Use an IMac or Macbook As a Wireless Internet Tether for Xbox Live
Intro: Use an IMac or Macbook As a Wireless Internet Tether for Xbox Live
In my first instructable, I will show you how to use an iMac, or Macbook as a wireless internet tether so you can use xbox live with out buying the expensive wireless internet adapter.
What you will need:
A Mac with Mac OSX
An Xbox 360
A wireless internet access point that you have access to
An ethernet cable
What you will need:
A Mac with Mac OSX
An Xbox 360
An ethernet cable
STEP 1: Setup Some Preferences
Go on your mac and go to system preferences. Go to the network tab. Click on the ethernet button on the right side, then go to configure and select manually. enter the address as 10.0.0.1 and then enter the subnet mask as 255.255.255.0 .
STEP 2: Enable Sharing
Go back to the system preference main tab and choose the Sharing Tab. Check the box that says Internet Sharing. Then say share your conection from the Airport, and make sure the check box beneith that is on the Ethernet box. Now plug the ethernet cable into the iMac or Macbook and then the other end of it to the Xbox 360.
STEP 3: Setup on the Xbox
The next thing you need to do is too go to My Xbox on the NXE.(New Xbox Experience). Go to System Settings and then choose Network Settings. Select your IP settings and choose manual. Now enter 10.0.0.2 as your IP Address, 255.255.255.0 as your Subnet Mask, and 10.0.0.1 as your Gateway and hit done. Go ahead and test it right now, it will fail. Now go back to edit network settings and select your DNS settings this time and once again choose "Manual." Now go back to the Network tab on your mac and click on the Airport Sidebar Button, then click advanced. Click on the DNS button and see what the DNS servers panel says, in my case it is 192.168.0.1 Enter this number as your Primary DNS Server. Then go to this website: http://www.whatismyip.com/
It will tell you what your IP is. Enter this number as the secondary DNS Server on the xbox. Select done and test your connection.
You are now done and should be connected to xbox live. Please note that you will need to have your mac on and plugged into the xbox the whole time, and it may be a little laggy depending on your signal stregth.
21 Comments
ruwanindikaprasanna 9 years ago
works :D , thanks
pimtozul 10 years ago
I couldn't connect and the xbox said there were DNS problems. I eventually resolved them by doing everything this instructable said, but instead used AUTOMATIC IP, Gateway, etc settings, and used MANUAL for the DNS as instructed in this. Everything else, including everything done on the mac was done the same. I hope this could help others with the same issue.
schuie 12 years ago
I followed it and it worked for the most part, however, I can't actually play on Live because of something to do with my NAT settings. I spent a couple hours on Google trying to find an answer to the problem, but I can't seem to find anything.
I can get on just fine when I connect my Xbox directly to my router; I'm using an iMac running Snow Leopard and a Linksys E3000 router. Any ideas?
Thanks in advance!
SteinerChild 12 years ago
jdurso 12 years ago
spudstud 13 years ago
GusGags 13 years ago
kingcatfish 14 years ago
Snow1989 14 years ago
tron1o7 14 years ago
drewthevander 14 years ago
ballistik 14 years ago
Thanks
wiseguitarmaster 14 years ago
xp1123 15 years ago
jackierulesall 14 years ago
The magical duct tape kid 15 years ago
phant0m_sp00f3ra 15 years ago
drewthevander 15 years ago
