Introduction: Use Corner Clamps to Get Right Angles
Unless someone has seen a corner clamp, they might think it is difficult to make a bookshelf or small table.
If Dagwood Bumstead had seen them, his projects would have been fine.
Here is what they are and how they help.
Step 1: Two Size Groups ; Two Types of Joints ; Buy 2 or More Clamps
Sizes
There are two sizes of corner clamps.
The smaller three inch size is usually used for picture frames
The larger size is used for making shelevs and the like.
If used carefully, either can be used for most projects
Joints
The corner clamps can be used to make a corner, such the top of a book case to the side of a bookcase
And they can be used to make a "T" joint, the end of one piece to another
Buy In Pairs
Its usually better to use these in pairs because one usually is binding both ends of a board.
Joints
Buy In Pairs
Step 2: Small Size Clamp Making Corner Joint
Here's a three inch clamp holding some 1 X2 "s at a right angle for a corner joint
Step 3: Larger Clamp Mating T Joint
Here's a heavier clamp holding 1 X 2 s for a T joint
Step 4: What These Clamps Wont Do ; What You Should Do
The Clamps will not press one piece of wood against another.
They simply hold pieces next to each other.
Usually, the pieces are joined with glue and screws.
So:
Apply glue to surfaces that will touch
Position the pieces in the clamps closely
Tighten the clamps
Drill pilot holes
Screw pieces together
Remove clamps
Tighten screws
Celebrate Victory
So:
Tighten the clamps
Drill pilot holes
Remove clamps
Tighten screws
Celebrate Victory
