Introduction: Useful Tips to Make Your Eyelashes Look Longer and Fuller
Eyelashes are an important element of the eye makeup and believe us they deserve as much importance as other parts which are adorned. The perfect way to make them look their best is to make them appear longer and fuller. In this way, they not only look attractive but can become the focal point of your makeup when you step out. Thus,In this article, we discuss 5 important, useful ways to give your eyelashes a fuller and longer look so as to let them catch more attention and add to your quintessential style. To make one of your best assets shine, take a look at these following points here:
1. Eyelash Comb: One of the most useful ways to make your eyelashes look longer and fuller is to use an eyelash comb. Most of the time, they are used to straighten lashes out before curling and then after applying mascara to prevent clumping. Other time you can use them when you remove the makeup so as to prevent any left out bits of makeup.
2. Eyelash Curler: Another useful way to make the lashes look thicker and fuller is to use an eyelash curler. The best time to use it is to apply it before putting on mascara. Other times you can just use it for making your lashes longer for everyday occasions.
3. Avoid Excess: Repeated use of the wand brush may result in excess clumping of mascara over its wand resulting in a lot of wastage as well as improper application. Thus make sure you clean off the excess product over the brush and then use it. You will be surprised to see that you dont need much a product for getting fuller and thicker eyelashes.
4. Always be slow to Apply: Most the time we are in such a rush and hurry that we tend to apply the mascara too quickly resulting in clumped lashes. Always take time to put on the mascara and make sure that your lashed are covered completely. This will make sure that your lashes look a lot more softer and cleaner.
5. Tight lining: Tight-lining is a technique of using eyeliner to the upper waterline in order to give a fuller look to the lashes. Make sure you use the eyeliner of the same color as your mascara to give a coherent and matching look.
Making the eyelashes longer and fuller is not difficult and can be easily achieved at home. Without resorting to expensive techniques, these tips can help to a great extent in achieving your goal. So try them out today and break the barriers around you to look great!
Click here for more beauty and makeup tips - http://goo.gl/iXTRdz
