Introduction: Urban Altoids Survival Kit
This article seeks to expose for you a kit I've designed (and continue to work on) that compromises some worst-case scenario type needs with needs I actually have RIGHT NOW. I still don't use it very often, but when I do, I'm very glad to have it.
Step 1: Exterior
Step 2: What's on Top
Step 3: Some Stuff...
Contents revealed:
* "Write in the Rain" waterproof paper, available at many outdoor stores (such as Mountain Equipment Co-op here in Canada). Not very expensive for such cool, exotic gear
* $5 Cash, various obvious uses: purchase a meal, take a (very short) cab ride, etc etc....
Step 4: Some More Stuff...
More stuff.
* Compass keychain from Suunto, a nice little multi-purpose device that keeps me warm at night because I'll always know which way is north...for all the good that'll do.
* Pills to make the voices in my head go away for a while
* Quarters to make phone calls (or spare change), and two bus/subway tokens to get home, or somewhere and then back
* Tiny box of matches, because gasoline doesn't set itself on fire and how else are you going to get enough insurance money to start a new life, huh? Huh??
* Krazy clue: for binding wounds, attaching things together to form a wikid awesome jerry-rigged survival gadget in the field or....just exploding inside the box and sticking all my survival stuff to the inside of an altoids box. Yay!
Step 5: Even More Stuff...?
* Blinking LED light
* Teeny-Tiny 1cm utility knife thing, for hijacking airplanes or just making airport security act even NICER to me...
* Post-it notes, because there's never a "sticky" handy when you need one.
* A pencil, to avoid embarrassment at having brought post-it notes to the nuclear wasteland but nothing to write with. Can't you just imagine that happening?
* Cable ties. I foresee the mad-max post-apocalyptic world as having far more cable-tying-up needs than most people anticipate. So now when it comes...I'll be ready.
* Really, does the antiseptic towelette need explanation? Does half the stuff in this kit?
Step 6: Ok, Enough Stuff Already!
* A actual, semi-functional human brain. Don't try fitting this in an Altoids tin--even if you take a lot of other stuff out and squish it down really hard, it won't fit. Just keep it someplace else and use it often.
* An unnecessarily cool "tactical" flashlight, in a cheap-ass Chinese holster that'll probably fall apart and make me lose the flashlight a before I REALLY need such a device
* A folding knife with one of those flint-striking-makes-sparks-go-zing tools attached. And a cheesy little whistle for some reason.
* Awesome looking Gerber multi-tool thingie.
Improvements I'll have to make:
* Carefully folded tin foil: the only known way to stop the CIA sending encrypted transmissions to your brain through the fillings in your teeth. "The CIA cafeteria menu for the week of June 6th is as follows...Monday--shepard's pie..." Make it stop!!
* Other stuff which has now escaped my mind.
