Introduction: Use Fusion 360 to Make a YO-YO
Not only you'll be able to make your own customizable yo-yo with this Instructable, but you'll also learn some basic stuff about Fusion 360. No basic knowledge of Fusion 360 needed, you'll learn it here.
Download Fusion 360 here: https://www.autodesk.com/products/fusion-360/overv...
If you like Fusion 360 as much as I do, but need more help, go to Fusion's official help here: http://help.autodesk.com/view/fusion360/ENU/?guid=...
Step 1: Create Sphere
- Start a New Design.
- In the Create drop-down, select Sphere.
- Create Sphere of 80mm on the XZ plane.
- Click OK.
Step 2: Create Offset Planes
- In the browser, make sure the light bulb next to the Origin is on so you can see the planes.
- In the Construct drop-down, click Offset Plane.
- Select the XZ plane and type in a value of 41mm.
- Hit Enter or click OK.
- In the Construct drop-down, click Offset Plane once again.
- Select the XZ plane again but this time type in a value of -41mm.
Step 3: Sketch Rectangles
On both newly created planes, sketch rectangles that are bigger than the sphere. The exact size is not important, just make the rectangles big enough.
- In the Sketch drop-down select Rectangle.
- Select one of the newly created planes and create a rectangle.
- Click Stop Sketch.
- Select the second newly created plane and create a rectangle.
Step 4: Extrude the Rectangles
Use the Extrude command to cut the sphere.
- In the Create drop-down, select Extrude. Or hit E on your keyboard.
- Extrude the bottom rectangle to 41mm and make sure the Operation is set to Cut.
- Click OK.
- Hit E on your keyboard.
- Extrude the top rectangle to -15mm and make sure the Operation is set to Cut.
- Click OK.
Step 5: Fillet the Edges
- In the Modify drop-down, click Fillet. Or hit F on your keyboard.
- Select both edges and type in a value of 1mm.
- Hit Enter.
Step 6: Decorate Your Yo-yo
Sketch your own design or insert a reference image.
Step 7: Insert a Reference Image
- Click Top on the View Cube.
- Click Insert.
- Select the top face.
- Insert the image.
- Adjust and position the image.
- Click OK.
Step 8: Create Sketch
In this case, use the Line command to copy all the lines of the reference image onto the top face.
- In the Sketch drop-down, select Line. Or hit L on your keyboard.
- With the line command active, copy all the lines of the reference image.
- When done, click Stop Sketch.
Step 9: Extrude the First Set of Profiles
- Turn off the light bulb next to the Canvases in the Browser.
- In the Create drop-down, click Extrude. Or hit E on your keyboard.
- Select the four profiles shown in the image and extrude them to 1mm.
- Make sure the Operation is set to Join.
- Click OK.
Step 10: Extrude the Second Set of Profiles
- Select the three profiles shown in the image and extrude them to 2mm.
- Click OK.
Step 11: Extrude the Last Profile
- Select the profile shown in the image and extrude it to 3mm.
- Click OK.
Step 12: Create Another Sketch
- In the Sketch drop-down, click Text.
- Select the top Face.
- Type in "360".
- Adjust and position the text according to your preferences.
- Hit OK.
Step 13: Extrude the Text
- Select the text and extrude it to 1mm.
- Click OK.
Step 14: Sketch a Circle
Let's make a hole for the axle which will connect the yo-yo halves.
- Click Bottom on the View Cube.
- In the Sketch drop-down select circle.
- Select the bottom face and sketch a circle with the diameter of 15mm.
Step 15: Extrude the Circle
- Hit E on your keyboard to start the Extrude command.
- Select the circle profile we created in the last step.
- Type in a value of -10mm.
- Make sure the Operation is set to Cut.
- Click OK.
Step 16: Sketch a Circle for the Axle
- In the Sketch drop-down, select circle.
- Sketch a circle with the diameter of 15mm away from the yo-yo half.
Step 17: Extrude the Circle
- Hit E on your keyoard to start the Extrude command.
- Select the circle.
- Extrude the circle to 25mm.
- Make sure the Operation is set to New Body.
- Click OK.
Step 18: Create Chamfer
- In the Modify drop-down, select Chamfer.
- Select both edges and type in a value of 2mm.
- Click OK.
Step 19: Offset Plane
- In the Construction drop-down, click Offset Plane.
- Select the XZ plane.
- Because the axle is 25mm tall, make the plane exact half, which is 12,5mm.
- Click OK.
Step 20: Sketch a Point in the Center of the Axle
- In the Sketch drop-down, select Point.
- Select the newly created plane.
- Sketch the point in the center of the axle.
- Click OK.
Step 21: Create Another Plane
- In the Construction drop-down, select Plane Tangent to Face at Point.
- Select the newly created point in the middle of the axle.
- Select the face of the axle.
- Click OK.
New plane is created.
Step 22: Sketch a Circle on the Newly Created Plane
- In the Sketch drop-down, select Circle.
- Select the newly created plane that is tangent to the axle's face.
- Sketch a circle with the diameter of 3mm using the point that is in the middle of the axle.
Step 23: Cut Out the Hole for the String
- Select the circle profile on the face of the axle.
- Extrude the profile through the axle.
- Click OK.
Step 24: Create the Second Half of the Yo-Yo
- Right-click somewhere in the canvas to bring up the Right-click menu.
- From the Right-click menu, select Move/Copy.
- Make sure the Move Object is set to Bodies.
- Select the yo-yo's half.
- New options appear in the dialog box.
- Check the Create Copy check box.
- Click and drag the arrow to place the copy (the other half of the yo-yo) next to the first one.
- Click OK.
Step 25: Time to Print
The yo-yo design in Fusion 360 is done and ready to be 3D printed.
- Right-click on name of the design in the Browser.
- Click Save As STL.
Step 26: All 3 Parts Printed
Step 27: Attach the String and Assemble Your YO-YO.
You might need to finish the axle with a sandpaper. But it is better than making the axle too small.
