pin the dress together
- Use a rotary cutters to cut excess fabric, allowing for some seam allowance
Step 4: Step 4: Sewing Everything Together
- Sew the sides of the dress together with a backstitch
- Hem the neckline by folding it and pinning it then sew with a backstitch
- Hide the stitches by folding it again and using a cross-stitch (make sure to go through a thread and not the entire fabric)
- Hem the bottom of the dress by folding it twice and sewing with a cross-stitch making sure it’s not visible on the outside
Step 5: Step 5: Make the Straps
- Use the lace as a guide on how long to cut fabric for the straps
- Fold both raw edges in and hold in place with pins
- With a cross-stitch sew the raw edges together
- Place the lace on top of the fabric and pin together
- Sew together with a running stitch making sure the stitches aren’t showing on the outside
- Secure with a cross stitch
- Repeat for the second strap but make sure to put the lace on the opposite side of where the lace on the first one is
Step 6: Step 6: Sewing the Straps On
- Keep the dress inside out
- The straps would be crisscrossing each other in the back
- Pin one end of the strap to the front and the other across the back of the dress
- Do the same with the other strap but mind the placement of the lace
- With a backstitch sew the end strap along the edges of the dress (make sure the stitches aren’t visible)
Step 7: Step 7: All Done
Fashion Contest
3 Comments
Question 2 years ago on Step 7
wonder if you could add support for braless??
3 years ago
This is super cute!
Reply 3 years ago
aw thank you 💛💛
