Introduction: Use Car Vacuum, Tyre Inflater, Led Etc. at Home
This is my first instructables so please (beer) bear with me..
Step 1: Things Required in This
Things require in this..
1. Car accessory
2. 12V AC-DC adaptor
3. Wire pieces
4. Lil patience
Step 2: Hook 12V Adaptor to Car Accessory
Here first you should know the polarity of the car cigarette lighter plug & 12V adaptor
Almost 99% of the car cigarette lighter plug & 12V adaptor pin's polarity is outer -ive & inner +ive (99% coz am not sure 100%)
Refer the images.
Now take two wires & connect both positve & both negatives. you can use rubber bands also to hold the wires
Now connect the adaptor to power & enjoy your car accessory at home...easy!!!
Note:- you can find 12V adaptor in your modem, router, electric shaver, trimmer etc.
2 Comments
5 years ago
You will need quite a chunky DC adapter to do this. I've got one of those little little compressors, and a 12V/5Amp power supply which "runs" it, but it definitely starts to bog down once the pressure starts building -- due to the voltage dropping.
It runs much better on a car battery!
A 12v adapter from a modem/router/shaver will probably be killed in quite short order (most are only 800mA-2Amp). Go bigger!
5 years ago
Great life hack. Thanks for sharing with the community.
