Introduction: Upcycling Bottles to Lamps
Looking to make something of those old bottles? Want a fun DIY gift for any time of the year? Lets get creative!
What you will need:
- Empty bottle
- Dremel
- Glass Cutting Bit
- Screwdriver
- Bottle Lamp Kit
- Cord Switch
- Grommet
- Bulb
- Shade
- Filler
- Funnel
- Wrench
Step 1: Drill Bottle
After selecting a bottle the first step is to decide where to drill a hole. It is important to choose a spot that is not too close to the bottom to avoid cracking it. I generally use a piece of tape but that is not required although highly recommended.
Mark where you plan on drilling and begin drilling. I also recommend using running water while drilling to prevent the bottle from cracking. I have cracked many bottles with or without water, however water helps significantly. Be sure to apply light pressure while removing the Dremel every few seconds and repeating the processes until through.
After you have drilled a clean hole, switch to a larger drill bit in order to widen the hole to fit the grommet.
Step 2: Wire Bottle
This step varies depending on the size and the shape of the bottle:
Take the grommet and snake the wire through the hole until the grommet is more than the length of the bottle down the wire.
Take the cut end of the wire and snake it through the drilled hole and through the top of the bottle. Be creative with snaking it, remember gravity is your friend. However a coat hanger can be used to grab the wire if that is easier.
Take the grommet that is on the wire and place it in the hole until it is nice and snug.
Step 3: Fill Bottle
It is very important that the wire is snaked through the bottle before filling it with stones (or whatever you choose) because there will be no way to snake the wire once filled.
In this example, I used a funnel to place the small stones but that is dependant on what you are filling the lamp with.
Once the lamp is filled up to the neck it is important to tap the bottle on the table in order to let the stones settle.
Refill what space is now there and repeat the process.
Step 4: Prepare Cork
For this step you will need the threaded tube, two nuts, and cork piece.
Take one nut and place it a few rotations from the end of the tube.
Next take the cork and place it over the tube using the nut as a stopper.
Now take the second nut and screw it on the top of the cork until snug. Do not tighten too much otherwise it will expand the cork.
After preparing the cork piece thread the wire through the tube.
Insert cork into top of the bottle.
This is where tightening the top bolt is okay. The more you rotate the nut the tighter it will be on the cork forcing it to expand outward making am extremely snug fit
Step 5: Prepare Socket
This step may vary depending on the socket kit you are using:
Take the wire and place it through the socket base
Attach the switch
Split the wire until you are able to wrap each comfortably around the two screws
Take a screwdriver and tighten until the screw is snug against the wire and its base
Cover the switch with the sleeve
Cover the sleeve with the socket shell
Step 6: Pull Wire
This step takes a little bit of patience and elbow grease
Pull the wire from the grommet hole until the socket is snug with the cork
Step 7: Prepare Light Switch
This step is also dependent on the type of cord switch you choose.
Open cord switch
Cut ONE of the two wires and place it into cord aparatus.
I repeat cut ONE of the TWO wires. If you cut both then you will have to start from scratch and rewire the entire bottle.
Cover the switch and screw tight
Step 8: Bulb and Shade
Decide what wattage and bulb you want to use
Be sure to choose a shade that fits the bulb you have
Step 9: Turn On!
Plug the lamp into the wall
Prepare to be amazed
Turn on the lamp
Let there be light!
Lamps and Lighting Contest 2016
