Introduction: Use Arduino and RS232 Shield to Interface Integrated UHF RFID Reader LSID-0702
Long Range UHF RFID reader (1-6M) (ISO18000-6C EPC G2) integrates
the reader with the antenna. After first powered on, the reader will buzz once to indicate that it starts to work. When there is tag approaching the reader, it will buzz to indicate that it’s sending the data. For the same tag, the read interval can be configured. After read, if the same tag is still in the read area, there will be no further indication, and no data will be sent. If the time lapse exceeds interval or different tags enter the reading zone, the reader will read the card and send out data.
In this tutorial, we show how to use the integrated UHF RFID reader with Arduino and RS232 Shield.
Step 1: Step 1: Part List
Step 2: Step 2: Wiring Diagram
Install RS232 Shield v2 on Arduino, and connect the DB9 of RS232 shield
to the DB9 connector of the RFID reader, and supply power to the integrated RFID reader.
In the Arduino code, we will use digital pins 5 and 6 as software serial
port to talk the integrated RFID reader, so we need to configure the jumpers on RS232 shield accordingly.
Step 3: Step 3: Test Code
#include "Arduino.h"
//#define DEBUG SoftwareSerial mySerial (5,6); unsigned char incomingByte; void sendIdentifyCmd () { mySerial.write (0x7c); mySerial.write (0xff); mySerial.write (0xff); mySerial.write (0x01); mySerial.write (0x08); mySerial.write (0x7d); #ifdef DEBUG Serial.print (0x7c); Serial.print (0xff); Serial.print (0xff); Serial.print (0x01); Serial.print (0x08); Serial.print (0x7d); Serial.println (); #endif } void setup () { Serial.begin (9600); mySerial.begin (9600); Serial.println ("begin initial Serial!\n"); } void loop () { sendIdentifyCmd (); delay (2); while(mySerial.available () > 0) { incomingByte=mySerial.read (); Serial.print (incomingByte,HEX); Serial.print (' '); } Serial.println (); delay (1000); }
Step 4: Step 4: Test Result
After we download the above code into Arduino, we we place the RFID tag
to the reader’s antenna, the reader will buzz, and Arduino will print the ID on the serial port.
http://linksprite.com/wiki/index.php5?title=Long_Range_UHF_RFID_reader_%281-6_meters%29_%28ISO18000-6C_EPC_G2%29_RS232
