Upside Down Pear Cake Baked in a Cast Iron Skillet
3,069
26
10
Introduction: Upside Down Pear Cake Baked in a Cast Iron Skillet
About: Hello! My name is Jenya. I love to teach people how to cook, so I started a food blog where I share spectacular recipes and step by step instructions. Visit me at BlueGalley.com and follow my delicious instruc…
Did you know that you can bake pretty much anything in your cast iron skillet? If you don’t already own one, a cast iron skillet is one of the greatest purchases you can make for your kitchen. I use mine more than any other pan and have baked everything in it from chicken pot pie, to lasagna, to bread and many desserts.
Here I show you how to make one of my all time favorite winter comfort sweets: a scrumptious upside down pear cake. Right now is the time to make this! Pears are in season and at their best, plus your family and friends are in need of some serious food comfort during these cold winter months. The sweet caramelized pears and fluffy light cake combo is a match made in heaven, especially with a scoop of vanilla bean ice cream and a dollop of whipped cream.
So grab your cast iron skillet, get some delicious, perfectly ripe pears from your local market and bake this immediately! If you’re not a baker and have never made a cake before, this is a great recipe to start with…especially since I walk you through it step-by-step. Enjoy!!
Note: if you don’t have a mixer, no problem! You can use a good old bowl and whisk. Just make sure you switch arms so you don’t get too bulky on one side from whisking ;)
Step 1: Gather the Ingredients
For the Pears:
  • 3 ripe pears (preferably Bartlett or Anjou varieties)
  • 1/2 cup (packed) light brown sugar
  • 1/2 stick of butter
For the Cake:
  • 1 and 1/2 cups all-purpose flour
  • 2 tsp baking powder
  • 1/4 tsp salt
  • 3/4 tsp ground ginger
  • 3/4 tsp ground cinnamon
  • 1/4 tsp ground cardamom (optional, but highly recommended!)
  • 1 stick of butter (softened to room temperature)
  • 1 cup sugar (granulated, white)
  • 1 tsp vanilla extract
  • 2 large eggs (yolks and whites separated)
  • 1/2 cup whole milk
  • 1/4 tsp cream of tartar
Special Equipment:
  • A large cast iron skillet
  • A mixer with paddle attachment (or a large bowl with a whisk)
  • Lots of love :)
Step 2: Make the Caramel for the Pears
  • Preheat oven to 350 degrees
  • Add the 1/2 stick of butter to the skillet, turn the heat to low and melt the butter, helping to spread it in the skillet
  • Add the brown sugar and stir with a spatula until it is dissolved in the butter
  • Move the pan around until the butter / sugar coat it evenly
  • Turn off heat while you prepare the pears
Step 3: Prepare the Pears:
  • Wash and peel the pears
  • Halve them lengthwise
  • Core the pears (either with a corer tool or a small spoon)
  • Place the pears cut side down on a cutting surface and cut crosswise into 1/4th inch thick slices
  • Arrange the pears over the butter / sugar in the skillet, creating as pretty of a pattern as your patience allows
  • Set the pan aside while you make the batter
Step 4: Mix the Dry Ingredients:
  • In a medium to large bowl, mix the flour, baking powder, salt and spices together (this is best done with a whisk, but you can also use a spoon or large fork)
  • Set the bowl aside
Step 5: Mix the Butter and Sugar
  • In a mixer with a paddle attachment (or bowl with whisk) cream the butter with the sugar until light and fluffy on medium speed (about 2 minutes in mixer and 5 with whisk)
  • Add Vanilla extract and mix just to combine
Step 6: Add Egg Yolks
  • If you haven't done so already, separate the yolks from the whites, reserving the egg whites in another large bowl
  • Add the yolks, one at a time, to the butter and sugar. Mix after each addition to combine before you add the next yolk
Step 7: Add the Dry Ingredients and Milk:
  • Now add 1/3 of dry ingredients to the butter and mix 10 seconds to combine.
