Introduction: Use of Microcontrollers to Operate and Monitor Remote Irrigation System
farmers and greenhouse operators for a low-cost automatic irrigation system.
In this project, we integrate an electronic soil moisture sensor with a microcontroller to automatically irrigate plants when the soil is too dry without human intervention, and to remotely operate and monitor soil conditions over the world wide web by sending push notifications to a mobile phone via SMS or Twitter; or other device capable of displaying a web browser via html and JavaScript. The system consists of a soil moisture sensor connected to an ESP8266 microcontroller capable of hosting a web server and responding to http requests. The microcontroller receives analog signals from the moisture sensor and activates a pump through a transistor circuit. A study correlating moisture level by water weight percent to conductivity probe output is complete. It was found that the moisture sensor saturates at a relatively low moisture level, which might limit the applicability of this sensor to certain plant and soil-type combinations. We have not yet succeeded in implementing push notifications to a mobile device via Node Red, though in theory this should be achievable.
Step 1: Checking the Moisture Level With the Conductivity Probe
I measured the conductivity in 9 pots
with different percentage content of water in order to calibrate the conductivity probe to moisture level. This allows the user to select a moisture level consistent with the needs of her particular plant species and soil combination
Step 2: Connecting the Water Pump and LCD Screen to the Arduino
I connected the water Pump to activate for 0.5 seconds in two-second intervals until desired moisture level is reached. LCD outputs set-point level and measured conductivity level (expressed as a percent of the probe saturation level)
Arduino codes
int setpoint = 0;
int moisture = 0;
int pump = 3;
pinMode(A0, INPUT); // Setting pot
pinMode(A1, INPUT); // Conductivity probe
pinMode(pump, OUTPUT); // Pump
lcd.init(); //initialize the lcd
lcd.backlight(); //open the backlight
lcd.setCursor ( 0, 0 ); // go to the top left corner
lcd.print("Setpoint: "); // write this string on the top row
lcd.setCursor ( 0, 1 ); // go to the 2nd row
lcd.print("Moisture:"); // pad string with spaces for centering
lcd.setCursor ( 0, 2 ); // go to the third row
lcd.print(" "); // pad with spaces for centering
lcd.setCursor ( 0, 3 ); // go to the fourth row
lcd.print(" D&E, Hussam ");
Step 3: Printing the Design of the Box
Basically I made a simple box for the Automatic irrigation system that has the screen place in the front and two holes for "Setpoint" and "Power" switch. Also I designed another hole on the side for the power supplies
Step 4: Final Step Putting All Parts Together
The parts price
- Arduino $20
- Pump $6
- Conductivity probe $8
- Jumper wires $6
- Breadboard $8
- Power Supply $12
- LCD $10
- Total $70
