Introduction: Use Arduino MKR Shields With Raspberry Pi
Our PiMKRHAT is an adaptor HAT to use Arduino MKR boards and shields together with the Raspberry Pi. Different Arduino MKR Shields can be used via our HAT as extension for the Raspberry Pi. I want to show in this small project how to use the Arduino MKR ENV shield with a Raspberry Pi under Python.
Step 1: Tools and Materials
Materials:
- Raspberry Pi
- SD card
- Arduino MKR ENV shield
- PiMKRHAT
Tools:
- Soldering iron
- solder wire
- side cutter
- bending tool
Step 2: Assembly
The PiMKRHAT comes as kit. You have to assemble it first. Please follow the attached assembly instruction
Step 3: Jumper Setting
Please set for the Arduino MKR ENV shield only the 5V and 3, 3V Jumper on the Power jumper bank. Leave all other jumpers open.
Step 4: Raspbian
Please download the latest Raspbian OS for the Raspberry Pi and copy it to an SD card via Pi imager or Win32diskimager.
Step 5: Configuring I2C
The sensors on the MKR ENV shield are using I2C communication. You have to install some libraries first via the bash:
sudo apt-get install -y python-smbus sudo apt-get install -y i2c-tools
Now you have to enable the I2C interface:
sudo raspi-config --> 5 Interfacing Options
--> P5 I2C--> YES
sudo reboot
Step 6: Testing I2C Interface
Now it's time to test the I2C interface:
sudo i2cdetect -y 1
This shows that three I2C addresses are in use – 0x10, 0x5c and 0x5f
Step 7: Install Additional Libraries
sudo apt install python-pip sudo pip install veml6075
Step 8: Test Your Work
3 little Python programs are available on Github to test the UV radiation, temperature & humidity and pressure sensor of the MKR ENV shield:
- HTS221.py -temperature and humidity
- LPS22HB.py - pressure
- VEML6075.py - UV radiation
The analogue light sensor requires an analogue input and can not be used with the Raspberry Pi.