  • Next add 1/3 of the milk and mix a few seconds
  • Again, add half of what's left of dry ingredients and mix 10 seconds to combine, followed by half of the milk and mix again
  • Repeat with remaining dry ingredients and milk
Step 8: Beat Egg Whites and Fold Into Batter:
  • Now comes the slightly tricky part: beating the egg whites. You can use the mixer with a whisk attachment, a separate hand-held mixer or again... a good old whisk
  • Beat the egg white with the Cream of Tartar until "stiff peaks" form as shown in picture. You want them to stay pointy on the whisk, but still remain fluffy and soft. DO NOT OVER BEAT! The time varies for this, depending on speed and tool used. It is ok to stop and check the peaks. If they are holding peaks when the whisk is upside down, they are done. If peaks are holding for a second and then falling over, beat a bit more. It's just practice, eventually you'll be a pro at peaks! :)
  • Gently fold the whipped egg whites into the batter with a spatula
  • DO NOT MIX TOO MUCH!!! What makes the cake fluffy is the airiness of the egg whites, so just gently incorporate them into the batter
Step 9: Spread Batter Over Pears:
  • Using a rubber spatula, transfer the batter to the skillet
  • Spread the batter as evenly as possible over the pears, being careful not to move them
Step 10: Bake the Cake:
  • Place the skillet into middle position of oven and bake until the top is a slight golden brown, or until a toothpick inserted in the center comes out clean. This should take 40 to 50 minutes
  • Remove skillet from oven and let the cake cool for 10 minutes
  • Run a knife along the sides of the pan to loosen the cake slightly
  • Place a large plate or platter over the skillet and carefully invert the cake into it, it should invert very easily
Step 11: Slice and Serve!
  • Serve the cake with some vanilla ice cream and / or whipped cream
  • I promise this cake will become one of your favorite winter desserts...it is SO GOOD!!!
Baking Contest 2016
Second Prize in the
Baking Contest 2016
Be the First to Share
    • For the Home Contest
    • Make It Bridge
      Make It Bridge
    • Game Design: Student Design Challenge
    10 Comments
    Cherzer
    Cherzer
    6 years ago
    Yummy! I have a pear tree in my back yard always loaded with pears.... and squirrels. I'm going to have to fight those furry rascals next year for a few pears to make this. :)
    Cherzer
    Cherzer
    Reply 6 years ago
    Thanks for the pear info! There is a good chance it was started from a seed (as so many of my neighbors do), so I'm not sure if it is a true specific variety. I did find this photo I took last year to send to my mom. Also, they never seem to change color, so I suspect they are an Anjou. ??? I'll have to check again next fall. Thanks again! :)
    Blue Galley
    Blue Galley
    Reply 6 years ago
    Haha, yes... fight the squirrels, this cake is worth it!
    MollyA20
    MollyA20
    6 years ago
    I have made a cake very similar to this Pear Skillet Cake, I will probably try this one also!
    http://canadaessaywriting.com/custom-essays
    Blue Galley
    Blue Galley
    Reply 6 years ago
    Let me know how it turns out Molly, thanks!
    offseidjr
    offseidjr
    6 years ago
    Looks so GOOD!!!
    Blue Galley
    Blue Galley
    Reply 6 years ago
    And it tastes even better :)
    Cheeky_Tinkerer
    Cheeky_Tinkerer
    6 years ago
    Thanks for the recipe! This was really yummy! I will be making it again. I made it for my Mother in-laws Birthday, it went perfectly with the Vanilla Bean Ice Cream my wife made. The cake all got eaten before I was able to take a picture.
    Blue Galley
    Blue Galley
    Reply 6 years ago
    Hi Cheeky, I'm SO happy to hear that you made the cake and it was a success! You can use the same recipe for peaches as well in the summer. Just slice the peaches and cook in the same way. Thanks for the nice comment :)
