Introduction: How to Triple the Battery Life of AAA Flashlights
When using 3W LED flashlights powered by AAA batteries, you'll expect them to last for about 30 minutes. There's a way to triple the run time by using AA batteries, which I'll show you by hooking up an AA battery holder to it.
Step 1: Things Needed
Drill
Heat shrink tubing
Inexpensive flashlight to modify (e.g. Techlite Lumen Master)
3AA battery holder with cover
3 AA NiMH batteries
Wires
Wire cutters
Solder
Sandpaper
Step 2: Extended Battery Pack
To connect wires to the flashlight, drill a small hole onto the body and sand the edges. Cut the wires slightly longer than you need and solder them to the flashlight's battery holder and the AA battery holder. For my flashlight, the wires were long enough to reach my pockets. Heat shrink tubing can be used to cover the solder joints. To make it water-resistant, add hot glue to the drilled hole.
If it doesn't come with a battery holder, you can make an adapter to hold the wires. This one fits AAA battery holders so that you may want wider dowels. To make the extended battery pack detachable, you may use 9V battery clips or DC power connectors.
Note that in the photos, I sawed the aluminum body.
Step 3: Helmet Mount
If you're using it as a helmet light, you can use cable ties, elastic bands, or bungee cords to attach it. Now your flashlight will last longer!
ShopBot Challenge
2 Comments
11 years ago on Introduction
Nice idea - execution could be tidier. There are a stack of torch holders on dx.com which would be perfect for holding the torch down better.
Personally I have a couple of old nokia phones and almost a dozen lithium batteries. I plan on gutting a phone and using the battery contacts and retaining clips, then permanently wiring it to LEDs on the bike.
Recharging batteries will use a desktop recharger I have spare.... Instructable to come one of these days.
Reply 11 years ago on Introduction
Thanks for the suggestions. I just ordered a couple of bike mounts. Laptop batteries use 18650s which usually works well.
