Use Xbox 360 With a Directv Remote!
Intro: Use Xbox 360 With a Directv Remote!
This "hack" allows you to use a directv remote with an xbox360, saving you around 25-30 bucks!!! I accidentally did this when I was trying to program my stereo. This is extreamly simple and easy to do. I am the first that I've seen that has done this. PLEASE DO NOT USE THIS WITHOUT MY PERMISSION. POST A COMMENT ASKING ME AND I WILL REPLY!!!
STEP 1: 1
First switch your remote to av1. Point your remote away from your reciever so that when you press a button it won't react. Then press and hold the select and mute buttons untill the light above the av1 switch blinks twice.
STEP 2: 2
press 991, then press 2. After that you press power.
STEP 3: 3
After doing this you press the up button 30-50 times untill you xbox turns on, do this slowly cause there is a small delay. If you've done everything correctly while pressing the chan. up button nothing should happen on the tv and the light above av1 will go on each time you hit it.
STEP 4: 4
When your Xbox 360 does turn on (after about 5-10 min.) press the select button to store that code and your done! Enjoy your new xbox 360 remote!!! =D
P.S. this was my 1st "hack" ever and I'm glad to see it can save you money and be somewhat usefull.
50 Comments
lcmgraber 7 years ago
would like to use your Directv/Xbox 360 hack, may I? thanks. mudcrab
CamirraC 7 years ago
can i have permission to use this with my directv remote for my xbox 360
joen39 8 years ago
can i have permission to use dish remote with xbox360?
Pandaangel76 8 years ago
Jboat77 8 years ago
monroe07 9 years ago
darkmickey420 12 years ago
wutangpoppa 12 years ago
Thyme Cypher 12 years ago
davidkichi 12 years ago
youngchulo 13 years ago
annaleecook55 13 years ago
Annalee
N2Otorious 14 years ago
Here is the quick and easy programming of the xbox 360, no scanning.
1. Turn on the Xbox 360.
2. Move the slide switch under the AV1 (or AV2) icon.
3. Press and hold the MUTE and SELECT keys at the same
time until the green light under AV1 (or AV2) flashes
twice and then release both keys.
4. Using the number keys enter the 5-digit code "21708". If performed
correctly the green light under TV will flash twice.
5. Aim the remote at your Xbox 360 and press the power
key once. The Xbox 360 should turn off.
djepik 15 years ago
zepeda128 15 years ago
errolbert 17 years ago
http://www.directv.com/learn/pdf/Remote_Controls/universal_remote_user_guide_new.pdf
It's listed under "Setup codes for DVD players"
Luis74 16 years ago
weatherjack 15 years ago
Program 16 years ago
